"Official" Lap Times Thread
I just thought of adding the suspension settings, as many inquire. Going forward you can also enter that information.
Traction Control: +R Long Press, Pedal Dance, Short Press, TC On
Shock Setting: Comfort, Sport, +R, Comfort DE5, Sport DE5, Sport+ DE5
(use DE5 if using DE5 Module)
If anyone that entered time(s) already, let me know f you would like to me to edit it, and i'll add it.
Yes please update for me. Both entries I leave TC on. Shock settings on +R.
BuntaTypeR
Model: FL5
Track Name: Willow springs SOW
Layout: Clockwise
Lap Time: 1:23:44
Date: 11/16/2024
Ambient: 35-55F
Username: BuntatypeR
Year: 2024
WHP/TQ: 300 plus? (never dyno)
Tire/Wheel: Kumho v730 265/35/18 - Apex VS-5RS 18x9.5" ET45 Wheel - 5x120mm / 64.1mm - Motorsport Gold
Mods:
Brakes:
Paragon brake pads - front R5
Paragon brake pads - rear R3
Paragon front rotors - slotted
Paragon titanium brakepad shims
Goodridge G-Stop SS Brake Line Kit
Wunderladen Racing Rear brake caliper bushings
Castrol React SRF Synthetic Racing Brake Fluid
Power and Cooling:
Phearable tune
Hondata flashpro mini
PRL intercooler
PRL front pipe with heat wrap
TSP downpipe with heat wrap
PRL HVI intake
PRL Titanium Turbocharger Inlet Pipe Kit
27won air intake snorkel
Acuity Super Cooler Reverse Flow Silicone Radiator Hose
PWR Track spec radiator
DUAL = G-Plus 25 Row AN10 10AN Transmission Oil Cooler Kit
Mishimoto aluminum expansion tank
Suspension:
JRZ RS PRO
Tein Error Canceller Kit
Spoon rigid collar front and rear
Spoon Stiff Plate Front
RV6 Adjustable Chromoly Rear Sway Bar Kit
Cusco Front Strut Tower Brace
PRL Rear mount engine mount
Eibach -Rear Camber Pro Alignment Kit
Drivetrain:
Hybrid racing short shifter assembly
Hybrid racing heavy duty trans detent springs
Technafit stainless steel clutch line
Interior:
Bride rail seats
Bride zeta IV Carbon Fiber
Misc:
Spoon radiator cap
Spoon oil filler cap
Spoon shift knob
Notes:
Time Attack Class: Modified +
Video: (if available)
Traction Control: On
Suspension Settings: front - 2.8 , rear - 2.5
BigBird
BigBird
Model: FL5
Layout: Clockwise
Lap Time: 1:23:44
Date: 11/16/2024
Ambient: 35-55F
Year: 2024
Mods:
Brakes:
Power and Cooling:
Phearable tune
PRL intercooler
PRL HVI intake
Suspension:
JRZ RS PRO
Drivetrain:
Interior:
Bride rail seats
Misc:
Spoon radiator cap
Spoon shift knob
Notes:
Amazing Build!!
I inputted the information using the form this way it populates the spreadsheet. Interesting that you used TC on with all of those mods, I'm all for whatever makes you confident. so keep it all shiny
BuntaTypeR
Amazing Build!!
I'm still a beginner with this car. I'm no Randy Pobst or Max Verstappen. Lol
  • The car is too refined and valuable for me to push beyond my limits. I'm genuinely afraid of crashing this beautiful build, and I’m okay sacrificing a second or two per lap if it means I can ensure the car makes it home safely. I had several oversteer moments that day because the rear tires were too cold (weather 35f to 55f), so I decided to dial it back and avoid taking further risks. It will be a different story if it was a 20yrs old civic.
  • I tried the long hold to turn off VSA before, but I didn’t notice much difference.
  • I’ll attempt the pedal dance to fully disable traction control soon. Hopefully, I’ll have better luck in warmer weather.
J1Avs
James
Seattle, WA
www.instagram.com
Added!
Thanks for organizing @BigBird
Model:FL5
Track Name:Ridge Motorsports Park
Layout:No Chicane
Lap Time:1:51.35
Date:10-05-2024
Ambient:65F
Username:J1Avs
Year:2023
WHP/TQ:Stock
Tire/Wheel:265/35/19; Goodyear Supercar3; 220TW; 19x19.5 +60
Mods:Camber
Notes:CSG C1X/CE1 Pads
Girodisc Front/Rear Rotors
265/35/19 Goodyear Supercar 3 (29 Heat Cycles - 182 Laps)
EVS Tuning Offset Camber Joints
Alignment Specs: -3.55* Camber (Front), -1.8* Camber (Rear), 0 Toe F/R
Castrol SRF
Time Attack Class:
Video:
Traction Control:'+R Long Press
Suspension Settings:Sport+ DE5
J1Avs
James
Seattle, WA
www.instagram.com
Model:FL5
Track Name:Pacific Raceways
Layout:N/S
Lap Time:1:34.33
Date:07-03-2024
Ambient:78F
Username:J1Avs
Year:2023
WHP/TQ:Stock
Tire/Wheel:265/35/19; Continental ECF; 200TW; 19x9.5 +60
Mods:Camber
Notes:Super Bumpy Track. Didn't Pedal Dance. Just Individual with Shocks in Comfort and Short Presh for TC.
CSG C1/CE1 Pads
265/35/19 Continental ExtremeContact Force on OE Forged Wheels
Castrol SRF
Time Attack Class:
Video:
Traction Control:Short Press
Suspension Settings:Comfort
CG13
Houston
2024 FL5 Civic Type R
Model:FL5
Track Name:Raceway Park of the Midlands/ I29 Speedway
Layout:Full clockwise
Lap Time:1:49.11
Date:10-19-2024
Ambient:
Username:CG13
Year:2024
WHP/TQ:
Tire/Wheel:Stock
Mods:Tune
Downpipe
Exhaust
Notes:Mods: Hondata tune, full Remark titanium exhaust, PRL downpipe, turbo and downpipe blankets, HEL oil cooler, PWR track spec radiator, motor mounts, brake pads and fluid, DE5 suspension controller.
The DE5 suspension controller is great here. I previously ran the FL5 unit and +R was far too stiff for this track. Pedal dance is needed to save the rear brakes. I’m faster with pedal dance and DE5 controller than I was with either FL5 controller +R long press or FL5 pedal dance.
I am having an issue with the PWR radiator with a small leak that only occurs at high temps with track driving. So far I’m unable to replicate in normal driving. It appears to be a small crack that doesn’t exist at normal temps. More to follow once diagnosed.
Next needed mod is suspension so I can achieve more negative camber to avoid destroying the soft sidewall PS4 tires.
Time Attack Class:
Video:
Traction Control:Pedal Dance
Suspension Settings: Sport+ DE5
BuntaTypeR
Model: FL5
Track Name: Willow Springs Raceway - Big Willow Track
Lap Time: 1:31:97
Date: 11/30/2024
Ambient: 35-65F
Year: 2024
Mods:
Exterior:
CF hood with vents
CF Spoon Crane Neck Wing
CF fender with vents
Wheels and tires:
Kumho v730 265/35
Evasive Titanium lug nuts
Brakes:
Power and Cooling:
Phearable tune
PRL intercooler
TSP downpipe with Lava Downpipe blanket
TSP x PTP Turbo blanket
PRL HVI intake
DUAL = G-Plus 25 Row AN10 10AN Oil Cooler Kit
Suspension:
JRZ RS PRO
Drivetrain:
Interior:
Bride rail seats
Schroth 4 point harness - quickfit
Misc:
Spoon radiator cap
Spoon shift knob
Notes:
The outer edge of the tires is completely worn, and throughout Turn 2, you can hear them screaming in protest. This is only my second time driving the Type R on this track. The last time I was here, it was on stock tires and suspension.
VSA off (long press/not pedal dance)
BigBird
BigBird
Model:FL5
Lap Time:1:49.11
Date:10-19-2024
Ambient:
Username:CG13
Year:2024
WHP/TQ:
Tire/Wheel:Stock
Mods:Tune
Downpipe
Exhaust
Time Attack Class:
Video:
interesting notes about being faster with the DE5 controler. definitely can be track dependent from what I'm seeing.
And which PWR radiator do you have? might have to get a pressure test kit to help diagnose possibly
CG13
Houston
I have the track spec radiator. It’s not leaking at all in normal driving, including driving around after a track session. It only shows any leak during high temp track driving. Because of this I don’t think a pressure test will find the leak unless done on a dyno at high temps. I haven’t been able to test this yet.
I’ve been in contact with PWR and may just send the radiator to them for replacement.
Rexpelagi
John
Nashville, TN
www.youtube.com
This is probably a silly question but you are sure it isn't the expansion tank leaking down to somewhere near the radiator?
CG13
Houston
The expansion tank isn’t near the leak I’m seeing. The apparent leak is on the right side (when facing the engine) behind the fan. I can’t see how any fluid from the expansion tank (on the left side) would reach that location.
Model:FL5Track Name:Virginia International RacewayLayout:Full CourseLap Time:2:10:28Location:Alton, VirginiaDate:12-08-2024Ambient:68FUsername:pointByPatrolYear:2024WHP/TQ:375Tire/Wheel:275/35/18; Kumho V730; 200TW; 18x9.5 +38Mods:Tune
Intake
Camber
Downpipe
Intercooler
Exhaust
Turbo Upgrade
Big Brake Kit (BBK)Notes:Time Attack Class:Video: Control:'+R Long PressSuspension Settings:'+R
