rondre3000
San Diego, CA
Anyone running CE28N+ 18x9.5 I found that the center cap size outer diameter is about 65mm and the inner diameter about 63mm to clip in. These fit perfect and I’m very happy with how they look. So much cleaner looking. Nothing worse than nice wheels with rusty brake rotors in the middle
4pcs Car Wheel Hubcaps Wheel... https://www.amazon.com/dp/B0F142D6WP?ref=ppx_pop_mob_ap_share
BTW, are those wheels in Shining Bronze Metal?
Zelixir
Benjamin
2023 Type R, 2005 R6, 2024 WRX Limited
how much of a difference on the speedo would we be seeing going to 18's and how can we go about fixing that? just want everything to be right. thanks in advance.
Speedo variation gets resolved with a Hondata. If you size your tires correctly for 18s then the variation can be less than 1% without Hondata correction
rondre3000
San Diego, CA
Google "tire size comparison". See for yourself whether you'll even need a correction.
Zelixir
Benjamin
I haven't tuned yet and I'm trying to run out the warranty before I do. if it fixes itself then great but if I gotta tune for it then ill wait to get rims. I don't mind the oem and I just picked up the AFD spacers to pull the wheels out more
Use this calculator to determine speedo variation
https://www.willtheyfit.com/
Zelixir
Benjamin
just did the calculation for 285/35/18 and itll take 20mph to 20.2 mph and 90mph to 92.5 mph. not too worried about it. thought it was gonna be greater than 5mph at 60mph. thanks for the help tho and the quick reply.
Zelixir
Benjamin
dumb question but where can I order custom made gram lights or some that have the exact specs I want? looking into those more than TE's. specifically looking for 18/9.5 +45 5x120 and looking to put 285/35/zr 18 on them
damage
United States
Civic
I see so many wheel widths and offsets here and many look identically flush against the fender. Is there a definitive 18" wheel size with exact width and offset that can fit the the widest tire width and sits flush with fender?
Sounds like you're looking for 18x10 +40(if lowered) or 18x10.5 +47 (if stock height)
damage
United States
Civic
does a 10" width support 275 tires? Does an 18" 275 width tire even fit in the front without rubbing on turns?? I definitely plan to drop the car down to about a finger gap at most.
Yup you’ll be fine as long as it’s a 275/35 or 275/30. Any thicker sidewall might cause rubbing
rondre3000
San Diego, CA
Doubt you can order to your EXACT specs if they aren't already a standard offering. Check in with some of the site sponsors (LMTLS, Garage IMMI, System Motorsports) to see what is available.
