Trey
R-00621
Atlanta, GA
I have the jailbreak, flashpro for the fl5. The hondata ots basemap is 93 octane with ITS pops and bangs. I reflashed the ecu today but do not hear any difference in +R mode. ???‍♂ Any suggestions? Thx!
Integra23
2023 Integra 6spd A-Spec
My pops and bangs at times sound like gun shots with the rv6 dp. It's even better in a parking garage ?
  • Like
Reactions: ITS
mbaapk
Twin Cities
Pacifica
Im going Vega next spring. Ill wait for the lab rats to test everything until then! Mad props to those diving in first!
BigBird
I always feel that the pops and bangs slow down the car, so I don't ask for it.
Hondata
Hondata
Hondata
Torrance California
www.hondata.com
23' Type R,22' Civic Si,18' Accord 2.0T,17' FK8
The ITS pops and bangs are just burbles like how the car comes stock. Since the FL5 stock exhaust is more restrictive than the ITS you may not hear the subtle burbles from inside the cabin. Up it to stage 1 or 2 if you want something more audible :]
arbies
Scott
Austin, TX
2023 BB Type-R
Another thing it could be... I've noticed that you need to drive the car around for a few minutes before the pop 'n bangs kick in. I assume the car needs warmed up to a min temp.
So, if you just started driving, put it into +R mode and expected pops right away... you might just need to wait longer.
Hondata
Hondata
Hondata
Torrance California
www.hondata.com
This is also correct. The burbles or pops will not occur right after flashing when you start it up.
The car needs to be driven around for at least a few feet.
Nikkonx
Chris
2023 FL5 2013 Kia Shitbox
I saw someone mention if a light comes on they turn off as well. Do they return or do I need to reflash? Stupid gas cap light came on and my pops said “no more”.
Just clear the code and you are good to go no need to reflash.
Nikkonx
Chris
Thank you. ? I’ll give it a few more miles of driving as the light turned off on its own after sitting overnight. I’ve only driven like 20miles since.
Sounds good! If any issues just clear the codes and they should come back as soon as the car reaches operating temperature.
Nikkonx
Chris
Appreciate the help. While I didn’t have a light it had 1 code found which was cleared. All is well, now.
