Rattle noise from seat belt fastener, drivers side
leodan
louisiana
2022 Honda civic touring
I hear a rattle sound when in roads with road vibrations, especially on highway. This is coming from were you adjust the height of the seat belt. I think it is because that fastener is fairly lose. I think that a soft material tape would easily eliminate the noise. I wanted to share this experience in case others have heard the noise. My civic is the touring and the vibration is in the left side of drivers seat where the seat belt height is adjusted.
kev2069667
Kevin
Phoenix, AZ
2015 Civic EX Sedan
I have the same issue on both sides. Adjusting the height to the bottom seems to help but it will still make a buzzy noise on choppy pavement. Does anyone know if Honda has a TSB so I don't have to take the b pillar apart myself?
zeroptzero
Joey
Ontario Canada
My passenger side seat belt bangs/rattles only when my wife is in the seat, it needs some sticky cloth affixed to the belt buckle to reduce banging , not related to what you posted but I thought I would add it.
Lastly, the roof liner was rattling above the driver seat / steering wheel, I stuffed a kleenex into the roof liner and it has not rattled again. ghetto fix.
Dopenutz
San Diego
22 civic si
I get this too. I just moved it to the lowest setting and it helped alot. I guess its common.
leodan
leodan
louisiana
I still have the vibration noise. I used to think it was the piece you push to change the height of seat belt but I am now wondering if it is the whole piece, meaning not only the part that is pushed but the whole piece itself. I am still trying to see what will stop the vibration noise.
kev2069667
Kevin
Phoenix, AZ
2015 Civic EX Sedan
Someone posted a YouTube fix on the seatbelt adjusters. I'm gonna try it soon. Just waiting on the clips to be shipped.
Also it looks like the dealer did put some fuzzy tape on my belt buckles before I picked it up. So that is the correct fix for that rattle.
BKK Jack
NoVA
2020 Toyota Tacoma Offraod
Extra credit for having his daughter work the camera, but a demerit for apparently reinstalling the pin that fixes the top of the b-pillar cover incorrectly.
It appears to me that he put the cover between the pin (white) and the sleeve (black). If you look at the pin at 1:55 the sleeve has a groove. That's where the it slots into the round cutout on the cover, so the pin can work properly. It's designed so a half push - to the first stop on the pin - spreads tabs on the sleeve to fix it. Pushing it all the way in releases the tabs for removal.
When he removes the pin at ~5:12, you can see that he had to physically pull it out of the cutout in the cover. When he puts the new one in at ~11:50, he has to hold it in the space, because he didn't use the groove in the sleeve. This would cause the cover to stand off the pillar a few mm's and may have contributed to some of the difficulty he appeared to have getting the cover pushed back snug to the pillar. Also, having the cutout in the cover between the pin and sleeve could make it very difficult to remove, since the pin cannot slide all the way into the sleeve to release the tabs.
johnloov
John
I’ve got the same issue, 2024 CTR, what’s the fix to eliminate this buzzing sound on both passenger and driver seatbelts?
@zeroptzero Your wife may simply need to tighten her seatbelt a little bit. When it is too loose it will bump against other surfaces.
Roof liner rattles are usually caused by the roof liner not being fully clipped into place. Simply hitting it with a hammer fist all over you will find the clip that the factory missed. Of course you don’t need to hit it very hard.
The seatbelt adjustment slider is what is causing the buzzing. I had the same issue in my FL5. I have found that all I need to do is press the slider adjuster down so it is more snug in the chosen position. I haven’t heard it buzz in over a year.
Shingo Shoji
Jeremy
FL5 - Championship White
I've got this too. I've tried tape, sound deadener and neither worked. Think I need to jam something in the seatbelt adjuster as it seems to dissapear when I press hard on it.
Another day another new rattle to deal with lol. If we all had smooth asphalt like Japan, this wouldn't be an issue.
a c i d.f l y
Austin
2024 Honda Civic Type R
Mine started doing this yesterday, and I'm two weeks into owning it. I adjusted the seatbelt height, clicked it in, then out, and it has stopped... for now. Guess we'll see.
johnloov
John
Anyone know how to open this up?
All ready broke the white clip, can get it out
11th Gen Honda Civic Rattle noise from seat belt fastener, drivers side IMG_1742
11th Gen Honda Civic Rattle noise from seat belt fastener, drivers side IMG_1741
11th Gen Honda Civic Rattle noise from seat belt fastener, drivers side IMG_1740
That white plastic fastener, you are supposed to press in until it releases the panel. I normally use a round metal dowel or punch and a small hammer or rubber mallet to press it out.
That fastener is one time use, because once you press it out to release the panel, you cant reuse it. So I would recommend getting replacements for them Part #91561-TVA-A01
johnloov
John
Many thanks, so I push it as a pull out the panel ?
