remove front license plate bracket?
vbb
vj
FL5 Type R
has anyone removed the front license plate bracket? I'm getting PPF and want it out of the way. Any tips would be great. thanks in advance.
11th Gen Honda Civic remove front license plate bracket? image0 (11)
Wow. Should have asked the dealer to not install it
vbb
vj
FL5 Type R
yep rookie error.
vbb
vj
FL5 Type R
unfortunately that's not the same. the hardware attaching mine to the bumper is completely hidden. so annoying.
Take it off and get something like a Sly Bracket. The placement of your bracket will rub the painted part of the front bumper. Get rid of it ASAP and don’t look back.
Rad Ray
Ray
Here' an example on an FK8, which would be identical to placement on the FL5.
mbaapk
Twin Cities
Pacifica
Its drilled into the black area not into the paint. There are two spots on the grill made for it specifically. Looking at it from the front you would not be able to tell. My point is its fine - there is no damage to the painted or gloss areas.
@Integra23 Look at the picture more closely. That bracket is different than the stock bracket that came with my FL5 and everyone else’s US FL5 that I’ve seen. That bracket is very similar to what came with my 09 Si and it will definitely rub the painted part of the bumper…especially if someone decides to give you a little bumper tap while the car is in a parking lot. Ugh!
dt10g
2016 Civic LX 6MT (Canadian)
I believe the original poster (who is Australian) bumper might look something akin to this
once the bracket is removed
This is an Asian market product for the 10th gen but AFAIK it will be a similar design.
This is totally different from US / Canada bumper license plate fitment where we just ram metal screws into bare plastic.
11th Gen Honda Civic remove front license plate bracket? 1682789052185
Regarding the license plate the OP showed... it seems like you could maybe slide those metal clips inwards to free it up?? I don't think it should need to be removed from the back, because there is no way Aussie dealers are pulling the bumpers to install the license plate brackets on all their cars.
TR3BLE
Auckland
Civic Type R (FL5)
It’s bolted down from behind the bumper so it’s a bumper off job.
That is super annoying. Assuming the car was pre-sold to you, they should’ve checked to see if you want the bracket installed, since it is not easy to remove. Just take the car back and have them remove it.
vbb
vj
FL5 Type R
those tabs are there only there hold the plate in place. i've had a really good look from above and below (up on a lift) and the only way to get to the hardware (which faces the radiator) is to remove the bumper or grill. both are a pain. according to my dealer all Aud cars left the factory with this madness, rather than dealer fit.
tezzasaurusrex
Terence
That's right. Bumper off job. Did it on the second week of owning it.
11th Gen Honda Civic remove front license plate bracket? 20230407_112655
AvecVtec
Alessandro
Italy
Civic FL5 Sonic Grey #7155
Cumbersome European license plate removed!
11th Gen Honda Civic remove front license plate bracket? Inked9A33E6F5-A4C4-4351-AD75-523B8EBC66F2
