arcticdc5
William
Finally had a nice cool day to do the Spoon Sports spring installation. Ordered these from Blackhawk Japan and was still able to save ~$100 vs the US vendors even after the expensive shipping (arrived in 10 days from time of order placement). I am running Bonoss 25mm rear + 20mm front spacers as the OEM +60mm offset just looks awful in my opinion. Onto the Installation: I've done a few suspension jobs in my past, but the FL5 front disassembly was by far the worst - simply removing the strut out of the knuckle assembly was the most frustrating asepct. Wiggling/pushing on the top of the rotor and then using pry bars for the final 1/4" of extraction seemed to have gotten the job done. Anyhow, onto the review:
Ride Quality: I wanted a suspension that felt close to stock as I liked the FL5 feel while it was in comfort mode. Reading a few reviews of the Spoon Sports, folks claimed that it actually rode smoother. Contemplated on getting some Eibach or Swift springs, but didn't want to slam the car down and cause a more harsh ride which I read some here and there with those. After installation and on comfort mode, I can certainly attest that the ride is much smoother than stock. I presume because Spoon engineered more coils than the OEM units.
Ride Height: As mentioned above, I didn't want to slam the car down with the Fenders touching the top of the tires look, just give it a slightly lower stance without straying too far away from the OEM ride quality. Based on my sight and included pictures, these springs do just that. It definitely has a more aggressive, lower stance, but doesn't slam you on the ground making you drive extra cautious not to scrape/bottom out everywhere. These are the latest Spoon Sports version springs with the black insulators on them. Supposedly they fixed the rear end squat look with these versions (the springs with the blue insulators are the earlier versions). About a finger and a half wheel gap which I'm totally fine with - More aggressive stance all while improving the ride quality - hard to believe but its true.
Conclusion: I would recommend these springs to anyone looking to get rid of the major wheel gap or those simply wanting a smoother ride vs the OEM. Also, if the FL5 suspension is too rough for you and are about to order the Integra Type-S damper control module - Don't! These springs will make the car ride smoother so there will be no need to waste that ~$200. Will give these another week to settle then go in for an alignment. Installation video and review soon to follow...
https://www.youtube.com/@randomrebuilds
11th Gen Honda Civic Spoon Sports Springs Installed on FL5 w/ 25mm R + 20mm F Spacers IMG_0098.JPG
11th Gen Honda Civic Spoon Sports Springs Installed on FL5 w/ 25mm R + 20mm F Spacers IMG_0101.JPG
11th Gen Honda Civic Spoon Sports Springs Installed on FL5 w/ 25mm R + 20mm F Spacers IMG_0103.JPG
11th Gen Honda Civic Spoon Sports Springs Installed on FL5 w/ 25mm R + 20mm F Spacers IMG_0104.JPG
11th Gen Honda Civic Spoon Sports Springs Installed on FL5 w/ 25mm R + 20mm F Spacers IMG_0107.JPG
realtorhoff
South Florida
2024 SGP FL5
Looks perfect. I was between these and Eibach pro-kit. Ordered the pro-kit on Wednesday and now regretting it lol. Wanted to order the Spoon Springs from Blackhawk as well and they told me they are backordered and won't be available for 2 months. You got lucky!
Robo7
Wait Spoon changed the springs? Is this change documented somewhere? I was leaning Pro-Kit because I couldn’t stand the reverse rake from the Spoon springs. What part number are yours? Did the part number change so someone can be sure they got the new versions? Maybe I need to rethink my plan now… Looking forward to your review.
arcticdc5
arcticdc5
William
This is where I gained that information from:
https://www.civicxi.com/forum/threads/🚀-tezzasaurusrex-build-journal.52260/page-3#post-889227
Info on part number change:
https://www.civicxi.com/forum/threads/🚀-tezzasaurusrex-build-journal.52260/page-5#post-904146
arcticdc5
arcticdc5
William
I think there are a few vendors in the states running a sale on em for $550 instead of $650.
https://spoonusa.com/spoon-progressive-spring-civic-fl5
https://www.evasivemotorsports.com/...TelBSyVzmoF1Zu0k90fPL-b7drPrKITRoCJaYQAvD_BwE
I would place the order from Blackhawk Japan and wait it out. These vendors in North America are taxing on these parts. There's something about needlessly paying more for the same product that doesn't work for me.
Robo7
Are folks here confident Blackhawk Japan only sells genuine parts? Looks like they would save $230 on Spoon springs and Spoon rigid collars vs. buying the same from Spoon USA. Very tempting.
arcticdc5
arcticdc5
William
Thousands of satisfied customers. I also received from Blackhawk Japan Spoon magnetic drain plugs and oil filters along with some JDM Honda accessories. 99% sure these are genuine parts.
kevinh
Kevin
Plano
2023 Civic Type R, 2019 Honda insight
Go look at Spoon Japan website and other companies from Japan. From what I saw is Blackhawk Japan sells for the same price as spoon JP.
This has surfaced a few times. Check Page 48 of this thread. A few members weigh in on BlackHawk Japan and the authenticity of the products they sell.
I've ordered from Black Hawk Japan several times, zero issues. They get their parts direct from the manufacturer and are really good about communication. As long as its in stock it takes a few days for them to process and send it out and they usually send it overnight from Japan.
raptor718
mid
Blackhawk is the play for like 80% of jdm mods. people paying hundreds extra for same stuff from resellers. If you can wait, of course.
TypeR_Kevv
Kevin
Indianapolis
24 CW Type R, 18 Type R (sold), 22 Pilot SE
You learn something new every day! Definitely ordering from black hawk moving forward for JDM stuff.
I've purchased several items from Blackhawk Japan and spent a fair amount, but know they aren’t the only game in town. JDMYamato, RHDJapan, and RZCrew are also worth a look. A word of advice: be very clear and confident in what you're ordering as returns will be a money losing endeavor. Some items are not compatible with LHD vehicles for obvious reasons and it’s on you to perform the appropriate level of due diligence.
TypeR_Kevv
Kevin
Indianapolis
That makes sense, appreciate the heads up sir!
