Spying on you?
wrath
18 Challenger RT. 26 Civic SI (soon).
I want to pull the trigger on a 2026 or 2027 Civic SI. My first brand new car in 10 years, and quite possibly my last, if these trends keep up! My brother has a Cadillac Blackwing and he had the same issue with all his driving data being sold to Lexis Nexis.
Those of you who removed your TCU:
Any problems with warranty?
can I still connect the phone via bluetooth without it spilling the beans?
if OTA updates are disabled, do I really need to bother with updates at all? Unless it's some major safety recall thing, i don't see the need.
Thank god the TCU is easy to remove. most cars you'd have to take out the entire dash board. hopefully that's still the case for the 2027s
Have not needed to use warranty
No issue with Bluetooth, I deleted the Honda app from my phone
Updates are only for the entertainment system, can easily be updated via USB thumb drive
FYI above is for the Type R, but I assume Si should be the same
No issues with warranty. With the TCU disconnected/removed, when/if you bring the car in for service at the dealer, they will not be able to use their tablets to remotely connect to the car. Instead, the service technician will connect the tablet via a hard wired connection to the OBD port to read data from the various systems on the CAN bus.
No issues with phone connectivity to the infotainment unit after the TCU has been disconnected/removed. Phone can still be used via Bluetooth or wired connection. Phone connection would still be a snitch but without vehicle specific information collected and beaconed back to the Honda mothership.
Regarding OTA updates, better off being disconnected from the mothership. When connected for example, navigation updates will be downloaded for your local area. If you want a full U.S. based navigation update, then you will need to download separately and install the update with a USB drive. Yet another reason to use offline updating.
I agree and thank Honda for making the TCU easy to remove without issue. The same cannot be said for other manufacturers that integrated telematics into other systems to make them a PITA to remove without suffering. Chevy slowly integrated that crap over decades with OnStar.
Xmetal
CTR, S3
I found a fuse (#26) called TCU in the engine bay fuse box. However, it's uninstalled from the factory. If so, why is my TCU still working perfectly fine?
11th Gen Honda Civic Spying on you? TCU Fuse1
ThunderPigeon
Long Island
Probably a generic fuse box and the TCU in this car doesn't have a dedicated fuse.
Sporky McGeuschky
Sporky
Central Texas
You're welcome!
Hey,
In this day and age, many times the "obvious" must be stated, even when, in the back of your head, you're telling yourself,
"Everyone knows this already. I don't really have to spell this out for them, right? ... RIGHT???
Well, better do it anyway... just in case."
No, not everone knows "the thing" already.
Yes, sometimes you do have to spell it out for them, and therefore make yourself Captain Obvious.
While most of us make fun of Captain Obvious out loud, we're quietly the same people who are glad we didn't "ask the stupid question", which needed to be answered by none other than... Captain Obvious.
To all the Captians Obvious of the World:
Cheers.​
The rest of us all think we're smarter than you... until we're not.
The '24 CTR TCU is in the dash, right in front of the touch screen. I could reinstall the TCU, download the latest GPS maps, and uninstall it in about 15 minutes. Car operates 100% the same with or without the TCU.
Note '27 and beyond model years are required by law to spy on you under the guise of drunk driving prevention. I believe removing the TCU in '27 models will disable the car partially or totally. Otherwise it's too easy to disobey Big Brother.
0x1d7
Washington
2025 Civic Type-R
Hondas
[*]I would not recommend connecting your phone to the vehicle as that would offer a secondary communications link back to the cloud and mothership.
Does this mean you don't recommend hooking up via Android Auto or Apple Car Play? Or are you talking about a different type of phone connection like wifi Hotspot?
Thanks!
Thanks!
If you use either, the infotainment system will pull a lot of your personal data from your phone (contact list, SMS messages, call history, etc.). If your phone also has the Hondalink app installed, then your car can use that app to communicate to the Honda mothership.
If you don't have the Hondalink app on your phone but use Andriod Auto or Apple Car Play, then you'll need to remember to do a factory reset to delete your personal information that was transferred from your phone.
With the TCU removed, software updates will need to be done by temporarily connecting to a WiFi access point or offline using a USB stick. Note that Honda vehicles that use the newer Google based infotainment system no longer allow for updates via USB. All updates must be done via communications through the TCU or via a WiFi connection. The same should apply to the 27 CTR.
Hondas
Thanks, I have a 2025 model. No Hondalink app on my phone.
Appreciate all the info!
Hondalink is such a crummy app anyways, I tried it when I had my old civic sport and found zero utility with it. The remote start would be the only thing I really wanted, but not worth the spyware
