BabyGirlChris
Christopher
Honda Civic Type R
25mm all around. Oem wheels/tires.
H&R Sport .8 inch all around.
No rubbing under any circumstances so far.
Hey man I am trying to do the same exact setup as you , same size drop and same spacers. however i’m curious to how it’s been. Has there been any rubbing at all? And as far as spacers what specs and brand did you go? Did you have to do anything special to make the 25mm spacers fit? Thank you in advance!
Hiro-san
South Africa
Civic Type R (FL5), Civic Type R (FN2)
Great pics guys.
Anyone running Eibach spacers? On the dream automotive site, they recommend getting 20mm spacers for the flush look. I'm curious to know what that looks like. Thanks.
jdezee
Jack
sanford, FL
Great pics guys.
These are Bonoss spacers but they are 20mm all around, so the fitment will be the same.
Spacer have been the best looking modifications yet.
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread PXL_20250427_144738278
Hiro-san
South Africa
Thanks! Your car looks super neat :) . Do you have a pic of the rear arch side profile that you could share? I'm just weighing up 15mm vs 20mm. Just afraid that 20mm might be too flush with the body if that makes sense.
jdezee
Jack
sanford, FL
This might be more of what your asking. IMO 20mm is perfect, no poke at all just flush fitment
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread PXL_20250402_162351698.MP
Robo7
20mm is exactly flush on the front. The rear could use an additional 2-3mm to be perfectly flush. I have Bonoss with 20mm all around and am happy with it.
Sporky McGeuschky
Sporky
Central Texas
One of the first items I wanted to address on the FL5 is the less than ideal wheel offset. I didn't want to turn to aftermarket wheels since I'm a huge fan of the 19-Inch Matte-Black Alloy OEM wheels. I decided the best path forward is to explore wheel spacers to move the wheels and tires outwards so they are more flush with the fender. The question that often arises is, "What size wheel spacer should I run to achieve the desired stance?" The answer is: It's a matter of personal preference. This thread will serve as a reference to help make that decision a little easier.
I will get us started.
Thanks for starting this thread, Clark.
Never thought I'd be here, because I never thought I would buy spacers, yet here we are.
Never Say Never Again.
1.) Car:
2025 Honda FL5 Civic Type R .
2.) Wheels, Front and Rear:
Honda (Modulo?) Forged Shark Gray FL5 Type R 19x9.5J , ET +60 .
3.) Tires, Front and Rear:
Michelin Pilot Sport All Season 4, size 275/35ZR19 100Y . Bigger, heavier tire probably negates most of the benefit of the lightweight, forged wheel.
4.) Suspension:
OEM Honda FL5 Type R .
Suspension Damper Module:
5.) Spacers, Front and Rear:
H&R Trak+ 15mm Wheel Spacers, Black .
Note:
Weight of the spacer along with weight of larger tire has got to be heavier per corner than heavy stock cast wheel + lightweight rubber band tire.
I have not measured, but we can just add the weight of an H&R 15mm spacer to the 51.4 pound wheel and tire combo to get overall weight per corner.
Gonna definitely be heavier than stock FL5 setup. Something to keep in mind.
6.) Clearance and Rub:
Front: Close to fenders, yet, so far, clear. I also have RokBlokz FL5 Rally Mud Flaps installed, which potentially closes the gap between each fender and the rolling rear of each tire. Just did over 600 miles round trip to Dallas and back home to San Antonio. No issues that I have seen or heard.
Rear: All Clear, but looks a bit tight for my preference. I'd prefer about a good half inch increaae to the rear springs, especially since I'll be keeping a full size (51 pound wheel + tire) spare in the boot. Personal preference.
7.) Wheel Studs:
Stock OEM FL5 Type R studs . Also stock FL5 lug nuts plus Honda McGard FL5 wheel locks.
8.) Photos:
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0652
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0650
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0648
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0725
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0726
Note the car is on a sloped driveway here, so the rear left corner is compressed.
The rear right corner is extended.
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0727
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0733
EDIT:
Overall weight of Honda Forged FL5 Type R wheel + Michelin PS AS4 in size 275/35ZR19... minus the plastic Honda center cap.
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0603
51.4 pounds.
Maybe 51.5 pounds with plastic center cap and Tyre Tote included?
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0604
Full Size spare and torque wrench in the trunk. Torque wrench gonna add a few extra pounds.
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0734
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0735
Some wheel-to-mud flap comparisons.
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0728
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0729
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0730
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0731
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_0732
Cheers.
Sporky McGeuschky
Sporky
Central Texas
aiggy
Miami,FL
2025 Honda Civic Type R
Hey guy, I’m trying to find myself some Bonoss spacers for my 2025 FL5. I am in search for 20mm/25mm. I’ve been trying to get them directly through Bonoss but their website seems to me shut down? Anyone have any recommendations on where I can grab these ? Thank you @everyone
They have a storefront on ebay.
beaterfl5
steve
los angeles
fl5
For reference - this fitment will work with no rub.
Car: FL5
Tires: RE71RS 275/35/19
Wheel: OEM 19" wheels
Springs: Spoon
Spacers: 15mm H&R all around
TypeRLoo
So you guys all recommend Bonoss spacer than H&R spacer? Anyone can show me picture with H&R spring with 20mm front and 25mm rear spacer? Thanks
jessefl5
Jesse
Coalinga Ca
As an update, added the 5mm slip on spacers in the back, got plenty of engagement on the lugs, but I am NOT on OEM wheels or nuts for what it's worth.
One note, don't buy the cheap ones off Amazon. I got the Akatas and they seem pretty well made for what they are, fit fine.
What wheels and nuts are you running?
