The Tuned 11th gen Experience & Reliability Thread (for all models)
Johaw
2023 Civic si
(UPDATE 2)
Vehicle: 2023 Civic SI
Total tuned time: 26 months
Tuned miles driven: 15,000
Tuning device(s) used: KTuner V2
Tunes used: Phearable 1.5R Revision
Fuel used: 93 octane
Additional related mods: 27won CAI, 27won air intake snorkel, 27won FMIC Kit , PRL x PTP Turbo Blanket, 27won 90A RMM, 27won Turbo Inlet Pipe,27won front pipe+ downpipe
TSP headstuds+ wunderladen rear cam plate waiting to install
Problems/issues: None
Driving style: Aggressive bursts here and there
Tuning experience notes: Car gets even more fun with every additional mod i do i plan on upgrading the Turbo and clutch sometime this year or next year love this car although ive been contemplating upgrading to a Type R
_1slowsi_
'23 SGP Si
Update #2
Vehicle: 2023 civic si
Total tuned time: 1 year today
Tuned miles driven: 18,000 miles
Tuning device(s) used: Ktuner v1.2
Tunes used: phearable 1.5 R
Fuel used:
91+ 1.5 Gallons of E85
Additional related mods: PRL HVI, 27WON DP, MAP Street exhaust, 27won ftst
Problems/issues:
None
Driving style: Normal 90% and the other 10% WOT in Mexico ;) always on map 2, occasionally map 3
: car feels great. i did end up lowering the car :)
ZoomZoom22
Nolan
North Carolina
22 Civic Si
Vehicle: 2022 Civic Si
Total tuned time: 4 months
Tuned miles driven: 3,000
Tuning device(s) used: Hondata
Tunes used: custom tune from national speed Wilmington
Additional related mods: MAP race catback, map front pipe, RV6 catted DP, PRL TIP, PRL intake with high flow duct, PRL IC w/ charge pipe kit, rv6 retro flywheel, exedy stage 0 clutch, ARP head studs, Custom tune through Hondata.
Problems/issues: none so far
Driving style: lots of short pulls day to day
Tuning experience notes: car feels a lot better, definitely woken up especially in top end. After tune it makes around 250hp and just under 290 tq, more than enough for some sporty driving. In my opinion staying at around this power without upgraded internals is the sweet spot for this car if it’s your daily. Couldn’t be more happy with this purchase.
11th Gen Honda Civic The Tuned 11th gen Experience & Reliability Thread (for all models) IMG_3523
gtman
gtman
Mitch
2017 Cosmic Blue EX-L Sedan
@ZoomZoom22 that's an outstanding tune build. Thanks for adding your car.
a c i d.f l y
Austin
2024 Honda Civic Type R
Vehicle: 2024 Civic Type R
Total tuned time: 3 days
Tuned miles driven: 300
Tuning device(s) used: Hondata FlashPro
Tunes used: 93-Octane Hondata basemap
Additional related mods: K&N Intake, Infinity Design Carbon Fiber inlet tube, Funk turbo blanket
Driving style: Between driving like grandma and like I stole it, and everywhere between.
Tuning experience notes: Multiple basemap and custom tuning on 10th gen 2.0NA using Ktuner, with almost 40,000 miles before reflashing to stock when I traded it in for the 11th gen Type R last July. I'm fresh to Hondata, but it's essentially the same (narrator: no it's not) with quite a bit more adjustability maps. I was finally able to get it unlocked at a Hondata Jailbreak event last Saturday and loaded the 93-Octane Hondata basemap with revhang delete. I had about 5500 miles before the tune, and nearly 5800ish miles since tuning (done a lot of driving the last few days). It's quite remarkable how much it improves the powerband and holds boost, and especially how much it improves the driving experience with the removal of revhang. I'll also note that my mpg's went up quite significantly, where I was averaging 18-20mpg, for this tank I'm seeing 200 miles before the fuel light has even come on. The computer is calculating 25+, but we'll see where it actually lands.
I plan to replace the downpipe, front pipe, and intercooler eventually. Hopefully this plays a little nicer with highflow cats than the N/A did.
Velcro62
23' Sport 2.0 NA
Vehicle: 2024 Civic 2.0NA
Tuned miles driven: 40 miles
Tuning device(s) used: KTuner V1.2
Tunes used: Pherable stage 2
Fuel used: 93 octane (tuned for 91)
Additional related mods: PRL HVI intake, remark quad exhaust
Problems/issues: first 20 miles, had high K.Con but now has stable .55-65, might have to do for still driving on my last gallon of 87OCT.
Driving style: Aggressive pulls
Tuning experience notes: not much sound change but can definitely feel the pulls harder at high rpm thanks to the tune making the VTEC, kick in at lower rpm. (Will update after another 500 Miles)
Any updates? Hows's the K.Con?
Vehicle: 2024 Honda civic hatchback sport
Tuned miles driven: ~30,000
Tunes used: ktuner basempas, phearable stage 2 (both versions)
Fuel used: 94 octane
Additional related mods: PRL HVI, function werk exhaust, function werk Frontpipe, RV6 downpipe
Problems/issues: put in a combination of bad fuel and too much e85, burnt out cat and caused knock control to rise
Driving style: spirited and a lot of aggressive bursts
Tuning experience notes: pops and bangs tune from phearable wasn't the best after the wrong fuel I put in, but the non pops and bangs version was amazing. Outside of the fuel issue and the bad cat, car ran great with zero issues. Transmission was at its limit though.
11th Gen Honda Civic The Tuned 11th gen Experience & Reliability Thread (for all models) 1000007695
_1slowsi_
'23 SGP Si
are you going to tune the Type R ??
Definitely will, not sure the number I'm looking for in terms of HP, but I'd like to hit the limit of the stock fueling system at least.
gtman
gtman
Mitch
I know many of you here come from owning a 10th gen Civic and are likely aware of the original tuning experience and reliability thread at the CivicX forum. We have nearly 1,500 tuned owners participating there.
Here, we only have 69. And while I know fewer 11th gen Civics are tuned, 69 tuned owners is a very low number.
If you're tuned, consider being a part of this project. I know there are plenty of owners on the fence regarding tuning and this thread might just help them decide one way or another. But, we need more tuned owners adding their cars and adding updates here.
SGPkaz
Greenville, SC
2022 Civic Si, Sonic Grey Pearl
UPDATE - flash to KTuner Dual basemap (I am now on TSP but will post a separate update with more detail)
Total tuned time: tuned since about 33k miles (12/25/24) this update is up to 35,555 miles
Tuned miles driven: 2500ish, about 1500 on Dual 21
Tunes used: Ktuner Dual 18 basemap, Ktuner Dual 21 basemap
Fuel used:
93 octane, Shell most often
Additional related mods: PRL HVI, PRL FMIC and charge pipes, 27won RMM street, muffler delete, high flow resonator
Problems/issues: So with the 21 Lb Basemap, the Kcon would constantly run up. Essentially had to keep driving in higher gears to learn back down. Was super finicky about gas stations- even amongst Shell stations it was highly sensitive to differences in fuel quality.. Ran a gallon of e85 here and there to ease the response of the kcon system, ultimately decided I had enough and went on to TSP (I will update on that separately).
Driving style: Aggressive bursts here and there. Normal mode in traffic and rain, sport mode all else. Typically smooth commuting with fun runs on the weekends or late night. Occasional pulls.
Tuning experience notes: The tune was very aggressive down low and jerky. Lots of power, but fell off at the top end. The torque was fun, but having to baby the car to prevent kcon from sitting up high was not. Hence, I moved on after a few months.
Wakes the car up even more, but not ideal for commuting. Too jerky.
Have wunderladen catch can I also plan on installing. I will be flashing to the TSP Stage 1 (plan to use mostly map 2) as the final destination.
More current update since late March to follow.. just wanted to document this checkpoint for the historical record.
Mobias
2024 Civic Type R, 2006 S2000
Total tuned time: 9 months
Tuned miles driven: 4000
Tuning device(s) used: Flashpro
Tunes used: IMW Custom tune
Fuel used: 93 octane and e85
R660AS Anti Surge Turbo
RV6 Carbon Fiber 3" Inlet
Full Race HPFP
Deatchswerks DW300C LPFP
Hondata 1530cc Injectors
Infinity Designs Carbon Fiber Intake
PracWorks Carbon Fiber Intake Manifold
PRL intercooler
PRL charge pipes
TSP Down Pipe
RV6 Front Pipe
Apexi N1 Catback
Hondata CanFlex
PTP Blankets (Turbo and Downpipe)
Acuity Reverse Flow Radiator Hoses
PRL Street Radiator
Exedy Stage 1 clutch
PRL Rear Motor Mount
Tuning experience notes: Had to dyno tune because we couldn't get traction for road tuning. 570whp on E50 and could easily go higher if the motor is built
11th Gen Honda Civic The Tuned 11th gen Experience & Reliability Thread (for all models) 20250101_145119
11th Gen Honda Civic The Tuned 11th gen Experience & Reliability Thread (for all models) ChrisMarvin_FL5
Domo_K
2023 Honda Civic Sport Touring 6MT
Vehicle: 2023 Civic Sport Touring 6MT
Total tuned time: 1 week
Tuned miles driven: Maybe 200? Currently sitting at about 41k miles
KTuner V2
Tunes used: Ktuner 18/dual and TSP 16.5 dual map and map 3 23/16.5
Fuel used:
93 octane
Additional related mods: 27Won FMIC, Gold reflective tape on stock intake lol.
Problems/issues:
None
Driving style: Aggressive bursts here and there. Absolutely no launching. Only did that with stock but it was just idle to flooring it so it doesn't really count I guess. No under 3k flooring as well unless absolutely necessary to get out of accident.
Tuning experience notes: I have never tuned a car or installed a FMIC but I did. This has all been scary for me because I want to keep the car in good condition. Will be attempting the 1 by 1 stud install with the Wunderland oil plate cover in the near-ish future. I have lurked in all the forums and seen all the youtube videos. I understand the risks so I am being extra careful, especially with launching. I am staying in Map 2 for TSP until I do the two above mentioned important upgrades.
One last note: I do all my own maintenance at 5k Amsoil and filter religiously. No low octane goes into my vehicle. Tried it when I first got the car and realized right away that it is not great for the vehicle.
Mrjustin81
Vehicle: 202Type R
Total tuned time: 9 days
Tuned miles driven: ~750 (nearly 8k on the odo)
Tunes used: Hondata base map
Fuel used: 93 octane(always sams club, unless not at home)
Additional related mods: N/A at the moment
Driving : kids say I’m an aggressive driver. I disagree with that. Baby it but also not afraid to give it to her. I have a 1.5 mile open stretch of highway on my way to work that there’s not even somewhere for a cop to sit and I always get it up to 100+ usually just at 1/2 throttle or a litttle more. Babybit up to really fast lol The thing loves those curves. And everyone wants to race you
Tuning experience notes:not a big fan of the Hondata, will be getting an OTS tune in the next few weeks. Probably from Phearable or maybe jestertuned, that quite a few talk about.
FBO+turbo+fuel system, no plans for ? in the future though. Big plans as long as the Si is running good
also installed the animators rear a/c vents. I got the fitment to be really good. Color isn’t exact but also it’s between two seats
11th Gen Honda Civic The Tuned 11th gen Experience & Reliability Thread (for all models) IMG_6737
