SCCA Autocross Stock Class
SlowAP2
Terry
FL
25 CTR
Anyone fit the APEX ARC-8 +58 wheels. Curious on caliper clearance and if a small spacer would be needed
I usually run a 5mm spacer up front for the track width. Tried it Sunday without and was shocked how close to the caliper it is. actually have a pic handy of it LOL
11th Gen Honda Civic SCCA Autocross Stock Class BRNFK2e
11th Gen Honda Civic SCCA Autocross Stock Class IdntGco
SlowAP2
Terry
FL
25 CTR
Awesome, I like the look of these more than the ec7 and are a bit lighter
Just be mindful of thread engagement. I got some lugs that have a shank to go into the wheel holes for more turns. Didn't feel the stock stud length was enough with a 5mm spacer.
If you do extended studs becomes a non issue.
Steven
Morgantown WV
Miata (cause fun)
If I can run without spacers I'm okay with the little bit less rotating mass
Steven
Morgantown WV
Miata (cause fun)
Yeah, so I just got my set and they do not clear the brakes. It is super close, but I would assume the wheels did some self clearancing. Which ET lugs did you end up with I just ordered a 3mm spacer
SlowAP2
Terry
FL
25 CTR
Steven
Morgantown WV
Miata (cause fun)
SlowAP2
Terry
FL
25 CTR
Pics above show them clear with no space LOL
Not sure why yours are giving you trouble. 2 I bought used and 2 I bought new from apex and both pairs clear zero issue
stamped on the back +58 and not something else?
11th Gen Honda Civic SCCA Autocross Stock Class IMG_3021
SlowAP2
Terry
FL
25 CTR
Hrm. Maybe I have the EC7 then? Thought they were arc8
went on their site and see the arc8 have those holes between the studs mine don’t have
SlowAP2
Terry
FL
25 CTR
:( sorry dude. I have them in my notes as arc8 for some reason.
Looking at apex site they don’t offer a 9.5 +58 for the CTR :/
APEXRaceParts
BMW
Hey everyone, just jumping in here real quick.
It looks like @SlowAP2 does in fact have EC-7s which will clear the OEM brakes in the 18x9.5" ET58.
The ARC-8 in that same size require 10-12mm spacers to clear, so we don't list or recommend them for these cars, especially if you're trying to stay within stock class rules.
The only wheels currently in our lineup that we have confirmed to be within that 7mm offset requirement would be our 18x9.5" ET58 EC-7 Flow Formed, 18x9.5" ET58 VS-5 Flow Formed, and 18x9.5" ET53 SM-10RS Forged.
If you have any other questions or your see a wheel that's not listed and you're curious, I definitely recommend reaching out directly first to confirm!
