Status
Not open for further replies.
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
Why another Intercooler? Don’t you guys already make an awesome intercooler for the FL5/DE5?
Yes we do! We’re incredibly proud of that intercooler, but we’ve heard the community asking for a tube and fin intercooler, so we listened, and we wanted to bring the best “no compromises” intercooler to market. Our goal with this project was simple: We wanted to make the lightest, highest-performing intercooler we could for the FL5 and DE5 platforms, while still maintaining OEM fit and finish as you’ve come to expect from PRL products. Oh, did we mention it looks mean behind the grille?
11th Gen Honda Civic COMING SOON: Meet the New PRL Tube-and-Fin Intercooler for FL5 Civic Type R & DE5 Integra Type S FL5-Tube-and-Fin-Front-Mount-intercooler-5
Why choose the Tube-and-Fin Over Bar-and-Plate?
When it comes to intercoolers, most people are familiar with bar-and-plate designs. They’re strong and durable, but they come with extra weight and added resistance to airflow. If you’re drag racing your Type R, that extra weight over the front wheels can be helpful, and the extra density of the bar and plate can be helpful to absorb all that heat over the quarter mile blast. But the downside is that it can take a longer amount of time to shed that heat again.
Tube-and-fin, on the other hand, takes a different approach. By using thinner material, this style dramatically cuts weight while still delivering the cooling performance drivers need. Less weight up front means sharper handling and quicker response, which makes a big difference for cars that already thrive on balance and precision.
Another advantage of tube-and-fin is the way it performs at speed. On the highway or during a track session, airflow moves through the core more easily, which helps it shed heat faster, while also providing better airflow to your radiator which is crucial on the Civic Type R platforms. Because there’s less restriction, the turbo doesn’t have to work as hard to maintain boost, leading to smoother power and less lag. While bar-and-plate cores might make sense in applications that demand extreme toughness, tube-and-fin offers a smarter balance for real-world driving.
Lighter, Faster, Smarter Cooling
Step one in meeting our goals required us to choose the best, lightest core possible. The star of the show is the CSF ultra-lightweight tube-and-fin core, measuring 184mm tall × 108mm thick × 716mm long (about 7.25” × 4.25” × 28.2”). This is the same core size that we utilize on our Bar and Plate intercooler, which already maximized the available space inside the OEM front bumper.
11th Gen Honda Civic COMING SOON: Meet the New PRL Tube-and-Fin Intercooler for FL5 Civic Type R & DE5 Integra Type S FL5-Tube-and-Fin-Front-Mount-intercooler-4
Step two in meeting our goals was carving every last ounce of weight out of our end tanks. We started from scratch on these designs in CAD, optimizing for proper airflow, maintaining OEM fitment, while also finding every bit of useless material to get rid of.
Step three is actually making this happen. Each end tank starts out as a 19.5lb billet block of custom extruded 6061 aluminum, and undergoes over 2 hours of machining on our state of the art 5 axis machining centers to carve them down to just 1.04 lbs. each.
11th Gen Honda Civic COMING SOON: Meet the New PRL Tube-and-Fin Intercooler for FL5 Civic Type R & DE5 Integra Type S Tube-Fin-vs-Bar-Plate
The results:
New Tube and Fin Intercooler: 14.4 lbs.
Current Bar and Plate Intercooler: 22.2lbs.
That’s a 7.8 lb. savings—roughly 35% lighter—without sacrificing cooling ability.
Why it Matters
Lighter weight means less load up front and better balance for road racing, autocross, or back-to-back pulls. And because the tube-and-fin design sheds heat faster at speed, it’s a great match for long sessions where airflow is constant.
This is only the beginning. Stay tuned for the next edition, where we'll share the results of our recently completed testing and get closer to product launch!
Evox787
Elvin
Do you still need to cut the base for the outside temperature sensor and relocate it? Or will fit like the PWR? Also can I use the HPS intercooler charge pipes? Also the stencil is optional?
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Yes, the core sizes are about the same, so the install process will be the same as the bar & plate version. Any factory fitment style charge pipe kit should fit, & the stencil is included in the box. It is up to you whether you want to spray it on or not!
SpoolinFK8
Gogi
NY, NY
2024 Honda Civic Type R FL5
Any release date yet?
mattrose4
chicago
2023 civic type R, 2013 sti
Is there any idea on price? Will it be more expensive than the previous model?
If the install process is the same as the bar and plate intercooler you sell, how does it fit without modifications? Removing the mounting tab for the ambient air tempurature sensor with a razor blade or shears to relocate, drilling a hole in the air dam, modifying o-rings from the factory charge pipes flanges, and removing air dams (Steps 8, 9, 12, and 17) is not "installation without modifications". I don't understand how both of these things can be true. Please confirm.
PRL Honda Civic Type R (2023+) Intercooler Upgrade Installation Guide
From Post #1:
"This is the same core size that we utilize on our Bar and Plate intercooler, which already maximized the available space inside the OEM front bumper without modifications."
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
From Post #1:
Good catch. I will remove that part. Temp sensor does still need to be relocated & the air dams on the bumper will still need to be removed. We provide new o-rings now, so those do not need modified.
SpoolinFK8
Gogi
NY, NY
Instead of relocating the sensor and having to drill another hole, you guys can’t just add an attachment section for the sensor in front of the intercooler?
Evox787
Elvin
I’m guessing they won’t be too expensive to develop, and since they already have the setup and instructions ready to go probably will add more to the cost.
Status
