TunerR1
- First Name
- Ge
- Joined
- Sep 20, 2023
- Threads
- 1
- Messages
- 24
- Reaction score
- 52
- Location
- Wisconsin, USA
- Vehicle(s)
- 2015 Toyota Tacoma, 2023 Civic Type R
- Thread starter
- #16
Yup; they come with these heatshrink too that you need to use at the end to help hold the sleeve in place; You don't sleeve the hose all the way to the end; you leave about 1/2 inch or so short so the heatshrink can shrink to the end of the hose (Helps reduce the diameter of the hoses so the OEM Clamps can slide over)Does indeed look nice and clean. So you just cut to length of each rubber hose, slipped it through and used OEM clamps?
I had intentions of using Gates Power Grip heatshrink clamps (But those are like 4-6 dollars a piece and one time use only) figure I'd stick to the oem clamps which don't look as nice but I can re-use over and over; plus this was very time consuming and after a while you just want it done lol.
