Best Gas For FL5?
Rad Ray
Ray
Any specific gas recommendations for the FL5? Finding 91 octane is challenging around me and I’m no fan of 10% (or greater) ethanol. Also seems that some less expensive types tend to knock even if rated as high octane.
chopsuey34
West Michigan
Some people say Costco gas is the best, some say Shell. Who knows? Don't overthink it, anything Top Tier is fine: https://toptiergas.com/licensed-brands/
Ethanol-free gas isn't worth the price increase and inconvenient locations (unless you live by a marina). Use ethanol-blended gas like the rest of us.
tuhroo
93 only if available near
stay away from discounted gas stations such as 7-11, race trac, Sams, wawa
stick to top tier stations with additives like shell, Mobil, chevron, Sunoco, Costco
DarthTrizzle
Trey
JAX, Fl
2017 Si Coupe
I've always been a Shell premium guy and have never had any issues. Some things I always do though. Never buy gas when they are refilling the tanks at the station, never get below a 1/4 tank, and I always buy from newer gas stations as their tanks are usually newer and less prone to corrosion.
CyberCTR
Sean
Co
Should I pick up 93 if it is available near me? Keep in mind my elevation is around 6500ft so I think 91 is basically 93 at that point.
tuhroo
93 is always best to run if it’s readily available for sure
ayau
Subaru
Let's clear a few misconceptions.
Ethanol is great for cars. Even the owners manual approves of using ethanol gas. Up to 15% I believe. Ethanol increases knock resistance. This is a good thing. No knock means more power.
Go to a busy gas station. The idea is less chance of getting stale gas.
Get the highest octane you can get in your area, e.g., 93
So from best to worst:
93 with 10% ethanol
91 with 10% ethanol
91 with 0% ethanol
87 with 10% ethanol
menikmati
STI, BRZ, FL5
Sounds more psychological than anything. I doubt that refilling under any of those conditions would have any noticeable effect.
DarthTrizzle
Trey
JAX, Fl
2017 Si Coupe
Prob not in these modern times as I was taught this by a legendary Porsche sports car team boss a long time ago. It's just something I've always done. I usually fill up at the same Shell station anyways though.
zeroptzero
Joey
Ontario Canada
Get the best octane you can get 91, 92, or 93, and I prefer non-ethanol as you will get best fuel economy from it. Ethanol fuels result in less fuel economy, as small as it may be.
ayau
Subaru
It’s been proven the engine knocks on 91 octane. Adding ethanol reduces this. The knock is probably not enough to cause long term damage but it’s still engine knock.
menikmati
STI, BRZ, FL5
I agree with this.
Fellow Subaru owners know all about knock :)
tuhroo
actually perform better, so who really cares about the 10 extra miles per tank?
zeroptzero
Joey
Ontario Canada
So 92 octane fuel using ethanol performs better than 92 octane fuel without ethanol ? Octane rating denotes the resistance to knock, so a 92 with ethanol is the same as 92 without ethanol. Same applies to any octane but I just used 92 in this example.
teggyluv
Josh
95 EG8, 23 FL5
Shell 91 would be my usual choice (no ethanol) but if I planned to drive it harder I'd go with a 94.
Right now the car isn't being driven much at all so shell is in it.
Both easily available in my area
