Club Version
- First Name
- Jose
- Joined
- Aug 3, 2023
- Threads
- 12
- Messages
- 335
- Reaction score
- 541
- Location
- Miami
- Website
- www.youtube.com
- Vehicle(s)
- FL5 Championship White
- Build Thread
- Link
- Thread starter
- #1
Hey everyone!
I've been debating making one of these build threads for a while now, and I suppose now that the car has seen some solid track time and will be modified further I can justify wasting more time on this forum than I already do.
Current Mod List (8-12-26)
Brakes
Endless RF-650 Racing Brake Fluid
Endless Racing Mono 6 Piston Brake Kit W/370MMĂ—34MM Rotors (EDYMXFL5) (ETA 4-5 months)
Endless MX72 Plus Front Brake Pads (RCP121 Shape) (ETA 4-5 months)
Spoon Sports Brake Hose Set
Spoon Sports Reservoir Cover
Paragon R5 Brake Pads & Titanium Shims (Front & Rear)
Paragon 2-piece Rotors Front Pair 350mm x 32mm
Wheels/Tires
Bridgestone RE71RS (255 35 R19)
OEM FL5 Wheels (19x9.5J +60)
RAYS x CLEiB TE37 Saga S-Plus BK (18x10.5J +42 Face 4) (ETA 1-2 months)
Muteki Hub Centric Ring Set (72.6mm/64.1mm)
MSI Racing Open Ended Race Lug Nuts Black (M14x1.5mm)
MSI Racing Wheel Studs (75mm/M14x1.5mm)
Suspension
OEM Type S ADS Module (39381-31M-A03)
OEM Accord Rear End Links (52320-TLB-A00)
J's Racing Camber Joint
J's Racing Hyper Springs (ETA 1-2 weeks)
Spoon Sports Rigid Collars
Spoon Sports Rear Stabilizer Bar
Track Alignment
Front Camber -3.0 Front Toe 0.00
Rear Camber -1.6 Rear Toe 0.00
Engine
HPT Cooling Plate
OEM K20C2 Engine Cover (12500-5BA-A00)
CSF Racing All Aluminum Radiator (Pending Install)
J's Racing Coolant Hose Kit (Pending Install)
Antigravity H5/Group-47 24 Ah
PRL Valve Cover Breather Connector
Seeker Oil Filler Cap
Spoon Sports Radiator Cap
Spoon Sports Heat Barrier Tape
Infinity Design Carbon Intake & Turbo Inlet (Matte)
Interior
Garmin Catalyst Driving Performance Optimizer
Sparco R 383 Wheel
Zestek SCX Racing Wheel HUB
Zestek Racing Boss Kit
OEM Alcantara Shift Boot (83443-T60-J21ZA)
Seeker Super Shift Collar Set
Spoon Sports Shift Knob
Spoon Sports Carbon Bucket Seat
Recaro Seat Rail (Recaro JDM Side Mounts)
Schroth Profi II ASM 4 Point Harness (Silver)
Cusco Seat Power Brace
Exterior
Track Day Patina
JAS Motorsport Carbon Rear Pylons
JAS Motorsport Carbon Exhaust Cover
JAS Motorsport Carbon Bonnet Air Duct
Seeker Front Wing Spoiler Carbon (ETA 1-2 months)
Seeker Double Deck Carbon Rear Wing (ETA 1-2 months)
Craft Square Carbon Mirrors (ETA 1-2 weeks)
Love at First Site
This is the day I bought the car in August of 2023 and yes I paid a $5K markup on it.
As soon as I got home, I noticed the front of the car was elevated. Curiously enough the dealer forgot to remove the shipping pucks, I took it back the next day and they removed it for me.
Track Prep
Anyways, after three weeks I passed the 1,000 mile mark and did my first oil change and got the car prepped for it's first track day at Homestead Miami Speedway. I went ahead and flushed the brake fluid with Castrol SRF, installed a Spoon Drop In Air Filter cause I'm a JDM fanboy, added some heat insulation tape around the turbo, and removed the rain shield under the hood.
During my first event with this car, I tested out the various methods of turning off the traction control and played with the onboard damper settings. Eventually I came to the conclusion that turning off VSA with the "Pedal Dance" method and running the suspension on comfort gave me the best feeling out on track and resulted in more consistent lap times.
In addition, this was my first venture into a FWD car for the track. I've been going to HPDE events since 2008 and most of my track hours have been in an S2000.
Here's a video from that day:
Overall First Impressions
I was extremely impressed with how capable the car is right out of the box, I had zero brake issues and or overheating issues. I did feel the car's power taper off after 4-5 laps but I think that's normal for all modern turbo engines these days. I did notice a brake warning light come on but didn't feel any difference in the pedal or smell fluid, so I kept on trucking.
I would say adjusting my driving style coming from RWD platforms was a challenge. I kept finding my self lifting off the brake pedal a bit too early and causing understeer as I approached the apex, once I got myself to trail-brake deeper into the corner the understeer was nonexistent.
Track Abuse Continues
I left the car As Is for my next three track days and was still left in shock how good it is. BTW my primary goal first and foremost is to have fun and become a better driver. So if you're expecting me to dig in and add boat loads of money in power mods your in the wrong thread and you're encouraged to leave.
If you're still here, I did finally destroy the OEM pads on the first session of my third track day. Thankfully, I had a set of Project MU Club Racer pads in my tool box and I was able to swap them in during a lunch break.
Here's a couple of more track day photos and videos for your enjoyment:
Here Comes the Cheater Tires (ADVAN A052)
After a total of four hard earned track days and reaching the limit of the car with the factory tires and alignment, I decided to swap in some real rubber on the car and get a custom alignment. I have a small writeup on the Tires in the following thread 255 35 R19 Yokohama Advan A052 . If you're lazy and don't wanna click a link, the tires are amazing and gave me an easy 3 seconds on track.
Also, the custom alignment really helped with more turn-in response. Using the factory slots on the top hats I was able to achieve the following: -2.0 degrees of front camber, -1/32 toe out in the front, -1.5 degrees of rear camber and 0 toe in the rear
Please enjoy the following fruits of my labor:
What's Next?
Planning to test out a few different brake pad and tire options and just have more seat time.
Anyways, I hope you guys enjoy my little build journey.
Brakes
Wheels/Tires
Suspension
Track Alignment
Engine
HPT Cooling Plate
Interior
Sparco R 383 Wheel
Exterior
Track Day Patina
Love at First Site
Track Prep
What's Next?
