Cluster swap
Shankmeyster
Shankmeyster
AZ
23 Type R
I still don't understand why they would get rid of the temp gauge. That thing is kind of important in all cars.
ivancook
Ivan
2024 Civic Si
I plan on ordering one as soon as it comes available. Only "issue" I see from the leaked photos is still no temp gauge.
Part number for the 2025 Si cluster is - 78100-T38-A02
As of now the release date for it is August 5th.
Where are these leaked photos?
ayospoonay
Josh
Orlando
2022 PWP Si
11th Gen Honda Civic Cluster swap 1721746256275-gs
11th Gen Honda Civic Cluster swap 1721746286633-ly
Looks like a temperature gauge is confirmed!
ivancook
Ivan
2024 Civic Si
Nice! So what do y'all think? Were any features added that would trigger errors when installing this unit, or is it as easy as setting the odometer and plugging it in and adding the correct buttons to the steering wheel?
ayospoonay
Josh
Orlando
2022 PWP Si
Steering wheel buttons are going to be a must I believe. They are different part numbers from the 22-24 Si.
Johaw
2023 Civic si
Definitely will be doing this swap once parts are available!
really wish the 11th gen just came with these features like they did in canada
Mossy117
Brandon
New York
22 Civic Si
I also want to swap the new cluster into my 22 Si, my question is once it’s programmed and everything, will it hurt resale value in the long run? Will it show as a mileage discrepancy even if the dealership did this?
ayospoonay
Josh
Orlando
2022 PWP Si
If a new cluster is purchased Honda can transfer your mileage from your old cluster to the new one. They cannot do it to a used cluster.
Catanzaro
It has been bugging to know if a FL5 cluster works in a SI. I have a 2024, and I just plugged it in. Sadly, the damper message appears. I also cannot control the cluster because the steering wheel switches are different. I just purchased on Ebay a type-r wheel with the switches so that will be in by the end of week. Would be nice to be able to control the cluster.
What did you remove to get to this area? I just ordered the cluster lens for the 2024. I will probably pay someone to do the job (auto places) that install and do work like this, as I do not want to risk damaging anything. Or even an auto body. For now, I am dealing with the small scratches, but I know years from now, the lens will have to be replaced. There are a few other threads on this.
Shankmeyster
Shankmeyster
AZ
23 Type R
Luckily the lens is like $10
ayospoonay
Josh
Orlando
2022 PWP Si
2025 Si Cluster is available to order!
Who is gonna be the first?
