Clutch delay valve delete analysis and how-to
Spart
2025 Integra Type S
About six months ago, I did the clutch delay valve (CDV) delete and the clutch master cylinder damper (CMC damper) delete at the same time on my DE5 ITS. If you have a non DE5/FL5 such as an Si, I'm not sure if your car has the same CMC damper, but it definitely has the CDV and the steps to delete it will be the same. I did a full video on the how-to and analysis, which will be at the very bottom of the thread. So if you're looking for good instructions on the process, I will direct you there since it's best explained on video.
In order to get some objective data on the results, I used 1000(ish) frames per second high-speed video to capture the speed at which the clutch fork moves when the clutch pedal is sidestepped, both before and after.
The TL;DR here is that doing this mod eliminates about 1/10th of a second of lag/delay in the clutch per shift. It's really a hell of a difference.
Analysis - "the only difference between screwing around and science is writing it down"
Here's the just the high speed video, 960fps played back at 30fps for an effective 32x super-slow-mo:
When you see the green “play” icon flash on the left, that’s when the clutch pedal is being released. To ensure consistency I kept the ambient temperature at approximately 75 degrees fahrenheit, and performed these tests on a completely cold engine. I used Honda brake fluid to bleed the system, and I pressed the clutch pedal firmly to the floor with a large wooden dowel that I literally kicked sideways off the pedal in order to get consistent, sudden releases with no variation.
It's easy to see the difference visually, but I also wanted to quantify it exactly and break it down. So I analyzed the high-speed video frame by frame at the pixel level in order to get data on the rate of clutch fork movement. The metal ruler is there so I could establish the exact travel of the clutch fork relative to the elapsed time. You do see the ruler shift, but I only used it to establish a baseline pixel measurement. The data resulting from that analysis is shown here:
11th Gen Honda Civic Clutch delay valve delete analysis and how-to de5-clutch-engagement-speed
On the X or horizontal axis we have time in milliseconds. On the Y or vertical axis, we have clutch fork travel in inches. In yellow is the data for the stock setup, and red shows the deleted data. This slope of the lines conveys a rate of travel - the steeper the line, the faster the rate.
Just like the video, the difference is quite drastic. The deleted setup is actually 58% engaged by the time the stock setup begins to move at full speed.
There are three obvious components to the rate of travel and I want to address the first two separately, because I think further testing would isolate each component to one of the two deleted parts. On the left side of the chart you see a diamond for both lines, and this diamond separates the first, slower rate of travel with the second, faster rate of travel. Let's focus on that first component of travel with this view:
11th Gen Honda Civic Clutch delay valve delete analysis and how-to de5-clutch-engagement-speed-initial
Because the rate of travel is so slow in the first part, I don’t believe the CDV is actually what’s exerting influence here. Instead I think what is happening is that you’re seeing pressure equalize throughout the clutch hydraulic system once one end of it, the master cylinder, has lost pressure. My hypothesis is that during this event, the CMC damper is inducing delay. By the nature of how it works, the volume of fluid inside of the damper will evacuate towards the port with the lowest pressure, in this case in the direction of the master cylinder. Only once the pressure in the damper has equalized will fluid begin to flow through the damper from the slave cylinder. This would explain why the stock setup is slower to start moving at full speed, even though the clutch delay valve should only affect higher speed operation, not lower speed operation.
Numbers-wise, the fully deleted setup is nearly twice as responsive, taking only 32 milliseconds to begin full-speed travel versus 63 milliseconds stock. I want to assert here that I believe it would make sense that this 31 millisecond difference happens both when you press the pedal and when you release it, since the CMC damper works in both directions. So for each shift, I believe this delay happens twice for a total of 62 milliseconds of delay.
So now let's focus on the second component of the rate of travel, which is between the diamond and the circle marks on each line:
11th Gen Honda Civic Clutch delay valve delete analysis and how-to de5-clutch-engagement-speed-secondary
This seems to be the regime where we have stable hydraulic flow and the CMC damper is not in play. I believe the difference maker here is the clutch delay valve. Because the CDV acts as a flow restrictor, there is a limit on how fast the fluid can flow, and what you’re seeing is the maximum speed. Ignoring the first component of the rate of travel, the clutch fork finishes its travel in 99 milliseconds stock, and 62 milliseconds deleted. So by deleting the CDV, we have increased the rate of travel in this regime by about 37%.
Of course there is a third component to the rate of travel, and in that first chart above, you’ll notice the lines dip back down towards the X axis after the circle mark on the lines. That’s because there’s a bit of rebound. The rebound is actually stronger on the deleted setup, which makes sense because it’s engaging the clutch faster. I don’t believe this rebound is actually disengaging the clutch - I think it’s just the whole chain of components settling into place. The stock setup actually starts to rebound after about two hundredths of an inch less travel than the deleted one, and you can see this on the chart where the circle for the deleted setup is higher on the Y axis than the stock setup. They both eventually come to rest at the exact same 0.563 inches of travel.
Conclusion
So what does the sum of this all mean? Well in theory, the time penalty from the CDV only happens once per shift, only on the clutch pedal release. And in theory, the time penalty from the CMC damper happens twice per shift, both on the press and release of the clutch pedal. So if we put these numbers together - 62 total milliseconds of delay from the CMC damper, and 37 milliseconds of delay from the CDV, we get a total of 99 milliseconds of delay per shift. This is substantial - an extra tenth of a second of delay can result in quite a bit of clutch slip and be disorienting for the driver. One modern technology we can compare this to would be virtual reality headsets. With those, latency between input and visual movement over 20 milliseconds can cause motion sickness, and Honda’s gadgets here add five times that amount of latency. I think what’s worse is that this delay varies with speed of operation, making it harder to predict. So you can try to drive around them, but you’ll get different results using different speeds. That is definitionally unintuitive behavior from the car. It should also be noted that the effect is not binary, this isn’t something that only affects you when you operate the clutch at maximum speed. If you’re moving slower than maximum speed, the effect you will feel manifests as variable pedal pressure.
Subjective experience
Everyone will feel a little different about this mod because driving styles vary, and some folks just don't ever learn how to drive both aggressively and accurately.
I'm familiar with putting manual cars around a track and I've always done my own heel-toe downshifts. I keep the auto-rev match systems in my cars that have had them (only two our of like twelve so far) turned off, because for me that's part of the experience and engagement.
The effect of the CDV and CMC damper didn't really trip me up so much with your mundane, everyday driving. Where it got me was doing heel-toe and trying to be fast and accurate with the clutch. If you really rip a fast heel-toe downshift, your goal is to keep the engine connected to the wheels and provide engine braking. This keeps the balance of the car consistent. My heel-toe downshifts tend to always be pretty aggressive, because I'm really just keeping my mind and muscle memory sharp so I can use it when I really need it, when going fast.
That being said, I am much more effective at doing near-perfect downshifts now than I was before. There's also a very welcome improvement to consistent, aggressive upshifts. Overall there's just more immediacy to the clutch and it feels like it grabs harder or more abruptly.
How-to instructions
As I mentioned, the how-to is best communicated in the form of video. I detailed everything here, from how the CDV works, how to delete the CDV from a stock slave cylinder, how to delete the CMC damper and swap the slave cylinder out, and even how to thoroughly bleed the system. And at the end, I added the objective analysis you see above (so you can skip that part if you've read this whole post already!) That last step of doing a thorough bleed is something a lot of folks get wrong and they don't even know it. Doing something like this gets a lot of air into your master cylinder, and it can be hard to get it all out.
Here is the complete video:
It's a long video, and there are chapters/timestamps in the description to help you navigate it.
ctechauto
This is a great data backed write up, but I have to caution to my customers (as with every mod) that YMMV and caution that this mod may come into question with an intact factory drivetrain warranty (the rate of travel is limited for a reason, to reduce driveline shock). And I am far from anyone to be loud about warranties for most cases as my shop provides parts and installs for practically any and all aftermarket modifications. Like you said, driving styles vary and some may or may not benefit from this delete.
FWIW I've never had a problem with heel-toe in any aggressive driving scenario (track included) on an FK8, FL5 with stock CDV and auto rev match off. Am I perfect every single downshift? Of course not, but this hasnt come into play for any frustration for me.
Spart
2025 Integra Type S
This is a great point and it's exactly why I retained the unmodified slave cylinder. This whole thing can be reversed in an afternoon if necessary.
I don't drive in what I would consider an abusive way (I don't like drag racing and I never dump the clutch or do burnouts or whatever else) and if something goes wrong with the trans I don't expect this to have played a part.
If anything, this is going to preserve the life of my clutch since the engagement is more consistent and predictable.
ctechauto
Yeah, thats fair. Again, just like all mods. If you/a shop have the ability and time to put it back to stock if/when anything may to happen thats a normal approach of course. Many people just by pre-deleted slaves for that reason.
Like I said for me personally, I've never had a frustration or problem with it as-is so YMMV.
Gizmo_FL5
JD
FL
@Spart what's your opinion on only doing the CMC damper delete and leaving the CDV? I did the CMC damper delete and braided steel clutch line on my old 10th gen Si and it felt pretty good, but I always wondered what deleting the CDV was like because I always felt a slight kink whenever going into 2nd gear and I simply want a smooth as butter 1-2 shift, literally have no problems with any other gear and it's the same case scenario with my 2025 FL5. My biggest concern is the increase in drivetrain shock because I have severe mechanical sympathy and overthink about the increased wear and potential damage lol. Awesome write up by the way. I already have both Sirimoto CMC damper delete and their steel braided clutch line on hand pending install. So far I've done the Acuity shifter cable bushing, shifter aluminum base bushings, and centering spring.
Spart
2025 Integra Type S
The whole point of this thread was demonstrating how they both contribute to the sensation of disconnection and unpredictability with the clutch pedal.
If you're adult enough to not sidestep the clutch repeatedly trying to find out what breaks, get rid of all of it. Get rid of the clutch helper spring, too, because it destroys the linearity of the clutch pedal pressure.
It's all useless corporate-mandated crap to cater to drivers in the lowest common denominator. None of it has a place on a performance vehicle, IMO.
When you see the green “play” icon flash on the left, that’s when the clutch pedal is being released. To ensure consistency I kept the ambient temperature at approximately 75 degrees fahrenheit, and performed these tests on a completely cold engine. I used Honda brake fluid to bleed the system, and I pressed the clutch pedal firmly to the floor with a large wooden dowel that I literally kicked sideways off the pedal in order to get consistent, sudden releases with no variation. I analyzed this video frame by frame at the pixel level in order to obtain data on the speed curve of the clutch fork movement.
Conclusion
How-to instructions
Tell me you do science without telling me you do science!
pwp25si
2025 si
Installed damper delete on my si. Disengagement definitely seems quicker and consistent. Every little bit helps, because of rev hang. With the damper, sometimes it would take longer to disengage. Maybe it's in my head, maybe it's real, but I can shift faster and more precise. I flashed back to factory, and it doesn't even feel like rev hang is ruining my shifts. Can't wait to reflash my tune with reduced rev hang. Cdv delete next.
Great writeup as usual, mr fellow regarded individual.
Im surprised I'm just finding this now when I've felt there was lag in the clutch since day one. Seems like a really good mod to do - though I have a few questions (apologies in advance if you've answered some of these, I haven't watched the full video):
1. I drive both aggressively and often. If the delay valve is removed, should I expect any less synchro wear? I try to be as accurate with my shifts as possible, and only sequentially shift, but I know plenty of people that let the synchros do all the work. I know this one is harder to measure, but theoretically it should lessen synchro wear.
2. In terms of feel, is the pedal effected at all? Can you describe any more of how the heel toe downshifts feel? I tried "gittin' gud" at heel toeing in this car but a combination of the pedal spacing and perceived lag turned me off to it. Unfortunately I've just become good at downshifting without putting one foot on two pedals. I'd love to make it easier and more engaging so I actually have a reason to practice it.
3. Bleeding the brake system is always a pain, is there any way around this? Getting air in the valve is super sketchy to me, but I've bled too many brakes to want to do it more than once if I mess up.
4. Are there any non user-related problems one could potentially run into down the road? Have you had any issues you could relate back to this modification?
5. Any other tips for the install to make it easier that you haven't already mentioned?
6. This is mostly just me being nosey, but did you ever try to figure out if the actual flow rate of the fluid across the valve (or I guess lack of valve) had changed? Could account for some of the variance you noticed. Id also be curious as to what the specs are for the OEM valve and what kinda validation they would do to say its reliable (as I read on another thread that removing it actually makes the system more reliable).
And don't take this as an insult, just genuine feedback. Calling detractors idiots and then mincing arguments to make your point doesn't make them more convincing, even to people who may have been on your side in the first place. When you have good work it shows, and any well meaning person won't say otherwise (of course subjective feel is always brought up, but arguing that is a waste of time). This is good work.
Websitesdown
I did the valve delete for my 10th Gen si that I had and I liked it. When I downshift into second gear with my 26 fl5 I can feel the slowness of the valve. You'll feel the valve finally release all the way a second after you release the clutch, you can feel the jolt when it disengages all the way.
My 24 fl5 did the same thing when downshifting into second gear. You can feel that valve disengaging. It eliminates that. As far as the other stuff you asked him I can't speak on it. I was never a heel toe guy myself. I would just blip the gas myself quickly by keeping my heel on the floor and bringing my foot over to tap the gas just right.
Rev match has spoiled me. You can order a pre modded one which is easier then modding it yourself. That's what I did with my si. Eventually I'll do it to my fl5.
Spart
2025 Integra Type S
Definitely not in your head, if the Si's hydraulic clutch system is the same as the FL5/DE5, then the analysis proves that out.
The part about it taking longer to disengage is exactly what I'm talking about with how the CMC damper creates lag between the clutch pedal and the clutch in both directions of pedal travel.
