Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
CSF released their Dual Oil Cooler Kit this week, and it appears to be a well thought-out kit with quality components. I'll copy the rest from their press release, but here are my quick thoughts below:
  • Since I've seen the WOT Kit, I was unsure about CSF's decision to make a kit that cuts into the bumper. Sidenote: credits to Jason and Casale Designs for that great bit of R&D. But after some consideration I do think that people who will heavily track their FL5's aren't as afraid of cutting, since they're already drilling for splitters, tow hooks, and anything else.
  • A painted bumper costs under $400 USD, and you can always find a wrecked car from behind or side to scavenge a front bumper from.
  • The kit has been in development for well over a year, then Dyno tested for data collection. Finally, they worked with guys like Michael Baxi and Johnny Hernandez, who are well known for their time attack builds.
  • CSF has a track record of solid cooling products, and quick search on the forum yields multiple results of people already running their upgraded Radiator.
We have the kits from both brands available on our website, here's the CSF Kit listing - LINK
Key Features:
  • Two Dual Pass High-Performance Oil Coolers
  • Superstrasse CPE lined stainless steel braided lines
  • DYME Pro/Spec Quick Release Fittings
  • Billet Sandwich Plate with 175-195°F (80-90°C) Thermostat
  • Oil Temperature reduction of up to ~15°F (~8°C)
  • Carbon Fiber Bumper Vents
  • Laser cut mounting brackets
  • Approximately 7 Quarts (6.6L) overall oil capacity
Oil Coolers
The CSF kit is built around two 13" x 4.5" (33cm x 11.5cm) Dual-Pass Oil Coolers run in series. These High-Performance Coolers offer maximum heat dissipation with uncompromising durability. The Bar/Plate cores feature CSF's "Aero-Flow" Bar Design which reduces weight while offering impressive strength and flow. The rugged design of these cores means you won't need to worry about debris from the track puncturing the coolers like with tube and fin cores.
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8119_2
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8119_4
The 100% TIG welded construction with cast end tanks further increases the overall strength of the coolers. Every cooler is pressure tested to 120 PSI before leaving the factory so you can be confident you will never have one burst on you like some weaker designs used in other kits. The end tanks also feature specially designed 40-degree angle feed/return fittings for optimal flow and lower pressure drop.
Oil Cooler Key Features:
  • Bar/Plate Core offers strength and durability
  • 100% TIG Welded Construction tested to 120 PSI
  • Smooth 40-degree feed/return fitting design
  • Dual Pass flow for additional cooling
  • Oil Capacity increased by over 2 Quarts (2 Liters)
Pressure Drop
When adding an engine oil cooler to a car that did not come with one from the factory, there is always a concern with pressure drop. This is due to the back pressure imposed on the system from running the oil through lines and cooling channels of an oil cooler.
In testing, CSF observed a small drop in oil pressure after installing the kit. While not a concern for casual driving, it was enough of an issue to address for those tracking their FL5s. To resolve this issue, CSF and test vehicles switched to a higher weight oil (from OE Spec 0W-20 to 0/5W-30) and this relieved the potential pressure issues.
MetricStock with 0W-20 OilCSF with 0W-20 OilCSF with 0/5W-30
Idle Operating Temp20 PSI (1.4 Bar)15-17 PSI (1.0-1.2 Bar)20 PSI (1.4 Bar)
On Track - Straight70 PSI (4.8 Bar)50 PSI (3.4 Bar)67-69 PSI (4.6-4.8 Bar)
On Track - Corners59 PSI (4.1 Bar)47 PSI (3.2 Bar)56 PSI (3.9 Bar)
Highway Cruising75 PSI (5.2 Bar)55 PSI (3.8 Bar)70 PSI (4.8 Bar)
CSF recommends the following oil weights depending on application:
  • Light Track Duty and/or High Performance Street: 0/5W-30
  • Heavy Track Duty and/or Dedicated Race Builds: 0/5W-40
Lines, Fittings, and Thermostat
CSF partnered with DYME PSI again for their exceptional quality and innovative quick-release hose and fitting solutions. The DYME Pro/Spec Quick Release Fittings offer race-proven performance with the convenience of tool-free clamshell removal and capable of withstanding up to 10,000 PSI. Quick Release fittings make the installation of the CSF kit much faster than traditional threaded fittings. In addition, they make maintenance like fluid changes much less of a headache.
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_9
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_10
The DYME PSI fittings are hydraulically crimped to their motorsport quality Superstrasse CPE lined 304 stainless steel braided lines. DYME PSI manufactures these lines and fittings in house to CSF exact specifications with the highest level of quality and precision. These lines offer the best flexibility, flow, and chemical resistance possible.
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_5
Oil flow is managed by a Billet Aluminum thermostatic sandwich plate. This plate bolts in the factory oil filter location with a M20x1.5 adapter. The sandwich plate was designed to reuse the OE oil filter but can be fitted with a larger filter up to 70mm in diameter with a M20x1.5 thread (check height clearance when looking at filter options).
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_6
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_11
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_12
The thermostat is designed to start opening at 175°F (80°C) and be fully open at 195°F (90°C), great for motorsports and high-performance street applications. The sandwich plate also includes a pre-plugged 1/8 NPT port for aftermarket oil temperature sensors. This is a great addition for drivers looking for more accurate data/metrics.
Key Features:
  • Fittings:
      • Forged 6061-T6 Aluminum Body
      • 180° Swivel Adjustment
      • Dual FLUOROK™ FKM Seals
      • Chemical & Heat Resistance up to 401°F (205°C) continuous operation temperature
      • Secure & Permanent Crimp-On connection for high-pressure systems
    • Lines:
      • 304 Stainless Steel reinforcing braid and Polyethylene top braid
      • Burst pressure of over 2000 PSI
      • Suitable for up to 302°F (150°C) continuous operation temperature
  • Sandwich Plate:
    • Billet Aluminum Construction
    • 175-195°F (80-90°C) Thermostat
    • Accommodates OE Filter or others up to 70mm in diameter with a M20x1.5 thread
    • 1/8 NPT Pre-plugged Port for Temperature Sensor
Ducting & Vents
The challenge of getting proper air flow to the oil coolers was straightforward but far from simple. While mounting an additional cooler behind the grill would be the easy choice, that just adds more heat to the rest of the cooling system. The optimal placement for the coolers was in the sides of the bumper outside of having no direct airflow. While technically some air does flow to this area as it leaks around the intercooler, it is not enough for significant cooling performance. While utilizing the brake cooling ducts is a potential option, that could negatively impact braking performance.
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 Light-Paints-3
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_3
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 CSF-1fastvc-FL5-37
CSF designed and modeled vents for the bumper to provide the two oil coolers with ample airflow to keep engine oil temperatures in check. These vents were carefully designed with CFD software for airflow and aero dynamics. Made from pre-preg carbon fiber, these vents match the lines and style of the FL5 and give a very OEM+ look to the front bumper. To further improve airflow and cooling, the kit also includes louvered vents that allow airflow out of the bumper area and into the fender wells.
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 DSC02685
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_7
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 DSC01515
OE Fit and Finish
CSF leveraged many industry connections to find the best possible source for motorsport grade carbon fiber. The quality, fit, and finish of these parts are of the highest caliber and have been extensively track tested. Each vent bolts on without the use of double sided tape so they are very secure.
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_4
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_14
Cut out templates are included with the kit instructions to allow for easy installation and ensure proper alignment. CSF also designed templates for the international market with FL5s that come equipped with PDC sensors. The factory PDC sensors will still function perfectly and retain the OE look and feel.
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 moontech.jp_1
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 moontech.jp_2
While there may be kits available that do not require cutting the bumper, they cannot match the airflow and cooling performance of the CSF kit.
Air Duct Key Features:
  • Motorsport Grade Pre-Preg 2x2 Carbon Fiber Construction
  • OE level fitment and finish
  • Provides optimal airflow to the Oil Coolers vs kits with air deflectors from the center opening
  • Instruction include cut out templates for easy install with motorsport grade hardware (no tape)
  • Laser Cut Louvered Vents for airflow into the wheel wells
*Note: Carbon fiber vents can be refinished as in matte clear or painted. CSF recommends using a qualified paint or body shop for best results.
Replacement Windshield Washer Reservoir
To make room inside of the right hand side bumper for both the oil cooler and proper airflow, CSF designed a replacement windshield washer fluid reservoir. This low clearance reservoir/bottle works with the factory pump and filler neck. The engine bay retains a clean factory look while freeing up space in the bumper for the cooler.
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_8
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_13
Dyno Testing
For initial testing, CSF turned to the automotive authorities and industry experts at MotoIQ for third party verified data collection. Mike and the team there developed the testing procedures for the prototype baseline data. Temperature readings were taken with two temperature sensors installed at the oil filter housing/sandwich plate for the most accurate readings. The FL5 was first run for 9 consecutive pulls on the dyno at World Motorsport to simulate hard driving and engine oil heat soak. The prototype CSF Oil Cooler Kit was then installed and the same test was conducted again. Average ambient temperature was only 0.5°F (0.3°C) higher on the test with the CSF kit.
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 8343_data-log_1
You can see from the results the CSF prototype kit offered consistently cooler engine oil temperatures throughout the test. On average the engine oil temperatures were about 9°F (5°C) cooler with the CSF kit installed. While the max temperature seen was only 222°F (105.5°C), this gave the engineering team a great comparison data point. This test was performed before the addition of the fender liner vents.
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 1769188534069-7k
ttccnn49
Steve
florida
Street triple 765RS
for the cool looking carbon vent? 🤣🤣
I have to admit, once you open a hole on the bumper, it does look badass
I'm no expert, but from an ease of installation perspective, the WOT cooler is much much much better. Im also not a big fan of changing your oil weight being the solution to the oil pressure problem.
It seems like a lot of the engineering done here wasn't intelligent and was just looking to place the coolers on a spot that was convenient on CAD. For God's sakes they offer a fix for messing with the windshield washer reservoir.
HondaHoon
Western Maryland, USA
I am current owner of the WOT dual oil cooler setup. A few take aways from this new offering that popped out to me.
1. Cutting giant windows on both sides of my factory bumper does not appeal to me. WOT uses the factory brake duct opening and printed a scoop to funnel that air into not only the brakes but the coolers as well.
2. Long have we known that when you push a light weight oil in excessive ways, it looses its viscosity, resolution is to run motor oil that is designed for high performance use and temperature ranges.
3. Long have we known, that the FL5 does not come with a oil pan baffling system that has been used on high performance wet bath engines since forever. The drop in cornering over the straightaways is likely partially attributed.
4. Both the WOT and CRF designs force the installer to remove the factory windshield reservoir and relocate to the engine bay. This is not a big deal at all and both offerings supply a solution to keep your windshield washer functional. Just beware that if you are running a HKS SSQV and a Radium CCV catch can, you will only be able to run one or the other with the WOT offering. Although I do not have any direct knowledge on the mounting of the CRF, it appears to be the same.
5. I do like how CRF designed the mounting brackets for the coolers to the chassis. Alot more designing and machining went into fabrication over the WOT offering. Both serve there function perfectly. However, I had to install some thin rubber strips to the side mounts of the WOT brackets to prevent damage to the paint/rust from metal on metal contact over time.
6. At the end of the day, both kits look substantial. I just would not personally want to cut the factory bumper, modifying the inner fender liners was stressful enough. Lol.
Just my opinions.
Also to note that it appears the $400 pre painted bumpers are no longer available.
CafeApex
AZ
2025 BB FL5
Looks awesome but there isn't a shop in the world I trust to cut into my bumper.
Shankmeyster
AZ
23 Type R
Just bought one last week. Got the old bumper if anyone needs it for this.
Another great option on the market, the bumper cutouts actually look great. For most FL5 owners this is going to be hard to recommend over the WOT kit, but having multiple options on the market is always a good thing.
Hey! Just wanted to clarify that you will also need to bump your oil weight with the WOT kit! I did on track testing and saw almost identical pressure loss with the WOT kit as this CSF kit. I also added an oil pan baffle for added insurance!
Here's my opinion piece:
CSF Pro's:
I like that they published oil pressure data and recommended bumping the viscosity!
I REALLY like those quick release hose fittings! (I generally overtighten the screw on type because I'm afraid they'll work loose)
The mounting system they use is pretty darn good!
CSF Con's:
Look....I'm just not going to cut into my bumper, or go buy another bumper. (Buying another bumper adds to the overall cost as does the tool that most of us probably don't own to cut a bumper. This just screams professional installation to me....)
There aren't any ducts to channel the air behind the bumper inserts, which increases drag.
That being said, I certainly won't judge anyone (too harshly;)) for running this kit vs the WOT kit because everyone rationalizes decisions differently, and some may really prefer the look of having the inserts in the bumper or whatever other reason they choose as their tipping point to purchase this product. I think that having different options is a good thing, and ultimately helps drive continued excitement around the FL5!
Unity Performance
Unity Performance
Humza
Great to have everyone's opinion on this!
We have happy customers with WOT products as well, and personally I would also be reluctant to cut into my bumper but there are those who won't mind as they're doing it for aesthetics as well.
Also, while uploading the HKS Oil Cooler yesterday to our website I found this video where the owner cut into the trim pieces on the edge of the grille area rather than using the supplied trim pieces.
siwelnosaj
Jason
Reno, NV
Type R
That is with the HKS China Kit, which I could be wrong on but I think was heavily influenced by the prototype of my dual OC kit I was running and shared pictures of. It used that area with ducting to provide air to the cores. I knew there was a decent chance it would get copied if I shared pictures, so I only shared these at the time because I knew we were moving away from this and towards the current dual duct concept.
To be fair, I liked this concept, but I knew it would be very tricky to make it work with the combination of a larger intercooler and/or a chassis mounted splitter (because the brackets go right in that area). I also was trying to come up with a solution that would not require cutting on any aspect of the bumper. The dual duct was the winning solution because it works with any intercooler, any splitter/brackets, any bumper with no cutting; so long as they retain the use of the OEM brake duct (which all should).
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 1 (2) (1)
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 Screenshot_20250203_093223_Photos
11th Gen Honda Civic CSF Dual Oil Cooler Kit for FL5 Picture1 (2)
