Downpipe differences
How much does having heat shields make a difference versus not having them? Will it raise the temperature a lot under the hood and affect the intake temps?
BIG difference, I strongly recommend using at least the factory heat shields. Blankets are better but definitely don't run it bare.
430 to wheels without injectors and HPFP. That dyno is reading high as shit.
Not at all, we have seen this even with our somewhat conservative dyno. That is certainly at the edge of the factory fuel system's capacity though.
I've been putting cars on a dyno since 07 and know for a fact that dynojet reads high. You might get a number that's higher than the avg for a run doesn't mean it's constant for a lot of reasons. You could probably hit over 400 9n stock turbo. Might not make it off the dyno though lol
Put the car on a mustang dyno show the mods and fuel then I'd believe you.
I think we are splitting hairs here. All dynos will read differently. Mustangs are typically known for being the most conservative. You could argue that Dynojet is pretty "standard" here in the US but even they are not all the same of course. At the end of the day, the dyno is just a tool and comparing results from different dynos will almost always lead to some level of confusion and frustration.
Tougefl5
It's hard to argue against dynojet reading high. So 430hp dynojet on a mustang would probably avg 418hp and that's a tad better than fk8 like DRob told Unity.
91 your probably 400 if lucky on a cold day with the right dynojet.
It's very misleading to give numbers on dyno without proving consistency on different dynos.
I done some research on the market and I see given Options (I'm from Europe so maybe some emission level is different between countries in EU and states in USA) :
  • HJS Motorsport - Sports-Cat Downpipe
    • Maintain EURO 6 emission requirements
    • 200cpsi Stainless Steel Primary Catalyst + 300cpsi Stainless Steel Secondary Catalyst
    • No CEL (Check-Engine-Light)
  • Milltek Sport - 5" 200 Cell Race Cat Downpipe
    • 200cpsi Catalyst
    • No info about CEL
  • Milltek Sport - Downpipe With HJS High Flow Sports Cat
    • 200cpsi HJS Catalyst
    • No info about CEL
  • Milltek Sport - Downpipe with Twin 200 Cell HJS Cat
    • 200cpsi HJS Primary Catalsyt + 200 cpsi Secondary Catalyst
    • No info about CEL
    • Very expensive !!!
  • RV6 High Temp Catted Downpipe
    • 300cpsi Catalyst
    • probably CEL (Check-Engine-Light)
  • 27WON Performance Downpipe
    • 200cpsi Catalyst
    • CEL (Check-Engine-Light) will definitely come on without tune
  • Two Step Performance (TSP) Catted High Efficiency Downpipe
    • 400cpsi GESI G-SPORT catalyst
For customer that don't want tune their ECU, TSP Downpipe is on 1'st place.
It seems that a value of 300cpsi can CEL on, while a value of 400cpsi is safe. 200cpsi and below I think can CEL on for every downpipe with this value.
I wonder about one more thing in all this. What is the characteristic of a downpipe consisting of two catalysts (e.g. HJS consists of 200cpsi primary catalyst and 300cpsi secondary catalyst). Are these values added up or are these downpipes treated differently? It also seems to be a good candidate for European market (produced in Germany so it will be easier to buy than TSP), but won't it be very close to the OEM value?
By the way, how much CPSI does OEM have?
So I'm confused, is the design of the TSP downpipe only at the size it is because it's trying to achieve a similar level of performance to the other pipes and still not give a CEL? Why don't competitors follow a similar philosophy if that's the case? I can't imagine a single person who thinks having a CEL all the time is okay.
That falls into the same realm as trying to figure out "true weight" on a person if the scale is wrong. If a person who's 200lbs loses 20lbs and reads 180lbs on the same scale, then they still lost the 20lbs.
In the case of dynonet reading high, I think the final number isn't as important as the initial number and the comparison between the two. If an fk8 makes a certain horsepower on the same dyno, and an FL5 makes more with similar mods, then the difference is proof that that final number is likely true.
You could extrapolate that to any dyno and find that it holds true.
In our experience the best way to share dyno data is offering comparisons using the same car on the same dyno. I'm not at the office at the moment so I cannot pull our factory FL5 dyno data but I am curious what you feel is a fair result on a dyno for an all stock FL5 on 93 octane.
The goal of the TSP HEDP (and the former PRL HVDP) is to provide an EPA compliant catted downpipe solution that does not make sacrifices. The 400 CEL catalyst EPA catalyst that we use is rated for flow "up to 1000hp" and does not yield a check engine light. The larger than average catalyst we use is required to achieve this.
Tougefl5
From wrestling since middle school through college. I can garentee you finding weight is more accurate than dynojet numbers lmfao ?
Tougefl5
Personally I avoid dynojet numbers because they are high. So I take them with a grain of salt. When ever I have had a car tuned I make sure to use mustang.
A stock fl5 on 93 probably going to put down 260-290 with a lot of different factors.
I do have a funny Mustang dyno story to share. Years ago, before we had a dyno of our own, we worked with another local shop that had a Mustang dyno. I walked in the door expecting the traditional Mustang dyno "heartbreaker" numbers, which would have been fine of course. The results Derek and I got back were comically high to the point that I knew they could not be shared anywhere. We were able to accomplish what we needed with the testing but the numbers were certainly a shock.
Thankfully we started with baseline testing and were able to identify the anomaly at that point instead of just testing out our changes and then getting super great numbers back. :lol:
Tougefl5
I hope you recommended the shop have there equipment serviced.
A big problem with the ctr community is people love to talk power numbers however ask for a time slip or draggy and it's crickets lol
They DEFINITELY need a proper calibration but seemed happy having the Mustang dyno with big numbers. :lol:
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
We'll definitely get our new FL5 on the same dyno, same fuel before we start adding upgrades to it. 100% agree that a dyno is just a tool, and numbers will vary between each type of dyno and how each dyno is calibrated.
That's why we also go out to 1/2 mile events, and do Dragy testing to verify how much quicker the cars are. Completely stock the last FL5 ran 125mph in the 1/2, with the mentioned upgrades we got up to 139-140; on par with other cars running the same power levels.
Back to downpipe data - I was able to pull this from our laptop, recorded in January of 2023. It was a much simpler (and boring!) time... No Hondata support, no FL5 specific parts, just the downpipe that carried over from the FK8. :D
11th Gen Honda Civic Downpipe differences Bone stock FL5 on 93 octane compared against the same car with a PRL HVDP (TSP HEDP) downpi
Nikw91
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
Was wondering the same thing.
A smaller 3” downpipe with a 200 cell cat might make similar numbers as TSPs 5” 400 cell downpipe in theory.
That’s where I’m at… do I spend the extra money on a $950 TSP downpipe or go with the $595 Maperformance downpipe or $750 on the RV6 downpipe and use that extra $200-$350 saved on a tune that will stop the check engine light
