Blindeye_03
- Joined
- Jan 23, 2016
- Threads
- 17
- Messages
- 415
- Reaction score
- 95
- Location
- Cincinnati Ohio
- Vehicle(s)
- '24 CTR - red
The airbox in these cars comes out ridiculously easy compared to almost every other car I've ever worked on.
Remove the sensor and pull it back, release two snap-in clips for some other wires, four 10mm bolts, a 5.5mm bolt on the hose clamp, and it's out.
You will waste far more time than that attempting to pump fluid in through that tiny hole with a syringe. I believe the threads are M6?
If you are serious about doing this and want to spend some money and effort to gain any sort of efficiency, I would recommend purchasing something like this:
That could be threaded into the check hole. You'd want to add a rubber washer or similar to form a temporary seal. And double-check what the treads actually are, both size and pitch.
And then getting what you need to hook that up to a fluid transfer pump of some sort. This could be as simple as a repurposed brake bleeder with a large enough reservoir, for example:
https://www.rennline.com/schwaben-3-liter-european-pressure-brake-bleeder-sku-sch-2774831/
You would want to be very careful to measure out the exact right amount of fluid so you don't underfill or overfill. This would take some trial and error at first, doing things with the car completely leveled out. But once you figure it out, you could fill the trans from the check plug with only the front of the car elevated, since you will be putting in a measured amount of fluid.
I do not think this is worth it. There shouldn't be a need to change your transmission fluid every two oil changes. Track use changes things, but using a more appropriate viscosity fluid and making cooling system changes would be a better way to handle that - if the fluid is getting cooked on track, that's never a good thing no matter how often you change it out.
We are somewhat lucky with our cars in that they already at least have a cooler (or warmer, depending) for the trans that exchanges heat with the engine coolant. It's a matter of plumbing to adapt this into a dedicated trans cooler, and the transmission already has an internal pump.
Blackstone will do UOA of transmission fluid. This will give you an idea of how the fluid is performing.
So if you have something to pump or long enough of a hose to fill the transmission via the check hole - what is the harm in doing that? Every single car that I have owned long enough to change the transmission oil I have done this way. Since the extra oil is supposed to drain out of it anyways it seems like the logical place to refill it from.
