Nothing
- Joined
- Dec 15, 2023
- Threads
- 2
- Messages
- 256
- Reaction score
- 164
- Location
- California
- Vehicle(s)
- 2023 CW FL5 #5044
At 4k miles on factory MTF, do you expect the feel to be representative of new OEM fluid? Such that OEM wouldn't also feel "smooth".You claim to speak for the average owner?
I have not had grinding, I'm not adding power, and I'm never going to track this car.
Swapping the fluid for Red Line MTL at ~4000 miles (after break in) made a VERY positive difference, on the level of the difference that the Acuity shifter made. The feel of the synchros through the shifter changed quite drastically. The OEM fluid felt inconsistent, irregular, and the shift effort was higher than it should be. Red Line MTL immediately gave me consistency, smoothness, and lessened shift effort.
The average owner of a CTR is an enthusiast almost by definition, not the plebe you imagine. Certainly if they've found this thread.
If you don't want to modify your car, don't modify your car. Instead you choose to tell other people to not modify their car. Why? Really... why?
90% of owners could stick with OEM, but also 90% of owners could stay stock. Neither of those are likely because racecar. OEM shifter is pretty good, Acuity is better, just comes down to where on the spending priority it falls for each owner.
Education is education, but like brake pad threads and the entirety of BITOG, user feedback helps us make informed choices. Certainly we don't all want to be running the same fluids just because.
