FL5 Transmission Fluid recommendation
Spart
2025 Integra Type S
My understanding is that GL5 will damage bronze parts
"Using GL5 gear oil, which is typically intended for differentials, could harm the transmission, especially if it has parts sensitive to the additives in GL5, such as synchronizers or other internal components."
Yes, don't consider a GL-5 in any weight for this or nearly any other manual transmission. They usually contain sulfur-phosphorus extreme pressure (EP) additive, which is great for a hypoid gear in a ring/pinion differential. Our cars on the other hand, being FWD only, do not have hypoid gears in the diff and thus have no need for the EP additive. Additionally (and most concerningly) that additive is corrosive to the yellow metals in your synchros, and possibly also shift forks, bushings, and thrust bearings depending on the particular trans.
GL-5 is what I put in the front and rear diffs of my Tacoma. The gearbox gets a separate GL-4 fluid, even though it's similar in viscosity to the diff fluid and I could save a few bucks by consolidating consumables.
AspecR
Stefan
Anyone run redline fluid in fl5?
Yes, I run Redline MT-90 GL4 in my car. If your car is stock then use the MT-80. I only use the 90 because my car has full bolt-ons including a bigger turbo so it helps in absorbing some of the extra stress the drivetrain would experience.
It helped reduce some of that 1-2 notchiness, felt more slick going through each gear as well. The improvement could be felt immediately.
Spart
2025 Integra Type S
Did you mean Redline MTL? (75W80)
MT-80 isn't a thing. MT-85 is.
Redline MT-LV or Redline MTL would be in the correct/adjacent viscosity range to the OEM Honda MTL, MT-85 is higher viscosity than OEM by a good amount. See my post on page 3.
AspecR
Stefan
My bad, MTL is correct. I'm so used to MT90 I forgot MT80 isn't a thing and MTL is OE equivalent
Ktrw
Zach
United States
2025 Integra Type S
I'm running Redline MTL as well, and it's doing great. Maybe a bit smoother getting into 2nd gear compared to the factory fluid, but not a huge difference. I just really wanted to get fresh fluid in the trans after everything had broken in.
I will say when the car was brand new everything felt a bit more notchy and I had a few 2nd gear grinding issues that were completely random. After a few thousand miles everything felt much better, so it wasn't really going to fix a problem since I wasn't having any.
Spart
2025 Integra Type S
I'm considering doing an A/B test with Redline MTL and AC Delco 10-4014.
My main gripe with the OE fluid is that the synchros don't feel smooth. It feels like they're working harder than they should, making the shift effort higher than it should be. I do not have any grind issues.
Spart
2025 Integra Type S
Do you know how this differs from like motul 75w -90? I just did my flush in November and used Motul 75w-90
Well it's not 75W-90 for starters. It's closer to 75W-80. OEM Honda MTF is closer to a 70W-75.
There's too much misinformation in this thread, including people recommending that you use GL-5 gear oil meant for hypoid differentials, which is fully regarded.
That's why I started this thread:
https://www.civicxi.com/forum/threads/fl5-de5-transmission-fluid-reference.63072/
TypeRbuilder
Vince
Cleveland
www.tdpracingind.com
25 Civic Type R
So I remember a very long time ago I used to use redline oil. I had a 91 Civic with a manual transmission. And I put the red line transmission fluid in it. All I remember was the transmission having to be replaced because it was shredded. And I didn’t drive that car hard. After that, I never use red line again.
mattrose4
chicago
2023 civic type R, 2013 sti
Really good information over there. Good write up. I do track my car so thats why I went with the motul 75w-90, but after reading that I may just go to the fluid Ben recommended
