FL5 PRL HVI Intake Installed
So it will heat up oil temp and water temp wise as much as stock with any tune. Since the heat buildup is gradual but cannot be dissipated quickly enough.
Now on tune difference they will have different cylinder temps depending on the approach taken. That will determine amount of knock and how much timing it will pull.
Fair enough. Thanks for the information.
With cool down laps no issues should be present be it stock or tuned. But highly advise on upgrading the cooling components. And you are welcome!
ELIAS64
Elias
Miami, FL
23’ Type R
I can confirm that you don’t need to buy the $50 coupler guys. PRL customer service told me I needed to buy it in order to use the HVI with their titanium inlet pipe, but that’s not the case. Perfect fit.
11th Gen Honda Civic FL5 PRL HVI Intake Installed IMG_2320
I would love to see this in person before I leave Miami.
elusiveaura
Tennessee
2023 Civic Type R - SGP
Wait, what?? You serious? I see the picture lol but why would they say you need it otherwise? Maybe the silicone tubing is slightly larger and fits better with the addon coupler? Something has to be different right?
Miami_TypeR
Jordan
Fort Lauderdale
Anyone got the instructions for the install of the PRL intake? I got my box in but didn’t come with any instructions for the install
Loulerg
Lou
2023 Civic Type R BB #5515
elusiveaura
Tennessee
so do you really not need the coupler as stated above if we have titanium inlet? Anyone else confirm?
This is an example of making something work vs doing it right. PRL didn't design extra couplers as a cash grab, it wouldn't be worth the trouble for them. We have had customers report using the "standard hoses" and connecting to the HVI, and then having them come disconnected after driving the car.
elusiveaura
Tennessee
I figured as much. I bought the larger ones prl made for it so I’m fine. Was curious how they initially made stock work though if prl had stated otherwise.
BigBird
Will this intake heat soak more or the same as factory setup?
