FX3D rock guards
spiff72
West Michigan
Being Canadian, I'm quite bad with imperial measurements lol.
1/4" ID is fine.
OD isn't that important. I'd say between 1/2" and 1" would be ok.
The spacers I designed are 4.5mm thick so slightly more than 1/16" thick.
Heh - 4.5mm is what i needed to know. That's actually about 3/16" :)
fenix-silver
Central PA
2024 Type R; 2019 Si (sold)
I had a few plastic washers lying around that came with a picture hanging kit or something. Just had to drill out the hole a bit. Work great. I know Lowes carries a whole assortment of nylon washers as well which I used in the past to mount mud flaps on my WRX.
KhaoS2K
S2000, FL5R
Quick follow up since I've had a bunch of DMs and emails regarding the new version.
Here's how the V3 fronts guards will be looking like.
Still looking for a local guy willing to let me work on his car to modify the rear design and add a lower bracket that shall eliminate the need for the tape and additional screw.
This modification should offer the possibility for the older models to use that bracket as well.
Product is now back in stock on the website.
Thanks guys!
11th Gen Honda Civic FX3D rock guards FL5-Front-V3
araska
Just ordered mine just now! Hoping they come soon as I’m scared to drive on these ugly roads without the proper protection ?!
Any idea how long it’ll take to get here to Los Angeles? ??
KhaoS2K
S2000, FL5R
Thank you for the order!
We have made a bunch of modifications and upgrades this week since I was able to get a hold of an FL5 to test fit everything.
I'll be working on the updated install guide during the weekend, but it may take a day or two more than usual to send the package out. You'll get the fully updated version #3 though, so it'll be worth the wait.
Usually takes about 5-10 days to arrive to Los Angeles.
I'll be posting the complete list of upgrades over here in a bit. We made sure that most upgrades will be fully compatible with the older versions. So the plan is to make a retrofit hardware kit available to anyone interested.
Stay tuned.
evlsmurf
2016 Subaru Impreza Sport
Maybe I will hold off installing then...
araska
Thanks for the update! Will you provide a tracking number once shipped?
edit: lol nvm, I just reread my confirmation and it said “tracked packet USA” hahah. Will be eagerly waiting for that!
araska
Stay tuned.
Was wondering if today is when the product will be shipped?? ??
KhaoS2K
S2000, FL5R
Shoot me an email to (info "at" fx3ddesign.com) with your order number and I'll see where you currently sit in the pipeline.
06S2k07Si
Brian
Wisconsin
06 S2000 22 RDX 13 CB1000R 22 Veloster N 18 Type R
If I had to make a small suggestion, i'd want the flaps to go up and reach that third OEM screw in the bumper. That way, most of the painted surfaces will be protected.
I think this is a great suggestion and should be considered. I just purchased a set myself today and am looking forward to seeing these in person. One of my concerns in that based on all of the pictures I've seen, I think they should come up higher in both the rear and the front.
Thanks, Brian
RP2000R
WA
23 CTR, 21 Porsche Cayman GT4, 15 Lexus IS350 RWD
Any bigger or higher these will look like Rally Armor style guards.
KhaoS2K
S2000, FL5R
***SOLD***
I have a set of the previous V2 design in stock. It will come with the updated V3 hardware, so the only difference will be the pattern of the vented area which is a bit more opened up.
Only available in black and only have one full set available. First come, first serve!
FX3D Design - FL5 Rock Guards (direct link)
svvitch
Installed mine last week. Went well and held up for my weekend track event. So far so good kept the rubber off the side of the car :cool:
