arcticdc5
William
-Spoon Springs
-275/35/18 Yokohama V601
Have never done this before (downsizing in wheels from the oem size), but digging the 18"s and meatier tires look. Took about 4.5 months from time of ordering from Garage IMMI (whom did a phenomenal job of keeping me posted on their shipment status) to reach me here in Virginia. Think I did right with matte black as the bronze color clashes with Boost Blue imo.
Anyhow - factory alignment specs and alignment pins are still intact - zero rubbing whatsoever. Car def rides smoother with the 35 series V601 tires, but only complaint is the super sharp steering response that the 19" OEM PS4S tires had is now toned down (guessing due to thicker sidewall and softer than the PS4S tires).
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) freshly installed
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) side vi
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) front 34 num2
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) wheel detail
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) rear 34
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) front pok
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) rer poke 2
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) rear 34 num2
getRIGHT
Anyone with Swift/Eibach Pro/Spoon springs have passengers in your car often and have any tire rubbing issues?
18x10 +40 Advan GT Beyond
265/35/18 Mich P4S
Since you got the Swift spring answer I can now answer the question from the Spoon springs side. Last night I drove with 4 normal sized adults in the car. Mobbed all around town at freeway speeds in all types of situations.
No rubs whatsoever.
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) IMG_2061
Ouhei
Alex
Raleigh, NC
2025 CW CTR
Looks amazing. How’s the ride quality?
The Swifts are on the stiff side for sure, but if your roads are decent they ride really smooth most of the time. The only time they bother me is on really bad roads, but the OEM setup isn't exactly great there either.
Shingo Shoji
Jeremy
FL5 - Championship White
Looks awesome. Same setup as me. I’ve never looked back.
-Spoon Springs
neildrives
Neil
Bay Area, CA
2023 CW FL5 Type R #8960
Any folks with this wheel spec running 265's?
Thinking of upgrading to a 275 next but want a squarer tire. Thinking a RE-71RS or RT660 in a 265 would fit better than a 275 280+ TW tire.
Love my AD09's but bothers me that the rim is exposed, don't want to curb it.
ctechauto
285/30/18 AD09. Pretty square on the wheel.
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) 2025-07-24_10-04-36
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) PXL_20251021_145257152
arcticdc5
William
You do not want a 265 tire on a 10” wheel for a “squarer” tire look. 275 with a TW of 200 or lower will achieve that or a 285/295 non-competition tire with a TW of 200+.
SKINNIE
DFW TX
ISF, 23' BB FL5
Scroll up 3 posts 😂
neildrives
Neil
Bay Area, CA
Figured, looks like I gotta get some camber joints
airs
Seattle, WA
Boost Blue 2025 Type R
Haven't seen anyone else running 30 series on 18x10's - how is it? Any rubbing? Looks like maybe sportline springs?
ctechauto
Ohlins with shorter swift springs. Its lower than sportlines by about .5" up front (about 1.75" drop total). Also -3⁰ front camber, no rubbing.
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) 2025-07-24_10-03-32
airs
Seattle, WA
Anyone running PS4S 285/35/18? I just got some 18x10 Volks and considering this specific tire/size as I've heard that 275 looks stretched using the PS4S. Planning to run Eibach Pro kit springs eventually.
Has anyone been running this setup for a while with extra front camber? I just installed EVS ball joints in spring, and have already chewed through 3 front tires. The OEM Michelins that had about 12k miles on them corded pretty quickly after about a dozen autocross runs after the camber change, but they also had roughly 8-10 events (~50-60 runs) and a track day on them before that so I'm still not entirely sure how much to attribute their demise to the camber... but also worth noting that one of the Falken RT660+ I replaced them with is also pretty much destroyed, but I believe that may be a delamination issue, or at worst my toe may be off on the passenger side. But this one only lasted 2 events, and roughly 1500 miles (the other side is fine though). These were 275/30/19 on 19x9.5 +45 Apex VS-5RS.
Just curious about the life expectancy of tires if I leave the camber as is. It's currently at -3.5. I plan on going with 275/35/18 RE-71RS. I'll do at minimum 1 autocross event per month but honestly probably no more than 3, and hopefully at least 2 track days this upcoming season. I'd like to think I can still have some tire left after a season, assuming I rotate every 2-3 events at a minimum (and probably flip mount halfway through).
ctechauto
Toe destroys tires way faster than camber. What is your toe set at?
PWR2W8T
Boise, ID
2025 CTR
I have my own "God Spec" being built....19x10 ET40, yeah I know, not the same thing. Excited to have them in the next few months.
