How to remove fender tabs?
S2K_FD3S
Houston
S2K, FD3S, FL5
Hi all
Newb question here. But how do you remove these tabs without breaking them?
I'm trying to install fender guards on the FL5. Figured i ask before I break two more tabs. I used flat head. I've used 2 flat heads. Broke both tabs on the driver side already.
Thanks in advance
11th Gen Honda Civic How to remove fender tabs? 20250522_102108
egxflash
CA
2024 Integra Type-S
Just pop out the middle (in red below) and the entire tab should pop out easily. You can use a thin flathead or use trim removal tools like these.
11th Gen Honda Civic How to remove fender tabs? Screenshot 2025-05-22 083849
PNEUMA
Jerry
PNW
2025 FL5
My car was brand new and two of the four still broke. This is even after using a small bit of spray lubricant on them and two very small flathead screwdrivers, to help in popping up the center button.
If your car has been driven in the rain at all, the road grime that migrates in pretty much guarantees that these rivets will break. Just go to a dealership as the parts department always has them in stock.
ctechauto
That's what I did. They break before popping out.
The fender ones are notorious for breaking even if you're careful. What works best we've seen is dont try to do it in one motion. Little by little with very light pressure and they should scooch out.
Xmetal
CTR, S3
Does anyone know what's the part number for these push rivets? Thanks.
I broke nearly half of these removing fender liners to install sound deadening, and I used the specialty tools.
Fortunately I recently purchased a 99 piece fastener assortment from ebay (less than $12), which has 20 of the pictured fasteners.
PNEUMA
Jerry
PNW
2025 FL5
I don’t, yet when I was at the parts counter asking for a quantity of two, the Gentleman asked if they were the large or small ones? I didn’t know but he said there were only two sizes of these rivets.
after breaking two of them using the pin remover tool I had at home (the one the looks like a forked snake tongue), I filed a screw driver tip to make it thinner, and used it very gently, moving it from one side of the clip to the other side till it popped out.
but I am going to get the Harbor Freight Tools pin plier today...
Clips are different sizes:
91505-TR0-003 (Common area: #16 Inner fender clips MSRP $3.97 each)
91505-TM8-003 (Common area: #17 Bumper clips MSRP $0.57 each)
91512-SX0-003 (Common area: #18 Inner fender clips MSRP $2.97 each)
For removal, I tried many different tools. The best option that I found without breaking the top of the clip is to use stereo removal tools (commonly found in trim removal kits). Slide one on each side of the clip to provide tension and gently twist one side to pop the clip open for easy removal.
11th Gen Honda Civic How to remove fender tabs? IMG_1655
Had this exact problem when installing my megachip mudguards (luckily they give replacement pins lol).
One of the clips snapped in half and fell into the fender vent area, it's pretty benign and I can't hear it since it has very little room (if any to move around). Does anyone have experience getting into the vent area? I pryed back the fender liner a little and couldn't see a way to access it, but I didn't pull any clips to access. I'm honestly just thinking of leaving it as is...
