jcb
- Thread starter
- #1
This is from a Facebook post by Mr. Brereton. dated 6/3/2025.
Based on my experiences on other platforms and with a lot of prior track time, I think he may be (edited from "is") correct.
The Type R FL5 (what we have) is near perfect. Be mindful that perfect is really hard to achieve...balance is key...with power you need brakes and possibly suspension. Things break if used over specified loads...etc. etc.
And perhaps the most important point - blowing up an engine is very, very expensive.
So what I read - you can tune the car, but be mindful of the needed supporting mods and such...and just maybe get connecting rods if going high hp. (this last sentence is 5/7/2026). Data on what when would be a good thing for the field...sort of if this power then this support....up the food chain...call it stage 1, stage 2, etc. What I am most confused about is the comment about do not wrap the turbo........thoughts?
"Honda Civic Type R FK2 ·
Steven Brereton
·June 3, 2025 ·
Power gains - BEWARE...
Just sharing with you all my thoughts regarding FK2 Type R's and power gains. If this has been done before I apologise in advance, although a bit of refresher knowledge every now and then doesn't do any harm.
Here we go:
1. I've nothing against getting more power out of Type R's K20 C1 engine. Go for it. Done it myself in the past. Have fun and be happy!
2. If you don't, relax as the stock 306 bhp (as much as 330 bhp on some dyno's) is enough for road use and track days. If you can use ALL of that power on the road much of the time, head straight to a track, win races and become rich/famous. You have what it takes you lucky bugger.
3. Honda's engineers who designed the Fk2 Type R are very clever and talented at what they do. They are the masters of engineering balance. So in the FK2 Type R we find the wheels/tyres suit the suspension and intended use, ride quality is a superb compromise for road and track use, the car is stable up to its maximum speed, the braking is appropriate for the speeds the car is capable of, the bodyshell has just the right amount of stiffness for nipping down to the shops with the family or doing a 7 minute 55 seconds lap of the 'Ring (dream on Steve...), etc., etc., etc. It sounds easy to achieve this kind of engineering excellence but it's anything but. Chuck in something like big power to this carefully crafted balance of high end engineering and real world usability, and you are asking for trouble. It's a bit like the human body - works great when everything is nicely balanced and in a steady state as god (I think) intended. But start filling it up with beer every day and...
4. The K20 C1 engine is superb BUT it's not bomb proof like Honda's absolute classics such as the mighty K20 A2. By today's standards, the C1 is pretty rugged, but as we are not in the 1990's for example, that's no great accolade. Thanks to engineers having to chase ever tighter emissions regulations and bolting on turbo chargers onto just about everything, modern engine's are more stressed and just not as tough as they used to be.
More power will compromise the K20 C1's longevity. I know that's a gross over simplification but I hope you can see where I'm coming from. This is not the place to present a thesis on modern engine design.
5. American tuning shops have found that the stock conrods are at their limit around 400 bhp. Go beyond that and sooner or later the rods will let go big time destroying the engine.
6. More power = more heat. No way round that. So avoid wrapping your car's turbo and SIGNIFICANTLY upgrade the cooling system at the same time as you remap/boost airflow, dump the cat, change the cams, fit a bigger turbo, etc.
7. If you don't do any cooling upgrades and wrap the turbo, boost power, etc. be prepared for head gasket failure and/or cracked/warped cylinder head. Or worse... In the K20 C1, the extra heat has to go somewhere and it seems to always make a B-line for the cylinder head. It doesn't help that the K20 C1 engine is a direct injection type so there's no real intake manifold with any heat absorbing capability. Head it is then.
8. The K20 C1 is VERY tuneable with 1000 bhp easily obtainable.
BUT, be prepared to spend a fortune getting the C1 engine and ancillary components into a state where they can survive making anywhere near this kind of power. If you don't have that fortune, forget it as it will only end in tears.
9. When in doubt, cool first power gain later.
10. One way of going faster is by not having to slow down for corners. Try suspension and braking upgrades. They work, are more long lived and cheaper than chasing big power gains. Forget top speed or sub 4 second 0 - 60mph. If you want to be frit senseless, try taking corners you know really well 20 mph faster than you usually do... An hour of doing that - sideways through corners, tyres fighting for grip, suspension flattening corner speeds, etc. - gives you one hell of an adrenalin rush!!!
Hope this helps and saves a few K20 C1 engines along the way."
Steven Brereton
·June 3, 2025 ·
Here we go:
