Integra exhaust
Type Gts R
Juan Li
Seattle Aa
2023 Fl5 R
Also I will note this video was from a few weeks back. The car is currently tuned with hondata flash pro with a tsp tune. That further increase exhaust tone.
TypeRGirl
Leslie
Atlanta
FL5, na 88 RX7
This is with the fuse pulled. Mid resonator deleted. For comparisons sake for when I remove the front resonator as well.
? Sounds really good! This was before the Hondata & tune? Do you have an intake?
edit: nvm, I went back and saw you have the Pipercross intake. Nice ?
lilDumpsterRat
LA
Rs3, S3
is the exhaust manifold on the ITS the same as the CTR?
probably. but what about the downpipes on both are they identical?
RUNN1N
Yes to the downpipes, the ITS exhaust has one less resonator resulting in a deeper tone, but is about 5” longer, so modification would be needed to install it on the FL5.
The DE5 exhaust alone will not get you pops and bangs, that’ll require a tune… but it’s also worth keeping in mind that you can get the pops and bangs with the stock FL5 exhaust + tune.
Correct now with the ecu flash plus a resonator delete you can basically mimic very closely the Type S exhaust note.
