mujoa
Germany
Civic Type R FL5
So my car has pretty much been a rattle fest for the past couple of days. I found three sources of noise and (hopefully) fixed them. I used electrical tape, paper tape and 1mm thick felt tape as well as plastic pry tools for removing trims.
1. Rear view mirror and camera housing
I identified the first rattle coming from the rear view mirror housing thanks to @TypeRGirl. I took it apart, including the larger plastic bit of the camera housing. You can watch the first couple of seconds of this video to see how:
I noticed that the clips holding it where kinda loose on their own so I took them off and put some tape underneath, which fixed them in place.
11th Gen Honda Civic Interior noises - rattles, creaks, squeaks! clips
Then I applied some black tape all around the edges of the plastic housing behind the mirror. I cut it so it's not visible when put together. This seems to have stopped the rattling coming from there.
11th Gen Honda Civic Interior noises - rattles, creaks, squeaks! rvm_housing
2. Center display
I noticed occasional rattles coming somewhere from the center of the dashboard. I put my hand on the display and it stopped. I let go and it started again. Then I found this thread describing exactly that issue:
https://www.civicxi.com/forum/threads/center-console-infotainment-and-glovebox-rattle.51626/
You can find a PDF in that thread with instructions on how to fix it. Apparently it's a TSB for the 2022 Civic but I decided to try it on the FL5:
https://www.civicxi.com/forum/attachments/mc-10211106-0001-pdf.231608/
Essentially, you need to remove the display and place some felt tape underneath it. To do this, I removed the dashboard center trim to reveal screws holding the display. I watched the start of this to see how the center trim is removed:
Be careful here. I put a small dent in the foam around the trim while doing this. In retrospect, it might have been possible to get to the two bottom screws with a wrench from the top (when you remove the plastic cover behind the screen) without removing the whole center trim. You don't need to unscrew them completely since the screen can slide off once you loosen them. I did it the way it was described in the PDF though. There are two more screws you have to unscrew from the top behind the screen though. After that, the screen is only clipped at the bottom.
You can disconnect the hazard lights switch as well as the start button if you need more space, but do not disconnect the climate controls. I figured if I don't disconnect it, I won't need to do step 6. in the PDF "Do the climate control unit Self-Diagnostic Function with the HDS" (and to be honest, I'm not exactly sure how to even do that). The AC has been working fine once I put everything back, so I guess it worked.
The red circles is where you need to apply the felt tape (not yet done in the picture). There is already some on it but apparently not enough. Make sure it's not visible after you put the screen back. The PDF shows exacly how much and where to apply it.
11th Gen Honda Civic Interior noises - rattles, creaks, squeaks! ts
Once I added the felt tape and put everything back together, I also decided to put some felt tape on the back of the display where it connects to the plastic cover. I used the front camera of my phone to look behind the screen since it's hard to see back there:
11th Gen Honda Civic Interior noises - rattles, creaks, squeaks! back_of_screen
Not really sure if this was necessary, but it made me feel better. So far, no more rattles coming from the screen.
BTW: Really make sure that your rattle is coming from this exact place before you decide to do this, as all of my rattles sounded like they were coming from somwhere in the middle but really weren't. It's quite tedious and you might break/damage/scratch something.
3. Plastic trim in the passenger side footwell
While driving over bumpy roads, especially in R+ mode, I noticed a rattle that sounded like it was coming from somewhere inside the dash again. I was able to reproduce it in my driveway by lightly bumping the dash with my fist and found that the noise is coming from the passenger side footwell. There is a big plastic trim down there around and behind the knee airbag. I took it out (it's clipped so just yank it a bit) and placed felt tape all around the edges. It's quiet now.
I didn't take pictures of this but it's relatively straight forward.
It's a longer post but I hope it helps out someone out there. The reason I did all of this myself is that I really don't trust the dealers around my area. If you're satisfied with yours, by all means let them do it ?
For now, everything seems quiet the way I expect it to be. Hopefully it stays that way.
@mujoa Nice, comprehensive, post. I also like your approach with adding extra felt here and there. It certainly doesn’t hurt anything and it’s better to just do it while you have stuff already taken apart. Great work, and well in advance of fall (cooler weather) when I and likely several others will really dig into some of these things.?
mujoa
Germany
Civic Type R FL5
Thanks! Yeah I wasn't holding back on the felt tape. I'd hate it if I had to take the interior apart again ?
TypeRGirl
Leslie
Atlanta
FL5, na 88 RX7
? Fantastic write up @mujoa, thank you! I commend everyone’s determination to locate and correct these rattles, you gotta have nerves of steel to pull these panels apart ?
For now, I’ll just keep praying to the car gods that the rattles go away when I press on them lol
simmic9
Sydney, AUstralia
FL5 Type R
Is the buzzing when I accelerate in the last few seconds of the video the wastegate rattle?
IsaiahGF
Foxborough, MA
CW 2023 Honda Civic Type-R
I am getting a buzzing noise around 3.5K 4K RPMS coming from the headliner right above driver seat. Stops when i press on the headliner and starts again if i let it go. only happens at that RPM. any one else experience this?
No, but I’ve had this happen in other vehicles where the headliner was simply not clipped in in a couple of spots from the factory. All I did was hit it with my fist in various places and the clips popped-in. There’s no need to hit it hard. They’re just plastic clips that pop into some slots. Give it a try.
atucker80
Aaron
Cincinnati
24 Civic Type R, 2022 Mustang GT CS, 2025 M240i
I get it occasionally. Sounds like its coming from center near the light, but I can't really isolate it to confirm. However, as I've put more miles on the car it seems like its happening less frequently.
fredzy
PA
Sienna, GR86, TourX
The car seems to have some pretty high energy vibration go through it in this engine speed range. I'm fortunate not to have any problematic interior rattles yet but the plastic skeleton that hangs from my rearview mirror basically dances a little jig in that RPM range from the vibration coming through to him.
Seems like only a matter of time before that vibration works up some rattles. I've never been bothered much by rattles.. hopefully I can stay that way.
IsaiahGF
Foxborough, MA
I tapped the headliner a few times and pushed on the plastic housing behind the rearview mirror and it went away.
TypeOne
Baton Rouge
Type-Rs!
I hear a serious rattle from the front screen or behind the glovebox area... it sucks because i don't want to take my dash apart to mess with it.
UJX
Missouri
2023 Honda Civic Type-R #2479
Anyone have any rattles from the rear hatch panels? Granted, this only started when I put on a AWE Track exhaust, but that exhaust drones so bad that I’m surprised my entire car isn’t rattling.
Only happens at certain RPM ranges on decel. The hatch light cover is tight, all panels seemed tight. Thinking maybe the subwoofer grill… anyone else have the same issue?
—EDIT—
The rubber things on the rear hatch struts were loose. I rotated them and tightened them, took it for a spin, and no noise. So if you get the loud ass AWE Track and get an awful buzzing from the rear, it’s the little rubber bump stops on the hatch struts.
There's also a common problem with AWE (at least the Touring exhaust) where it can rub up against the heat shield and cause a rattle.
I am currently experiencing a rattle that only happens at a certain RPM/resonance. I thought it was the heat shield but turns out it is coming from inside the Touring muffler. Most likely a broken internal weld. I've contacted AWE, hopefully this will get resolved.
RUNN1N
Just out of curiosity, if an exhaust is rattling against the heat shield, am I correct in assuming the heat shield would need to be trimmed back to correct the issue?
UJX
Missouri
Depends which heatshield. If it's the one at the very rear near the muffler, your muffler might be too far back and might need to be moved forward. Not sure about the rear heatshield but the other heatshields can be bent a little bit with a pry bar so it doesn't rub up against the piping.
I guess as a last resort you could either remove the entire heatshield or trim away parts of it.
wrxdev13
Atlanta
Same here but only on rough roads. On well paved roads with no imperfections, there is no rattle.
