OEM Oil Filter and Oil Drain Plug Crush Washer Part Number
K20C1CTR
United States
What is the part number for the OEM oil filter and oil drain plug crush washer?
Based on my research, the part number should be the ones below. However, when I typed them in the official Honda OEM parts website, it said that the part numbers below do not fit my vehicle. Any advice? Thanks in advance.
Oil filter - 15400-PLM-A02
Oil drain plug crush washer - 94109-14000
UCF120
Jon
Orlando,FL
All Honda oil filters and drain plug washers are the same except for the s2000. I went to my local Honda dealer asking for a Type R oil filter the other day and that’s what they told me.
K20C1CTR
K20C1CTR
United States
Thanks for confirming that.
UJX
Missouri
2023 Honda Civic Type-R #2479
Sorry for bumping this old thread but does anyone have a part number for the oil drain bolt?
Is it 90009-R70-A00?
Yes, that should be the correct part number. I think it may be closer to $10 on other sites. I just ended up spending a few more dollars and bought the magnetic drain bolt from Spoon.
11th Gen Honda Civic OEM Oil Filter and Oil Drain Plug Crush Washer Part Number 1721003807016-ds
  • Like
Reactions: UJX
MC BumSlap
J
North Bay, CA
'24 CW CTR
Sorry for old bump. What is the correct PN for the Spoon magnetic drain bolt?
And why is the Spoon oil filter recommended?
I've used Purolator and/or Wix filters in almost all my vehicles and motorcycles for the last 20+ years.
Use this part number for the oil filter instead, 15400-RTA-003, it is harder to find but it is a higher quality filter.
PNEUMA
Jerry
PNW
2025 FL5
Save your money, the type R comes from the factory with a magnetic oil drain plug
edit, no magnetic plug from factory. I forgot I previously installed one.
ctechauto
They do not. :)
Highly recommend the Votex magnetic drain plugs. They are full stainless steel and the aluminum ones on the market tend to strip and eventually break even with careful torquing habits.
15400-PLM-01 oil filter made by FILTEC is the best of the bunch but good luck finding them. Your best option is to use the 02 or 03 filter and change it along with the oil every 3-5K miles.
11th Gen Honda Civic OEM Oil Filter and Oil Drain Plug Crush Washer Part Number IMG_2431
