Oem PS4S tires and chunking
Monkey_Luck
Jeremy
Apex NC
2022 Honda Civic SI
Has anyone else had an issue with their PS4S's with inaide tread chunking? My tires have 17k on them, no track days, no auto-x and just street driving. They all still have 6/32 remaining.
11th Gen Honda Civic Oem PS4S tires and chunking 20260627_110451
11th Gen Honda Civic Oem PS4S tires and chunking 20260627_110355
11th Gen Honda Civic Oem PS4S tires and chunking 20260627_110349
11th Gen Honda Civic Oem PS4S tires and chunking 20260627_110340
11th Gen Honda Civic Oem PS4S tires and chunking 20260627_110311
11th Gen Honda Civic Oem PS4S tires and chunking 20260627_110306
Yeah definitely curious what's going on here. ^Cold temps and at-the-limit driving would be a culprit but I'm leaning alignment as well.
Not 100% clear from the pics but is this just one tire? That would at least point to a tire failure but if it's happening on more than one that's environmental.
MoodySara
New England
A couple of people have mentioned cold.
That's what it looks like to me, too. Was it cold out when you first saw this, like below 40°?
  • Like
Reactions: jcb
ModJPB
Jason
Usually when I've seen customers with tires like that are for several reasons.
1) driven regularly on sharp edged rock or brick roads/driveways.
2) aggressive driving on summer tires in cold winter.
3) tire tread separation from rubber that did not cure properly when manufactured.
PS4S usually have a 30k mile warranty. If this happening on all four tires you should get a proration credit (a little less than 50% $ towards another Michelin/bfgoodrich tire) if you claim it as "tread separation". Bring it to a tire center and they will contact Michelin.
Monkey_Luck
Jeremy
Apex NC
2022 Honda Civic SI
Hello,
It is just one tire having the issues. I do drive in cold temps but dont drive hard at all. By cold i mean in the 30's.
MoodySara
New England
Tire Rack's Advice
Can I Drive Summer Performance Tires In Cold Temperatures?
Can you? Or, should you? The simple answer is — no you shouldn't. Summer performance tires are simply not designed for near- or below-freezing temperatures. Here's a quick explanation of why.
Summer performance tires feature tread rubber compounds engineered to provide traction in warm to hot temperatures only. As temperatures drop into the 40s, a summer performance tire's tread compound changes from a pliable elastic to an inflexible plastic, drastically reducing traction capabilities. The tire industry calls this process the "glass transition." And, without traction, your vehicle will have a hard time staying on the road!
In fact, should summer performance tires even be exposed to near- or below-freezing temperatures, tread compound cracking or tread block chipping can occur. Once a tire has been damaged in this way, it will need to be replaced. And, as both types of damage only occur as the result of improper use or storage, they will not typically be covered by the manufacturer's warranty.
So, to recap — don't drive summer tires in the cold! Save yourself the headache of an accident or damaged tires, and transition to All-Season or dedicated Winter tires in the Fall - before cold weather hits.
Hello,
Contact Michelin. Probably just a faulty tire.
zymmer4
Howard
West Virginia
You have driven these ps4 Summer tyres in sub freezing temps..You might attempt to claim a faulty tyre, but please don't tell them that you used these Summer tyres in the freezing winter.
You drive these ps4 tyres in sub freezin
thatonedaveguy
Dave
Texas, USA
24' CW Civic Type R #18788
Hello,
There's your issue right there. These tires should not be regularly driven or rather driven at all in temps that cold.
JoeFabs
Joe
Upstate NY
FL5, EG hatch
If it's the passengers side front tire, check your alignment. I'm guessing there's a lot of toe out in the front. Under compression/as the suspension settles, it will toe out in the front. Set it to zero toe.
These tires should have no problems in any weather other than ice/snow or serious track laps.
  • Like
Reactions: jcb
