Type R Spring Track Day - May 24-25, 2025 VIR
Which Track/Date?
  • Total voters
  • Poll closed .
Vtec87pr1
ANTONIO
VIRGINIA
i should had stayed and ride alone with you but i was so tired i was falling a sleep driving home.
Vtec87pr1
ANTONIO
VIRGINIA
Looks nice and smooth. Getting a couple point by's too!
my instructor was very happy with my driving he really liked it. i just need to practice more the point by i kept making mistake on the first straight pointing to the left instead to the right. and some times ppl gave me point bys really late i decided not to take the point bys.
J1Avs
James
Seattle, WA
www.instagram.com
I cooked a set of Carbotech XP20s in one day. Removed my front brake dust shields and my backup set of pads (Endless MX75+) lasted Saturday and Sunday.
I was cooking them with the shields on.
If you are cooking pads with your dust shields on you should be considering different pads and evaluating your braking habits.
svvitch
svvitch
Ben Thorn with a 2:06+ in @PointByPatrol car
@yeaitsahonda with a 2:10.7 in a fully stock FL5 on 660s
everyone else just doing work to be better
? First time vir and first solo in like 20 (ouch I'm old) years ? times were recorded and I beat my goal time.
Djseto
@PointByPatrol had the same issue in the past. My braking habits are pretty solid for this track now. I’ve logged over 1000 miles at VIR over the last 5 years. The XP20 is a very aggressive track pad. It was 12mm to start and after one day, about (6) 25 min sessions, I was down to 6mm driver and 5mm passenger. This is with vsa and tcs off (type r mode + long press).
The two straights at VIR can get to 135mph+ and they require hard braking down to 45-55mph. I don’t drag my brakes but I do trail brake into a few corners but on the straights, I do brake late and hard. As soon as the shields came off, I had zero issues and more consistent brakes all weekend with a “lesser” pad in the Endless. ?‍♂
J1Avs
James
Seattle, WA
www.instagram.com
@PointByPatrol had the same issue. My braking habits are pretty solid for this track. I’ve logged over 1000 miles at VIR over the last 5 years. The XP20 is a very aggressive track pad. It was 12mm to start and after one day, about (6) 25 min sessions, I was down to 6mm driver and 5mm passenger. This is with vsa and tcs off (type r mode + long press).
The two straights at VIR can get to 135mph+ and they require hard braking down to 45-55mph. I don’t drag my brakes but I do trail brake into a few corners but on the straights, I do brake late and hard. As soon as the shields came off, I had zero issues and more consistent brakes all weekend.
VIR is a former home track for me - I have quite a few laps there as well ?. What lap times did you run this past weekend?
XP20 is a suboptimal pad. This is far too much wear, and it’s paired incorrectly with the braking system if you need to remove the shields.
I’d recommend some other options if you are open to something different than Carbotech.
Djseto
Ah. Good to know. My last time out in Nov of last year my PB was a 2:15.5. Friday I was in the 2:17's knocking off rust. I set a 2:13 by end of day Saturday after being mostly consistent in 2:15s. Sunday, I was 2:14-2:13s all day if there was no traffic.
Def looking for your take on this: Last year I ran Carbotech XP12 front and XP10 rears. After 2.5 days, the XP12's were down to maybe 30% left. I was NOT happy as I expected better life. Rather than miss a half day, I bought a set of Endless MX72+ from a guy who had them new in box for like $100 just so I could finish my day. They were OK but I didnt love them.
This year, I called at brake guy I got my XP12 from and I talked to Mike at Carbotech. Both said I should have gotten more life out of the XP12 but said this time I should try they XP20 as they should last 2x longer and were only $20 more than the XP12 (I got the fronts for $260). After Fridays session, I was pissed at the wear. I called my brake guy and he couldnt make heads or tails of it and neither could @PointByPatrol. I was having dinner with some of the guys and one of them (I can't remember his handle here) mentioned the brake shields. I told @PointByPatrol later back at our AirBNB and he agreed that was it. He assumed I had pulled them off and I didn't know I had to remove them.
I'm all for trying a new pad but I do feel like I didn't give the Carbotech's a fair shake if this was truly the issue. There are a few instructors and endurance guys I know who swear by Carbotech. The being said, the Endless felt pretty good. I couldnt quite go as deep but they never gave out like I remember them doing last year. That being said @yeaitsahonda was running 2-3 second faster and he was the only one faster then me with a similar setup (stock engine, 200TW tires) but he's running counterspace garage pads that cost significantly more and blanks vs the OEM 2pc. @PointByPatrol runs an AP Racing BBK so his car and pace isn't a close comparison.
I am all for trying a new pad next time. I went with Carbo based on recommendations and because I am able get a 10% discount. I also run their 1521 street pad so keeping the same compound made switching pads easy as there was no need to rebed anything.
I am back at VIR for 2-3 days in Sept.
