marcusm86
Marcus
Missouri
2025 Civic Type-R
So not sure if anyone had any issues with the RV6 bypass valve getting stuck and causing a CEL, but i try to contact them for a solution and or a replacement and they just brushed me off asking me to do all these vacuum test making me buy additional tools to perform the test. Even while i showed them and explained that the bypass valve had a delay opening up under vacuum, they said it’s functioning. Short story the piston either has debris in it or was not properly greased when assembled. But i moved away from RV6 and went to a new brand that I cam across on the Net. Here are some sound clips, and best of all it comes with 3 spring strength S-M-H… that no other brand is offering. I’m not promoting in any way shape or form. Just want to share with those looking to bet better BOV sound from their intake and turbo. Here’s what it sounds like on my PRL P700 pushing 535whp. Sounds should be similar on stock turbos and upgraded turbos as well, Spring strength will determine pitch and duration to some extent. I’m currently on the Medium spring, rated @ 15-23lbs. Couldn’t be any happier with the results and sound.
what bypass valve did you get? or what did you end up replacing it with? sounds great man
zumbooruk
Ventura CA
Thanks for the feedback. I went PRL because the consensus seems to be that it's not too extreme compared to other options, but interested to see if I can feel much difference at all given your experience.
same reason I did
And I believe that It is the only one with EPDM rubber bushings
  • Like
Reactions: MrB
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
Nearly stock baseline dyno on 93 octane. The only “mods” are an MXP exhaust with the stock downpipe and front pipe, plus the TSP coupler between the stock intake and inlet. Do either of those make a difference? Bare minimum, if anything. It was also a nice, cool 46°F day, so conditions were definitely favorable.
We’ve been using Tuning by Nick’s Dynojet for a number of years now, and DRob has remote/live tuned our cars on this same dyno. The numbers have always been consistent with what the cars would make on Derek’s dyno if we made the trip down, so I don’t really have a reason to say this dyno reads high. The car just made a little more than I expected. Maybe that comes down to the favorable weather, with a small contribution from the minor mods mentioned above.
Either way, the actual number isn’t the most important part. What matters is having a clean baseline to compare against once the engine upgrades start going on. We’ll likely be back 1–3 more times depending on what stages the car goes through.
11th Gen Honda Civic What did you do to your FL5 today? IMG_5225
11th Gen Honda Civic What did you do to your FL5 today? IMG_5232
11th Gen Honda Civic What did you do to your FL5 today? IMG_5243
TheFactor
Factor
So Cal
2025 CW Civic Type R
Mounted a Bride seatbelt holder... now to jump on the highway to test drive it. Gotta make sure that the install was done correctly :)
It only took me Two Type R’s to train myself to follow the belt back so it didn’t drag 😳
hongda
Daniel
Wisconsin
'25 FL5, '26 Passport Trailsport Elite
All I did was wash her (Drivelab stuff is great, btw, first wash, already turning more heads than normal).
Honestly just killing time for 2 more weeks til the Hondata ECU unlock event in Chicago (I'm in Wisconsin).
Weather is nice, having fun one bendy road at a time.
11th Gen Honda Civic What did you do to your FL5 today? 20260502_115619
2025 FL5 Civic Type R
I keep seeing ads for Drivelab on social media and was always curious if it actually worked as well and as quickly as they say it does.
CafeApex
AZ
2025 BB FL5
Bit the bullet and treated myself for finally graduating college after waiting far too long. Ordered the 18x10 +40 ZE40 M-Spec wheels from @lmtlsauto
Now the search for tires begins as the one thing I’ve admittedly never really researched that hard. Also need to order some good lug nuts and I’m assuming hub centric rings.
11th Gen Honda Civic What did you do to your FL5 today? IMG_5492
