The Tuned 11th gen Experience & Reliability Thread (for all models)
Dan_E26
Dan
Columbus, Ohio
Did a bunch of little maintenance items over the weekend. Engine and cabin filters, tire rotation, spark plugs, oil change, put EVEN MORE GREASE IN MY GODFORSAKEN CLUTCH FORK to keep it quiet and smooth
Here's what my spark plugs looked like after 60K miles, 9k of which tuned! I thought they looked decent but I don't really know what red flags on spark plugs look like beyond being burnt to hell or super sooty.
11th Gen Honda Civic The Tuned 11th gen Experience & Reliability Thread (for all models) IMG_0922
Gapped the new plugs down a smidge to 0.028. Unsure if that will really do much for me since I rarely ever use Map 3, but it's what all the cool kids are doing so I'm doing it too
Anyway, time for more reliability updates:
Total tuned time: 5 Months
Tuned miles driven: About 9K (went back and checked my maintenance notes, had more miles than I remembered!)
Tuning device(s) used: KTuner V2
Tunes used: Phearable 1.5R
Fuel used: 93 octane
Additional related mods: PRL HVI, Remark Link Loop exhaust, ARP Head studs, RV6 FK8 Retrofit Clutch kit, 27WON RMM, SiriMoto clutch damper valve delete, Swift springs with SPC camber arms, FL5 Rear swaybar
Problems/issues: None whatsoever.
Driving style: Highway commute (30-35 miles each way) with frequent WOT pulls, road trips, and autocross in the warm months
Tuning experience notes: This tune is so fucking good.
2025-Si
2025 Civic SI
How do you like the fl5 rear sway bar, and do you wish you had gotten something thicker instead?
Dan_E26
Dan
Columbus, Ohio
It does exactly what I wanted it to, which is: It makes it significantly more neutral during heavy cornering in autocross. You can even induce a little lift-off oversteer! I don't wish I got anything more aggressive because there's no need to make a FWD car super tail happy IMO
2025-Si
2025 Civic SI
Thanks!
Where did you source your FL5 sway bar from, and was it a straight swap or did you have to get additional parts for the install?
Dan_E26
Dan
Columbus, Ohio
Thanks!
IIRC I got it from a fella on reddit who swapped his swaybar off his Type R. Direct fit, no modification needed.
danielbl
Daniel
CA
2023 Civic Si, 2021 Civic HB EX
'23 Civic Si
Tuned miles driven:
4,388 (+324 miles since the last update, 32% of total miles)
Current mods: N/A
Current tune: Hondata 240 CARB
New issues: N/A
Tune experience notes: :headbang:
'23 Civic Si
Tuned miles driven:
4,557 (+169 miles since the last update, 32.5% of total miles)
Current mods: N/A
New issues: N/A
Tune experience notes: I haven't driven much lately, but the tune still rocks. The car feels like it's tied to an anchor when left in Normal drive mode. Hondata Mode in Sport drive mode makes a difference.
xxBodom
Arthur
24' Civic Si
Vehicle: 2024 Civic Si
Total tuned time: 14 months
Tuned miles driven:
15,000+
Tuning device used: KTuner V2.0
Tunes used: TSP Stage 1 (1 year) Drob etune (2 months)
Fuel used: 91 octane
Additional related mods: 27won gin (journal bearing), 27won 4bar, 27won CAI, 27won FMIC, 27won downpipe, prl front pipe, Magnaflow exhaust, Rv6 fk8 retro w/ exedy stage 0 clutch kit, inline pro head studs
misc - 27won snorkel, 27won FSTB, garage line 20mm spacers eibach lowering springs, prl rmm
Problems/issues: Clutch started feeling like crap after 1 year of living in TSP Stage 1 map 3 tune with frequent pulls and spirited driving. Eman said the head gasket had some wear (did proper head stud w/ new gasket and noticed some wear during install not the 1by1 method.) Spark plugs are good for another 10-20k miles. Clutch was shot
Driving style: Pulls here and there with some occasional spirited driving on highway/canyons
Tuning experience notes: The TSP stage 1 tune definitely woke the car up a bit. It actually was not fun in map 2-3 in city traffic for me personally. Outside of traffic it was fun but could still feel room for improvement.
If you intend on tuning your car please be prepared for an eventual clutch/head job to be done.
Custom Etune Drob - I added the custom etune when purchasing the 27won gin turbo with the other supporting parts (clutch, head studs, 4bar sensor). Starter tune for the gin turbo felt great once I was able to get on it after breaking in the clutch, currently on rev2 of the tune and it feels so much better than the starter tune and cannot wait until the tune is complete.
I was unable to find any videos or reviews for the most part of the 27won gin turbo so feel free to reply to this if you want any additional feedback/videos
91 oct tune is complete peaking at 27/28 psi - No issues!
Drob did great and the car has power all the way to redline with some extra pull around 5500/6k rpm? Redlines around 7100/7200 rpm now.
Have added an acuity short shifter (great improvement) Hybrid racing detent springs and acuity shifter bushings, not a huge improvement but somewhat noticeable? I definitely don't feel like I have to force 1st /2nd gear as much when downshifting and feels a lot more smooth.
I'm either going to get it Dyno'd this weekend or picking up a prl flexfuel kit and getting a flexfuel tune.
My guess would be around 270-290whp??? Can still manage 40mpg on the highway and 27~ in the city
pwp25si
2025 si
How is the city driveability with this turbo? Looking at this or the prl one. Does your turbo make the squeaking sound? I've seen some videos making weird sounds. Is that before anti surge revision?
xxBodom
Arthur
24' Civic Si
I have the pre anti surge revision, literally released like a month after I bought mine.
Yes it squeaks LOL. Only when I barely tap into boost though, I've learned to live with it when it happens. I have the 27won cold air intake a mutes most of the turbo except for WOT. Lid off it squeaks in low boost, WOT/20+psi doesn't squeak
City driveability is perfectly fine.
Turbo spools a bit later and sometimes i need to downshift when I normally wouldn't need to in order to pass someone or catch a light. I guess I've adjusted my driving and haven't really thought about that until now.
xxBodom
Arthur
24' Civic Si
*UPDATE
installed prl flex fuel kit and got it tuned. Can run up to e40 but I think the car MAY be performing better on e30
Different tuner, very linear power all the all way to red line capping at 28psi still.
Made 280 on the dyno.
Illinois
2023 Rallye Red Civic Si
UPDATE*
Car is now FBO
Vehicle: 2023 Civic SI
Total tuned time: ~1 year, 3 months
Tuned miles driven: ~14,000 miles
Fuel used: 93 Octane + 1 Gallon E85 sometimes
Additional related mods: PRL HVI, TSP DP, PRL FP, PRL TIP, PRL FMIC and Charge Pipes, PRL RMM
Driving style: Spirited with daily pulls
Issues: Minor clutch slippage has started to happen on long road trips. My LT fuel trims have been creeping up when idling around 0.08 - 0.10. At first I thought it was tune related but I believe it could be a boost leak.
UPDATE*
Did the headstuds in my garage around 3k miles ago.
I switched over to 5W-30 at 30k miles, now at 33k
Total tuned time: ~2 years, 7 months
Tuned miles driven: ~30,000 miles
Tunes used: TSP Stage 1+
Additional related mods: PRL HVI, TSP DP, PRL FP, PRL TIP, PRL FMIC and Charge Pipes, PRL RMM, ARP Headstuds, Acuity Short Throw Shifter, 27WON Intake Snorkel,
Issues: Minor clutch slippage still occurs when accelerating hard from <3000 rpm in gears 3-6 otherwise, no slippage at all. LTFT still creeps up to 0.10 when idling for a while. It has to be a vacuum leak, but I cannot find it to save my life.
Other notes: Car has treated me great since new, never had any reliability issues, and I hope it stays that way lol. I love driving this car every day, so much fun.
xxBodom
Arthur
24' Civic Si
*UPDATE
Tune is not good.
Getting retuned by Drob at IMW and will hopefully get over 300 on a Dyno. Will update once done.
