Improved Racing CCS Catch Can
Been using the Improved Racing CCS for a few years now, had it previously on my 23 Sport Touring. When I traded it in, I made sure to hold on to it and just recently installed it on my FL5. Works great, easy to install. So much easier to service it compared to others. I had a Mishimoto catch can on my 10th Gen and that thing was a pain to service. I had to practically uninstall it and use a vise to remove the can.
Sooner1
Adam
Kansas City
I second that the Mishimoto can is a pain. I have to remove the 3 tiny bolts and remove the unit to emply. Impossible to unscrew the can while it is mounted. It is only a matter of time before I lose one of those tiny bolt/screws.
jedi03
aaron
new mexico
2025 integra type s
how much oil is captured and what are your intervals for draining it?
phothrottle
phothrottle
Phuong
2023 honda fl5
That is the online debate and my thought process is i would rather be provactive than reactive. There is no harm in adding a catch can, just a bit more work for maintenance but I'm ok with that.
Spart
2025 Integra Type S
This is a really good design for maintenance. It reminds me of the UPR can I had on my GT350 with the quick disconnects. Very OEM-quality and easy to service!
I am very curious to see you report back with how much oil is actually collected. The consensus on these engines is that a catch can just isn't necessary. It certainly was on my GT350, I still have a roughly 1/3 full bottle of oil that I recovered from that car's passenger-side catch can.
tc0566
Jim
Canton, Ohio
2025 Honda Civic Type R
I have this can and guess what, as usual they used 3/8" lines. You can't use a 5/16" clamp on a 3/8" hose. So now they can either replace them with the proper 5/16" or I am returning it. At $300 I shouldn't have to buy parts to make it work. If you put 3/8" hoses on 5/16" fittings you will have a vacuum leak and your car will run rich. Seems like every catch can maker does this and I have gone through this with multiple vehicles. Also this one does not have a check valve and you should really use one.
timestamped
DC
I found this t-bolt clamp that is a perfect fit for the molded collar around the vacuum port on the intake manifold:
11th Gen Honda Civic Improved Racing CCS Catch Can IMG_2236
11th Gen Honda Civic Improved Racing CCS Catch Can IMG_2237
I used the wormgear clamps supplied for splicing in a check valve:
11th Gen Honda Civic Improved Racing CCS Catch Can IMG_2228
timestamped
DC
btw I have had the Mishimoto and was always able to twist off the bottom while gripping the top with my other hand. Then have to pass it between hands to get it out which can be a little tricky, but yea I didn’t remove the entire can:
11th Gen Honda Civic Improved Racing CCS Catch Can IMG_2231
In the OEM configuration, it is simply a straight hose connection between two points (out from the head and directly into the intake manifold). Under boost conditions, it would make sense to add an inline check valve so pressure from the intake manifold does not pressurize the head at the same time.
Thoughts as to why Honda did not simply include a check valve between these two hose connection points to reduce/prevent pressurizing the head while under boost? Why not just close off the intake manifold connection entirely and simply add a breather filter on the head connection itself?
I really like the design/functionality of the Improved Racing CCS but don't understand why a check valve was not included for this particular installation location. On a related note, has anyone used this particular catch can on the other intake side to catch oil vapors that would otherwise be reintroduced into the intake track? I have not heard of anyone on this forum talking about that aspect where for example a drain cock or weeping hole would be needed on the lower section of the intercooler to drain.
