Clutch helper spring delete
ChrisLe5512
Christian
Ontario, Canada
2023 Acura Integra Elite A-Spec (6MT)
This is for the FL5 owners, which is why I posted in the FL5 sub-forum. Don't try this if you have an Si unless you want to be a guinea pig like me. Your clutch is different.
Thank you for sharing your data-backed experience in such detail. I read up on this a lot last night and watched your related video, and I think I’ll be the guinea pig with my Integra A-Spec 6MT this weekend, seeing as no one seems to have tried it on their Si or at least posted about it anywhere. I’ll report back for my Si/A-Spec folks and we’ll know once and for all. Worst case I take out the clutch pedal assembly and put it back in… I love tinkering with my car anyway ¯\_(ツ)_/¯
I took the helper spring out, knowing that I am taking a risk that I will not be able to easily put it back.
I really like the clutch feel without it.
Coming from FA5, I always felt that the clutch on the FL5 was too mushy and lacking feeling.
I can definitely notice a bit more effort, still seem softer/easier than the FA5, and feels more "natural"
ChrisLe5512
Christian
Ontario, Canada
Can confirm this works for our cars as well! Just pulled the helper spring in my Integra A-Spec last night, the two sides were pretty simple but I fought with the center notch for a solid half hour… really gotta push in the right direction else you’ll just rotate the spring, plus it was a struggle working down there and keeping the area lit without knocking down the light source. Anyway, very much worth it. No more feel than stock, gonna have to delete the clutch delay valve for that (soon!), but pedal pressure is indeed much more linear and feels great. No more artificial engagement halfway through pedal travel, and can confirm the pedal comes all the way back up without issue. Thanks again to OP for sharing! Very worthy free mod for all K20 and L15 6MT’s 👌
I'm asking you to argue a conditional hypothetical in support of your subjective opinion that clutch pedals feel better when they're less linear. I didn't insinuate that you ever said that a heavier helper spring would be better, what I'm saying is that if less linear clutch pedals feel subjectively better to you than more linear ones, then it follows that a heavier helper spring than stock would make the clutch pedal feel subjectively better than stock by decreasing the linearity.... unless you have some argument to the contrary that somehow doesn't contradict your previous statements?
11th Gen Honda Civic Clutch helper spring delete 1786849772912-8r
some people like the stock clutch pedal feel and you like it with the deleted spring. not sure why this has to be a debate. it's personal preference.
I love the way it is already. don't want to f with it. considering it's hard to put back in, I don't think i will participate in this experiment. I can barely fit my head under there anyway.
Just FYI, for my FL5, after releasing the two sides, I was feeling around the center and the spring just fell out, kinda surprised me.
Sporky McGeuschky
Sporky
Central Texas
Admitting you like the feel of the clutch pedal better either before or after helper spring removal:
Subjective.
Admitting you have a huge head:
Priceless.​
Spart
2025 Integra Type S
Hey homie, this post explains how to do something.
It doesn't require you to reply to year-old posts, and for the SIXTH time in the same thread, that you personally don't want to do something.
Just don't do it and move on.
Seriously, sick of it, get the f out of my notifications.
You're on the ignore list now.
Spart
2025 Integra Type S
Hey do you all want to know something absolutely hilarious?
For me and my Big Ass American Feet, the throttle pedal in these cars is just too light. Particularly when you enable the modes that give you fun exhaust sounds, because they alter the throttle mapping at the same time. Just really hard to modulate at slow speeds in first gear without the car bucking a little bit, and then any time I didn't use the cruise my shin would cramp up from literally holding my foot up and off the throttle.
It's just sprung too lightly, and they use the same pedal in the base Civic all the way up to the CTR/ITS. I assume the torque available per unit distance of throttle pedal travel is a lot higher in the CTR/ITS, but they had to make the pedal for the mass market cars first and foremost.
ANYWAY, I went to the trouble and effort of purchasing a stock Civic/Integra throttle pedal assembly for R&D work. I figured out how to disassemble it. Analyzed the size of the concentric spring seats. Figured out the spring rates of the two factory springs as well as the free lengths. Did a bunch of math to figure out suitable replacements, with the goal of a 25% increase in pedal weight. Ordered a bunch of different springs. Landed on the most suitable replacement. Did before and after measurements, and I came out at a 23.9% increase.
Shot a bunch of video of the whole process.
Pedal has been in the car for 11 months now and it's awesome.
And I never posted on here about it. You know why?
The first nine replies would be from regarded individuals saying something to the effect of "why it's good like it is."
On a forum where people come to look for info about how to modify their cars.
I'll probably get banned for saying this, but THOSE PEOPLE NEED TO BE FORCIBLY STFU'D.
thatonedaveguy
Dave
Texas, USA
24' CW Civic Type R #18788
Just practice a little more. No need to disassemble the clutch for what is essentially a skill issue. Screwing with the shifting experience on a Honda is like replacing steak with tofu.
HKSpeed
FL2 6MT
I'm really interested in removing the clutch helper spring, but I'm concerned whether doing so will accelerate long-term wear. The OP stated this mod is common among Mustang owners, so I Googled it. I discovered companies sell spring upgrades. The product description concerned me about removing the spring.
Many new Mustang owners have found that taking out the stock OE spring will give you somewhat similar results, but realistically the clutch becomes far too heavy especially if your Mustang is daily driven. Most owners fail to realize the prolonged effects of simply taking out your factory OE spring and not replacing it with another spring. By negating your factory clutch assist spring you will notice chatter/NVH from your clutch pedal. Your clutch pedal will never fully return to stock position without any assist spring, and over time your slave cylinder may begin leaking due to constant pressure on its seals from the clutch pedal not returning to the stock position. Avoid these problems in the future by installing our Steeda S550 Mustang Clutch Assist Spring 35 lb/in into your GT, EcoBoost or V6.
Obviously Mustang and Civic transmissions are different. I wish I could easily swap or reinstall the helper spring.
I want to increase tactile feedback in the shifting experience. That's why I swapped in a Hybrid Racing shifter (got it before Acuity released one), cable bushings, Wunderladen RMM, and replaced the stock clutch stopper (kinda like this mod). I tried Hybrid Racing detent springs for 6 months. I removed them because they made shifting too notchy in combination with the other mods. I'm considering removing the helper spring, plus a CDV delete and clutch damper delete.
From 2001 to 2017 I daily drove manual transmission VWs, Nissans, and Toyotas from the 90s/00s. When I bought my Civic new in 2024 (my first Honda), I was disappointed by the spongy clutch. I analogize my Civic's clutch pedal feel to wearing thick-cushioned shoes (like Hokas) versus thin soled shoes (Chuck Taylors).
My favorite shoe for driving and weightlifting because of the tactile feedback.
11th Gen Honda Civic Clutch helper spring delete 1788448222277-jo
I removed my spring a few weeks ago.
I have not notice any chatter nor clutch not returning to stock position.
I also have Hybrid Racing short throw shifter, bushings, PRL RMM, and clutch pedal stopper (rubber disk off Amazon, since I did not like the hard plastic stopper)
I adjusted the clutch pedal travel to eliminate most of the free play at the top
As a test, I increased the free play a bit to see if the clutch pedal comes back all the way up
I pressed down just a little bit with my finger till all the free play slack was gone and released.
I tried it about a dozen times, and each and every time clutch pedal returned all the way up.
HKSpeed
FL2 6MT
Is this how you adjust your clutch pedal? A and B shown in step 1?
11th Gen Honda Civic Clutch helper spring delete 1788465203031-7s
Yes and no...
Same bolt, but adjusted by feel, to minimize free play.
I never measured the height...
I just measured the height from floor to middle of clutch pedal, about 160mm 212mm from "tab C"
The clutch pedal as is, after I increased free play a bit, is fairly high, and I hit the top of my knee on the steering wheel. I would not want it any higher
note that in my car there is no insulation to pull or remove. nor could I feel any "tab"
the insulation is about 10mm
update, I measured wrong.
originally I measured where the ruler and clutch pedal made a 90 degree angle down to the carpet.
I now found more images, and located "tab C"
When measuring to "tab C" the ruler is nearly horizontal, and the measurement is 212mm
