XDI or Full Race HPFP
jmheath357
Phoenix, AZ
2025 Honda Civic Type R
Update on my fuel system install, pasted from another thread. This is the summarized version:
We had a few questions on the XDI HPFP flex line that got answered along the way. Both ends of the line are identical, it's rated across all fuel types (including ethanol, race gas, methanol, even hydrogen in motorsport use, though XDI doesn't publicly advertise fuel compatibility to protect their manufacturer’s IP), and 3 1/2 threads engagement into the fuel rail is normal, hand-snug is really all these need before a final wrench pass.
Install came back together clean, checked every fitting before first start, no leaks at the HPFP, and it settled into a smooth idle after the initial crank cycles as expected. Idled 15 minutes with no codes, then took it for a shakedown drive on the basemap with no inconsistencies.
Logging is now underway for DRob ahead of the dyno. Got a 60-mile drive in with the 15-minute steady cruise and WOT 3rd-gear pull from 2000rpm both logged, still need to recapture the 15-minute stop-and-go (FlashPro missed it twice) and the cold start/idle log (FlashPro missed this as well 😬), planning to grab both tomorrow. Full tune on Shell 93 and Ethanol is expected in the next 1-3 weeks.
Hey, just as a heads up. You may or may not know or maybe cleared this with Derek first, but typically you have to record all 4 of those logs back-to-back directly after uploading the tune on the same drive cycle. They are not supposed to be done separately on different days as the ECU will have already gone through it's learning process and it won't be accurate data being sent back to Derek. I know the ECU's are different between the Accord and the R, but his instructions are the same for both so I'm sure the same principles apply. When having my Accord tuned by him I had asked this exact question and this was his response:
Me: "Why is it that you ask to drive the car/perform the datalogs immediately after flashing it with a new tune and not drive it around any first? Just curious."
Him: "I need to see the ECU learn fuel trims and monitor the behavior of knock control movement. If I don't see it happen, I can't make changes that affect them accurately."
So you would likely need to reflash the ECU again and do all the logs in the same drive cycle as he asks for, unless he told you otherwise of course.
And those missed logs are exactly why I would also recommend doing the logs with your laptop connected to the Flashpro and record from there. That way you can see for absolute certain you are actually recording and there won't be any issues there. I was worried about missing logs too so that's what I decided on doing so that can't happen. Plus, you won't have to download them from the Flashpro since they will already be on your computer so it's one less step too. But if you really just don't want to carry your computer around when recording, hold you hand under the Flashpro and you will see when it's not recording the blue light will have a short fast blink and when you are recording it will be a slow longer blink. Just some tips if you weren't already aware. Ignore me if you were aware. lol
Looking forward to seeing how everything goes on the dyno!
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
I missed that in the memo!
I went out again and got those done as requested by Derek, let's hope that he gives me the green light to head to the dyno now. The last time I did street tuning was back in 2022 with my FK8 and stock fuel system with a Kuro; I didn't enjoy it then, I don't enjoy it now 😅
When I added the Hondata FS in 2023, it was straight to dyno tuning and in 2 hours we achieved what took to get done on the street.
The funny part is, I've had my computer on the passenger seat for each log, and the datalog button on the FlashPro Manager software was more inconsistent. I now press Datalog on the FlashPro itself, wait to see that the Orange light is cycling ON/OFF every few seconds. My new rev limit is 7650rpm, that's as far as I could go in 3rd yesterday with the beeping screaming at me. I didn't hit a fuel cut off wall, but it certainly seemed to slow down at that.
jmheath357
Phoenix, AZ
I hear ya on that. I'm currently doing a street tune with him on my FL5, and he did my Accord a couple of years ago too, and I didn't enjoy the process either time. It takes an enormous amount of time to go through a full tune that way at least without paying for priority, (2.5 months on the Accord and 3 months so far on the FL5) and that whole time you are having to drive around on a partial tune which I'm not a fan of. Next time I get tuned by him (after upgrading my turbo) I'm going to do it on a dyno and just knock it out in one quick shot. I've always done street tuning to save money, but I'm kinda over it at this point. lol
SKINNIE
DFW TX
ISF, 23' BB FL5
Did you say you're 3 months in tuning sending in logs and revisions?
jmheath357
Phoenix, AZ
Damn! lol
Yeah...lol
It's ok though as I'm not actually driving the car much at the moment and it's worth the wait to make sure my car is tuned properly by one of the best tuners out there for this platform. But next time I'm just gonna pay the extra money to do it on the dyno.
Sweet…Been waiting for this and ordered.
mike_99gsx
Columbus Ohio
2026 Integra Type S
I was holding back from posting on this subject but I had the Full Race failure happen to me as well (on the track). I have had the pump on for about 10 months. No issues on the street. But as I replaced motor mounts and starting tracking the car is when it happened. In both cases at the track, I had a couple "stumbles" through hard turns and ultimately limp mode and codes for fuel pressure like others have described.
Smell of gas getting the car back to the pits. I was very fortunate that nothing stupid didn't happen to the car.
My line is one of the previous generations and did not have the vibration clamp. Nostrum was responsive when I called them saying that a new pipe is developed with an improved radius to the rail (and obviously) adds the clamp. I am to receive that tomorrow.
I also saw the 4 Piston announcement today and ordered that one. Honestly, the soft line approach feels better to me. But I think I just want to hold both in my hand and make a decision.
jmheath357
Phoenix, AZ
I'm tempted to order one right now but I also think I might let everyone else guinea pig it first since I won't actually need one for a while. Super curious to see how these work out though.
