m3bs
- Joined
- Mar 14, 2025
- Threads
- 6
- Messages
- 110
- Reaction score
- 142
- Location
- South Carolina
- Vehicle(s)
- 2023 CTR, 2016 GT4
GT4 to FL5. No regrets.
the fl5 seems to be quite easy to work on.. this is dangerous once you start upgrading parts imoI have zero problems working on my vehicles. I’ve done everything from suspension work to replacing clutches, to changing differential gear sets, wiring. You name it I’ve done it. Trucks, sports cars, new and old. I’ve had it all!
I owned a 987.1 Cayman S similarly to yours for about 4 years. You're spot on regarding the CTR being more refined being 20 years newer. The Sport mode in the CTR is about the same as activating the PASM button on the 987.1 Cayman S or my stock suspension on my 981 Boxster Spyder and GT4 (Normal mode) which is perfect for me to daily. The 200lb weight disadvantage of the CTR is offset by the additional power and torque compared to your Cayman S. I find that the CTR also handles better given the 20 year newer suspension setup. The same goes for the transmission. The CTR transmission is the next best transmission that I've driven with my Boxster Spyder being the best.I have zero problems working on my vehicles. I’ve done everything from suspension work to replacing clutches, to changing differential gear sets, wiring. You name it I’ve done it. Trucks, sports cars, new and old. I’ve had it all!
The Cayman is pure sports car. Loud. Bumpy. Glorious.
I have a feeling a near 20 year newer Civic type. R is going to be a bit more refined than the Cayman.
But even if it’s not, that’s OK. I like that experience. I’ll swap in the Integra control module to have some additional comfort. I like adjustable drive mode. I came in has the sports suspension so at the push of a button, I can stiffen it up as well.
I’m pretty much 100% decided on the type R. I’ll list my Cayman for sale probably next week and I assume it was all relatively quick. I won’t be asking much for it so somebody should get a pretty good deal on a pretty amazing sports car
I owned a 987.1 Cayman S similarly to yours for about 4 years. You're spot on regarding the CTR being more refined being 20 years newer. The Sport mode in the CTR to be about the same as activating the PASM button on the 987.1 Cayman S or my stock suspension on my 981 Boxster Spyder and GT4 (Normal mode) which is perfect for me to daily. The 200lb weight disadvantage of the CTR is offset by the additional power and torque compared to your Cayman S. I find that the CTR also handles better given the 20 year newer suspension setup. The same goes for the transmission. The CTR transmission is the next best transmission that I've driven with my Boxster Spyder being the best.
Good luck with the search and I'm partial to Championship White![]()
Love the video! Amazing how much a front wheel drive has improved over the years. Funny, it seems like the Porsche driver was falling asleep until your friend came up on him the first time, then he started pushing it.Here is my friend at the track. It's his modded GT4 RS going up against my modded FL5:
