Battery tender installation
vbb
vj
FL5 Type R
Searching for some wise counsel on how to install a CTEK battery tender. In particular, there are some conflicting views on whether you should connect the negative eyelet to the chassis as opposed to the negative terminal on the battery. Is there a definitive view on what the best approach is? thanks in advance.
Rhorn
BRZ, Civic Type R
I do it on the chasis just because with how the battery terminals are on my Mustang its easier that way
Reading around, it seems that connecting the negative to the chassis is indeed the better/safer way to go. If the battery is removed from the vehicle, that’s when you want to use the negative battery terminal. Thanks for bringing this up. Learned something new.
UJX
Missouri
2023 Honda Civic Type-R #2479
I have always hooked them up to the terminals in my cars and never had a problem. What is the advantage of using the chassis?
Safer = Less chance of sparks at or near the battery
MYK20C1
Jim
Chattanooga
2021 type R SGP; 2018 Clarity Touring
Chassis will never be wrong
vbb
vj
FL5 Type R
thank you!
