EVS BALL JOINTS OR WHITELINE BALL JOINTS FOR CAMBER?
I've been considering dropping back to a less aggressive camber. I do really like the way the car drives but if I'm chewing up tires every 5k miles that is too extreme for my tastes.
The thing is, these ball joints don't really offer a huge amount of precision in adjustability. You get 1 degree increments; for the EVS at least, I can validate that the "least aggressive" setting leaves you at OEM, then you get -1 and -2. That's it... so if I'm at -1.5 at the OEM setting (after Eibach Pro-kit springs), then I have the option of -2.5, or -3.5. The other option is to pull the strut tower pins, which is a ghetto version of adjustable camber plates... which is what I actually want and will eventually move to. I feel like an almost full degree of camber would hurt the way the car rotates during autocross, which is my primary use case. I want to try -3 but can't get there with my current amount of adjustability.
Especially if I can get any validation from folks on here that have tried the roll-center adjusters on this platform. I have yet to find ANYONE with them installed so zero testimonials to go off of. I don't want to re-architect my suspension mods on a hunch.
I'd definitely recommend roll center adjusters on a lowered car, but I'm still at stock ride height, and have no plans to change that.
Understood- but as far as I'm aware you get either the choice of adjustable lower ball joints OR roll-center adjusters. Unless I'm misinterpreting what the roll-center adjusters are- effectively elongated lower ball joints. I think I've seen on other platforms they incorporate elongated outer tie-rod ends as well but I haven't seen that for this platform.
Would be nice if they offered an option of adjustable elongated lower ball joints amirite?
I agree. Still a lot of parts to be desired for our platform! I'm currently looking for a vent to atmosphere catch can, and I'm having zero luck. I'd make one myself, but I'm admittedly unfamiliar with how the CCV and PCV function on this car.
REDRAGN
Matthew
Gainesville, GA
2019 FK8
mattrose4
mattrose4
chicago
2023 civic type R, 2013 sti
Yea I have a roll center correction kit and bump steer correction on the sti. I have thought about going back to stock springs actually but I want to test the waters and see how much understeer I get, but from what Ive seen the fl5 has really good lift off oversteer. I am curious about doing -2.8 instead of 3.0 camber though 🤔
I think prl posted about something like this the other day, though I'm not clear on if it's vent to atmosphere or just a normal catch can
REDRAGN
Matthew
Gainesville, GA
2019 FK8
IIRC, youre running a 4piston engine too. Have you had similar issues with increased blow by? Do you vent to atmosphere?
I vent the "to turbo inlet" to atmosphere...long black silicone hose from valve cover going behind airbox in pic. I run the Radium PCV catch can.
11th Gen Honda Civic EVS BALL JOINTS OR WHITELINE BALL JOINTS FOR CAMBER? IMG_1617
I really never have had much blowby at all. But plenty of other issues :p
Ball joint pic for relevance. Installed Feb 11th and Failed June 15th after 2 TA races and 1 track weekend. But zero issues in the last 2 years!
11th Gen Honda Civic EVS BALL JOINTS OR WHITELINE BALL JOINTS FOR CAMBER? 66630202395__8A8FAD5F-7F88-405F-8609-EEA97CF7957C
11th Gen Honda Civic EVS BALL JOINTS OR WHITELINE BALL JOINTS FOR CAMBER? IMG_2394
And one small fire in between...
11th Gen Honda Civic EVS BALL JOINTS OR WHITELINE BALL JOINTS FOR CAMBER? IMG_1952
mattrose4
mattrose4
chicago
Holy fire! glad you're safe! This is my biggest fear on all my project cars.
NKOTB
David
Atlanta, GA
Replica 1965 Shelby Cobra Roadster, Jeep JKUR, Lincoln MKT Ecoboost
Fellas, I’ve seen written answers, but I’m hoping one of you that may do this often could post up a video of how you adjust the plates with pins after installation. I’ve got an alignment guy that was having a devil of a time with my type R. He’s a solid BMW track/ race suspension guy, but I don’t think he’s ever done a Type R with the Whiteline Performance ball joints with the camber shims. He essentially took it down to the knuckle to get the shim plates moved. I know there’s simpler way to make this adjustment from messaging with our Type R club, and I’m understanding that I/he should be able to just loosen the bolts below the shims and move them over, but I’m thinking there’s some sequence, pry bar, other bolt loosening action that I’m missing in translation that a video would illustrate. Appreciate anything I can share with him the next time around. Thx!
