**FL5 Cluster in '24 SI?**
ayospoonay
Josh
Orlando
2022 PWP Si
Dang! Any leads to get another? Part number? Or did you find it on eBay?
Shankmeyster
AZ
23 Type R
I found a used Canadian Si gauge cluster and it's on the way. I reached out to odo-pro.com and they said they should be able to reprogram the mileage. Updates to come.
If they can actually reprogram a used cluster that will be a game changer for us in this thread and the other one.
Xcelent
Xcelent
Biter's Garage EST. 2018
'24 SI, 93.5 Toyota Supra
you have to repin wire 13 (light blue) to 6 on cluster, and type r mode will activate if grounding that pink (type r) wire you said (light blue in si after swapping 13 to 6) . however, the type r drive mode connector is 10 pin and the si is 8 pin. you'd have to repin the connector or cut and solder. you can also add a separate button somewhere for the auto idle stop button. it seems europe type r's have the r button and idle stop button may just need to add a wire between r button and cluster. wires run straight to cluster by the way.
Rob any chance you have the wireless charger Diagram from a 2023 Type-R? I do not want to pay again for that 1 diagram on Honda's wiring site. Any chance you could snag that if you have access
ayospoonay
Josh
Orlando
2022 PWP Si
Does this help?
11th Gen Honda Civic **FL5 Cluster in '24 SI?** 1708530495930
Xcelent
Xcelent
Does this help?
That is 100% of what I need! Thank you!!!!
I installed a FL5 on my '24 Si. I got the MiKStoreShop plug-n-play harness though. I am installing one on a customers car this weekend and no plug-n-play harness so I want to ensure I wire it per the factory requirements, circuit amperage etc.
I must have accidently not grabbed that diagram.. I have almost everything else for the '23 type-r and '24 Si..
Xcelent
Xcelent
I need to get pictures for everyone. I wanted to let everyone know how it is going so far with the cluster. Besides loving it so much, it works perfectly. The alert for ADS is so simple to just scroll and bam it is gone. I can't tell you how much I dislike the OEM Si cluster, the pixels, the lack of full screen just ruin it for me. When I take calls while driving into and from work, it even displays the Outlook meeting name on the cluster. I love the small details. The yellow needles are nice too...
Anyhow I paid 400.00 on ebay for a used cluster with 674 miles I would never go back tot eh SI cluster. I may throw the cluster online for sale or just keep it.
I will however be selling my SI door cards soon since I upgraded tot he TYPE-R with ambient lighting. I also added the OEM lighting to the flooras well : ). Creature comforts....
NH
23 Civic Si
Would you be willing to just sell the red cloth front door inserts? If so, I'm in.
Also, do you have any tips for accessing the gauge cluster?
Xcelent
Xcelent
So hoenstly I do not think the inserts just come out - their supersonic plastic welded jsut like the type-r door panels.. So I will be selling as a whole unit 250.00 each panels they have 1500~ miles on them.
And what do you mean about the cluster getting a new type-r one or?
NH
23 Civic Si
How were you able to remove the stock gauge cluster? I'm assuming the upper steering column cover is removed and that provides access to some retainers or clips?
Xcelent
Xcelent
Both trim panels have to come off (the vent ones) then two screws on top of the cluster come out, lower the wheel, remove bezel, bezel hider, 43 screws to the cluster and two connector, dont forget that the harness attaches dont he side of the cluster too, pop that push pin out
