Flashing CEL but no trouble codes
FL5ghost
Charles
Tampa
2023 civic type r
After trying to diagnose the cause of misfire codes in my car, my tuner adjusted the fuel trims, and the issue seems to be resolved. However, I recently noticed a flashing CEL without any trouble codes. What could be the cause? Is it just a random occurrence? My car is FBO/upgraded turbo with an Xdi hpfp and 1400cc injectors.
11th Gen Honda Civic Flashing CEL but no trouble codes IMG_7428
11th Gen Honda Civic Flashing CEL but no trouble codes IMG_7430
11th Gen Honda Civic Flashing CEL but no trouble codes IMG_7429
FL5ghost
FL5ghost
Charles
Tampa
2023 civic type r
A blinking CEL signifies a misfire, even if there’s no code showing. It could have been a temporary misfire and didn’t register the P0300. If it doesn’t happen again, maybe it was a fluke.
It's happened twice before and no codes but prior it happened to P0300-P0304 codes would pop up.
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
19 Sport
possible software error. visit the dealer.
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
19 Sport
Dealer isn’t going to do anything with those upgrades. I’d probably say visit a reputable shop.
It was implied to return to stock, might need an ecu.
Could be possible. I had to have my head unit replaced 3 weeks into ownership.
perfect example.
ABPDE5
New England
2024 Integra Type-S
Aren't DI likely to misfire if pushed too hard? Check w. another tuner, maybe IMW, Jester, Phearable -- someone who has a lot of experience with this platform, and share logs w. them.
Higgs Boson
Texas Hill Country
are you running colder plugs and mostly driving around normally on the street?
could be injectors, injector install issue, injection timing issue, injector characterization issue, etc
altering the airflow model to change fuel trims probably wouldn't be the solution.
