jbrown552211
Joseph
Cleveland, GA
2022 Civic Si
U guys are lucky i gues! I just uploaded dual tune 21psi in sport mode and 18 in normal and saw slippage in 4th gear at 3k at 21psi so figured il swith it to normal at 18psi nd after some driving ive noticed same slippage even at 18psi. Again 3-4k rpm in 4th-5th gear probably 80% throttle. Crazy how some r fine and some arent.
Same. I’ve already bought a clutch.
kanav
Kanav
Toronto, ON
2022 Civic Si Black
Don’t go 80%+ throttle at 3k rpm, downshift or roll into the throttle so by the time you are 80-100% throttle you are past 4k rpm
Car must be driven a bit differently on the stock clutch, once you change the clutch then go wild lol
ValkenDnB
Luis
Civic
This. Roll into your pulls and gradually apply throttle. Don't just mash the gas. You want to be WOT after 3500 basically. It's a turbo car not a naturally aspirated one so it's a little different.
Dopenutz
San Diego
22 civic si
Theres a 23psi map. On the original post they said they would post the dyno results at a later date. Ive read the thread and looked online and cant find any info on it. I just wanna see how it compares to their e85 tune.
ValkenDnB
Luis
Civic
You’re actually right. Email Drob and ask him or ask tsp. I’m actually curious how much that makes considering 21psi makes ~240wtq
BKJ7
Brandon
GA
2022 Civic Si SGP
Did Ktuner remove the option to see battery voltage on the Ktuner V2? Everything else seems to be there except battery voltage.
11th Gen Honda Civic KTuner 2022+ Civic Si Tune Results - Fantastic Gains! 20230110_213351
11th Gen Honda Civic KTuner 2022+ Civic Si Tune Results - Fantastic Gains! 20230110_213400_2
Shingo_Shoji
Max
Rochester NY
2023 Civic SI
Any reply on this?
Dopenutz
San Diego
22 civic si
Any reply on this?
They did run it but there was slip on the stock clutch so they didnt post any results. Im assuming it must be more than the flex tune 21psi map since that one didnt see slip and those results did get posted. Mine holds 23psi well so far after a couple months of use.
Shingo_Shoji
Max
Rochester NY
2023 Civic SI
Same here! Im 400-600 miles in on the 3rd map with no slippage, just more so curious what the dyno result is on the map 3 25psi tune
BKJ7
Brandon
GA
2022 Civic Si SGP
I emailed TSP support asking if the 241whp/286tq is the Map 3 (25psi) results and they confirmed it is.
"That's correct the numbers would be for MAP 3 which is for our tune. The MAP 1 & 2 are reserved for the tunes that come with the KTuner itself."
