Spying on you?
Xmetal
CTR, S3
I haven't read through the entire 9 pages, but is there any usable function(s) that we're losing if the TCU is removed? For example, update notification, etc... I don't subscribe to anything and I don't use the Honda Apps.
PNEUMA
Jerry
PNW
2025 FL5
Really no reason to remove it in my eyes. Just unplug and place connectors to the side after wrapping with some sort of anti rattle insulation or foam. You won’t be getting any sort of OTA updates. My car runs fine so I don’t feel a need for an update if there was one released.
Need to go to the shop? Plug the connectors back in and go there. Disconnect or reconnect, either operation is five minute task.
JMO and other owners will have theirs
I do not recall if I removed it or just disconnected the TCU, but in over four or five months, I have seen no ill effects.
I do check updates manually every so often using a USB thumb drive and the Honda website
https://usb.honda.com
ThunderPigeon
Long Island
Everyone is so programmed to update everything all the time. If everything is working fine what do you need updated?
Depends on the update.
Checking for update does not mean that I'll apply it.
I will review the release notes, evaluate any fixes and added functionalities (if any) and then make an informed decision.
Same as for any other system: iOS, MacOS, Windows, router, ham radios, etc, anything with firmware, and apps too.
ThunderPigeon
Long Island
Must be nice to have that kind of free time. Who is looking at a monthly cumulative Windows update weighing the pros and cons of installing it?
I treat an internet connected system very differently than one that isn't. My Internet connected devices update regularly and usually on their own, including apps. Unlike most consumer software these days, which is released half finished and patched to 100% as they go, the car is expected to be released in a working form. I'm sure if there was a safety issue, they would issue a TSB and update it at the dealer for you. Just doesn't seem important enough to spend the time on.
I do not weigh pros and cons myself, I look at "expert" reviews, but only for major updates. not weekly/monthly updates. sorry I was not clear.
Sporky McGeuschky
Sporky
Central Texas
Today is Sporky's 1 Year Anniversary.
Gave Honda a full year of data.
I have no excuses to wait around any longer.
It's time to stop.
Done.
11th Gen Honda Civic Spying on you? 20251206_114634
You're welcome, Honda, for the free year of data. Now leave me alone.
Cheers.
Sporky
PNEUMA
Jerry
PNW
2025 FL5
Help me understand why the complete removal of the TCU? Is it for weight savings?​
Sporky McGeuschky
Sporky
Central Texas
Not for weight savings for me. I suppose it saves a few ounces by removing the module, if someone really needs that weight reduction.
I put my TPS Report module in a ZipLock bag so I can tuck it away in a bin with other unneeded OEM parts, like the rear windscreen wiper.
Put it in... Time Out ... if you will.
PNEUMA
Jerry
PNW
2025 FL5
Yeah I’m good with my choice to unplug. My car runs, looks, operates just fine without being connected. I’m not paranoid, yet I am comfortable with my decision to not share data.
In about 3 minutes I can pop the cover off without damage, and reconnect the plugs if need be.
I do t need an OTA update, nor a monthly vehicle health report from Honda telling me how nice my car is. YMMV
Yesterday, I bought a new 2026 Passport TSE (built date in 01/2026) to add to the garage. It is powered by the new Google/Android head unit and has a larger display. Responsiveness is very snappy as compared to the current CTR. I really like the updated interface even though it is running Android 13. Fobs are also individually configured for settings that is a bit different. From what I understand, the new Google/Android head unit will be used in the 2027 CTR.
I mention this simply because it appears like Honda has been trying to work with tech companies like AT&T to figure out how to use the TCU as a means to offer "connected vehicle" services. When the 2026 Passport was released, this thread on another forum noted issues with the TCU connection.
Quite frankly, I am glad to learn that Honda is having issues with the TCU "connected vehicle" implementation since it makes it easier for the owner to simply disconnect without having the TCU embedded with other systems on the CAN bus (e.g., Chevy OnStar integration that has been used for decades).
That said, the TCU as mentioned in this thread is easy to locate and disconnect without issue on the CTR. On the 2026 Passport and Pilot, they use an updated TCU part number however, it is not as easy to access for disconnection.
