The Tuned 11th gen Experience & Reliability Thread (for all models)
pwp25si
2025 si
Are you maxed out on fueling? 27won stated 300hp range easily. Sounds kinda low. Makes me yhink i should just save up and trade in for fl5.
Yeah it should. Regret being impatient and getting it tuned from someone else
xxBodom
Arthur
24' Civic Si
Tuner said I'm capped on fueling but I don't believe him or I am and the tune is super off.
Should be able to be around 310-330 maxing out fuel.
I thought about trading in for the Type R but not only is it more expensive, all the aftermarket parts are as well.
Plus ill take my miles per gallon lol
On my 91 tune I could still get 40mpg on the highway if I stayed below 3k rpm
pwp25si
2025 si
Dyno could just be reading low. Its not always about the numbers. Do you have a dragy?
danielbl
Daniel
CA
2023 Civic Si, 2021 Civic HB EX
'23 Civic Si
Tuned miles driven:
4,557 (+169 miles since the last update, 32.5% of total miles)
Current mods: N/A
Current tune: Hondata 240 CARB
New issues: N/A
Tune experience notes: I haven't driven much lately, but the tune still rocks. The car feels like it's tied to an anchor when left in Normal drive mode. Hondata Mode in Sport drive mode makes a difference.
'23 Civic Si
Tuned miles driven:
4,794 (+237 miles since the last update, 33.7% of total miles)
Current mods: N/A
New issues: N/A
Tune experience notes: 🤗
danielbl
Daniel
CA
'23 Civic Si
Tuned miles driven:
Current mods: N/A
New issues: N/A
'23 Civic Si
Tuned miles driven:
5,334 (+540 miles since the last update, 36.1% of total miles)
Current mods: N/A
New issues: N/A
Tune experience notes: Avg. MPG post-tune is 32.3 vs. 31.4 pre-tune. Found that interesting.
chopsuey34
West Michigan
2025 Civic Si
Vehicle: 2025 Civic Si
Total tuned time: 1 hour
Tuned miles driven: 38 miles
Tuning device(s) used: KTuner V1.2
Tunes used: Phearable 1.5R
Fuel used: 93 octane
Additional related mods: PRL Intercooler
Problems / Issues: None
Driving style: I drive like THIS
Tuning experience notes: So far, so good. I took it out after tuning and kept it calm for the first 30 minutes per the instructions so k.con could normalize. In normal mode, I noticed a better turbo response and pulling power, even at partial throttle. Once I started flooring it, I really noticed the additional response in Individual mode. The engine feels less restrained, more spicy than stock. PSI gauge was hitting 16psi a lot more frequently than stock so the tune is working.
Quality of life improvements like no start-stop are great. Not sure how I feel about the higher 6,800 rpm limit. It's cool, but dealers can read how many times engines overrev. Ack, my warranty, why did I do such a thing?!?
As I put miles on the car and get comfortable with the tune, I'll post updates. I like to drive my car aggressively, so I'll be staying in Map 1 exclusively so I can avoid clutch and head gasket issues as much as possible. I never was able to find specific reliability stats for someone who remained in Map 1 for the long term, so I want to run that experiment: does driving a car hard in Phearable 1.5R Map 1 affect reliability?
Tuning is really easy. I used the included Phearable instructions and this youtube video (Tune Your Honda Civic Si with KTuner (Step-by-Step Guide) by Dale Does Stuff). Make sure to have your battery on a trickle charger or go for a long drive before tuning! You don't want to run out of juice mid-tune and brick your car.
Addition: Phearable states that anything under 25% throttle positioning doesn't activate the tune, which means daily driving is unaffected by tuning. I can feel the surge in power when opening the throttle from 24% to 26%!
xxBodom
Arthur
24' Civic Si
Should start saving/looking into clutch and head studs. Anything over stock is going to deteriorate your clutch much much quicker and head studs YMMV but intend on getting it done. And if you're going to milk the stock head studs to see how far you can make them last, when you upgrade your head studs have them done properly and not the 1b1 method
pwp25si
2025 si
Tuned miles driven: 15k miles
Tuning device(s) used: KTuner V2
Tunes used: phearable 1.5r
Fuel used: bp 93 octane
Additional related mods: PRL Stage 1 intake prl intercooler/charge pipes
Problems/issues: None
Driving style: nothing crazy.
Tuning experience notes: knock control solid at .48 .49. Fuel trim solid at around 0. plugs changed at 32k miles. Plan to change every 20-25k. Headstuds soon maybe? How long will the clutch last? We'll find out.
danielbl
Daniel
CA
'23 Civic Si
Tuned miles driven:
Current mods: N/A
New issues: N/A
'23 Civic Si
Tuned miles driven:
6,050 (+716 miles since the last update, 39.0% of total miles)
Current mods: N/A
New issues: N/A
Tune experience notes: Avg. MPG post-tune is 32.9 vs. 31.4 pre-tune.
xxBodom
Arthur
24' Civic Si
Don't need to change plugs that quick, inspect them for sure but I think that might be overkill for a OTS tune.
My clutch started going out after 10k (total 19-20k) miles or so after running map 3 daily. Never officially went out but was close.
My head gasket had some wear as well when I replaced the clutch. If your car is new the 1b1 head stud method should work. If you ignore doing head studs then when you do be sure to actually get it done the proper way and not the 1b1 method
gtman
gtman
Mitch
2017 Cosmic Blue EX-L Sedan
The first page stats are now up to date.
It's amazing how slow this thread is in terms of tuned cars added compared my OG thread at CivicX. Mind boggling.
Dan_E26
Dan
Columbus, Ohio
Fuck it, another update:
Vehicle: 2023 Civic Si
Tuned miles driven: 12k miles
Tunes used: Phearable 1.5r
Additional related mods: TSP ARP headstuds, RV6 clutch kit, PRL HVI, Remark Exhaust, bunch of suspension stuff not worth mentioning in a tuning thread
Problems/issues: None whatsoever.
Driving style: Daily driving, WOT pulls multiple times a day, every day. Autocross a few times a year, hopefully actually getting on track sometime this year, but who knows
Tuning experience notes: Every now and then, my K.Con will climb seemingly unprovoked while cruising on the highway, and then go back down to 0.49. I am currently playing around with the early spool setting in the KTuner menu, even though I was told by John Vega on FB that they don't recommend it. I honestly can't feel much of a difference, but I like the idea of the car bit more responsive to my pedal inputs. Anybody have any insight/opinions on early spool?
chopsuey34
West Michigan
2025 Civic Si
Didn't know Vega didn't recommend it. I'd like to know opinions as well.
