[Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S
Christian/AWE
Horsham PA
FK8 Type R
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S awe_email_header_product-release-forum
Air superiority. Presenting the AWE S-FLO Carbon Intake System for the Honda FL5 Civic Type R & Acura DE5 Integra Type S, now available:
Learn more, right this way...
S-FLO SYSTEM:
  • Modular two-piece intake system featuring a carbon fiber airbox and carbon fiber turbo inlet tube
  • Components can be installed independently or paired together as the complete S-FLO system
  • No tune required
  • Dyno-proven max gains of 20 hp and 16 lb-ft of torque at the wheels with 91 octane software (complete system)
  • Genuine 2x2 carbon fiber construction with UV-stabilized resin and clear coat
  • Utilizes factory mounting locations
  • Perfect fitment, guaranteed
  • AWE No Check Engine Light Guarantee
CARBON AIRBOX:
  • 85% increase in filter surface area compared to stock
  • Fully sealed carbon fiber airbox and S-FLO Filter combination
  • Precision-engineered 80 mm aluminum MAF housing designed for consistent airflow across the sensor
  • Washable, oil-less S-FLO Filter
  • Integrates directly with factory inlet ducting
  • Compatible with the factory turbo inlet tube or AWE Carbon Turbo Inlet Tube
  • Includes application-specific silicone coupler for factory turbo inlet compatibility
CARBON TURBO INLET TUBE:
  • 39% larger inlet cross-sectional area compared to stock
  • Compatible with all factory-fitment turbochargers
  • Compatible with the factory airbox or AWE Carbon Airbox
  • Machined aluminum turbo flange for long-term durability and straightforward installation
  • Removable aluminum turbo flange and coupler accommodates larger turbos with bigger turbo inlets
  • Includes application-specific silicone coupler for factory or AWE airbox compatibility
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11115_2660-11114_1
THE S-FLO INTAKE SUITE:
The AWE S-FLO Intake Suite for the FL5 Honda Civic Type R and DE5 Acura Integra Type S is a modular two-piece intake system featuring a genuine 2x2 carbon fiber airbox and carbon fiber turbo inlet tube.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S _2660-11114_5_9d78cd9b-4075-4744-be71-6ffbba00b0c0
Each component can be installed independently with its factory counterpart or paired together to create the complete S-FLO system, giving you the freedom to upgrade in stages or go all-in from the start.
With the complete system installed, the S-FLO Intake delivers dyno-proven max gains of 20 hp and 16 lb-ft of torque at the wheels with 91 octane software.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11114_Dyno
No tune required for installation. No Check Engine Light. Perfect fitment, guaranteed.
CARBON AIRBOX:
The AWE Carbon Airbox replaces the restrictive factory airbox with a fully sealed genuine 2x2 carbon fiber enclosure engineered to increase available filter area while maintaining precise airflow through the MAF sensor.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2669-11115_3
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2760-11151_1
At the center is AWE’s washable, oil-less S-FLO Filter, providing an 85% increase in filter surface area compared to stock. Increased surface area allows the filter to support greater airflow while retaining excellent filtration and long-term serviceability.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2669-11115_4
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2669-11115_5
A precision-engineered 80 mm aluminum MAF housing maintains consistent airflow across the sensor for factory-like drivability and reliable operation.
The Carbon Airbox integrates directly with the factory inlet ducting and retains the factory mounting locations for a straightforward, precise installation.
Running the factory turbo inlet tube? An application-specific silicone coupler is included for seamless integration. Moving to the complete S-FLO system? The Carbon Airbox mates directly to the AWE Carbon Turbo Inlet Tube.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2669-11115_6
The AWE Carbon Turbo Inlet Tube increases the available airflow path between the airbox and turbocharger while replacing the factory inlet assembly with genuine 2x2 carbon fiber.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11114_1
With 39% more inlet cross-sectional area than stock, the Carbon Turbo Inlet Tube provides a substantially larger path for incoming air while maintaining compatibility with all factory-fitment turbochargers.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11114_2
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11114_3
A machined aluminum turbo flange provides a precise, durable connection at the turbocharger and is removable by design. The removable flange and coupler architecture allows the carbon tube to accommodate larger aftermarket turbochargers featuring increased inlet diameters.
The Turbo Inlet Tube can be paired with the factory airbox or the AWE Carbon Airbox. An application-specific silicone coupler is included for compatibility with either configuration.
MODULAR BY DESIGN:
Start with the Carbon Airbox. Start with the Carbon Turbo Inlet Tube. Or install both.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2669-11115_7
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11114_4
The S-FLO Intake Suite was engineered from the outset as a modular system, allowing each component to function properly with its factory counterpart while providing a seamless upgrade path to the complete intake.
No redundant parts. No dead-end upgrades. Just a straightforward path from stock to full S-FLO.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11114_5
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2669-11115_12
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11115_2660-11114_6
CARBON, DONE RIGHT:
Both the airbox and turbo inlet tube are constructed from genuine 2x2 carbon fiber and finished with UV-stabilized resin and clear coat for lasting appearance and durability underhood.
Every component is engineered around factory mounting locations for exact fitment and straightforward installation.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11115_1_c7b70973-2fb3-46ce-8b39-5f0fff469cea
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11115_2660-11114_2
NO CEL GUARANTEE:
The AWE S-FLO Intake Suite is engineered to work properly with the factory engine management system without requiring a tune for installation.
As always, it is backed by the AWE No Check Engine Light Guarantee and Perfect Fitment Guarantee.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 2660-11115_2660-11114_4
Christian/AWE
Christian/AWE
Horsham PA
FK8 Type R
that form felt like:
Me: I have a FL5...
Autozone: "Is it 2WD or 4WD?"
Yeah we also need your blood type, mother's maiden name, and the last four digits of your SSN.😂
But in all seriousness, yes the form is pretty broad and does need some updating. Thank you for the (funny) feedback. We are always adjusting and updating our site, so we will look to streamline that in the future.
artsyfartsyFL5
Ant
PA
www.instagram.com
2025 CW FL5
Curious to see what the verdict looks like once it's released compared to the other systems available. I'm digging the dry CF that matches the OEM valve cover.
North Carolina
2025 Honda Civic Type R
whats the filter efficiency of the material/layout for the intake system? Does this require changing the wiring for the waste gate actuator? Eventuri makes you remove the plastic housing.
Christian/AWE
Christian/AWE
Horsham PA
FK8 Type R
Christian/AWE
Christian/AWE
Horsham PA
FK8 Type R
whats the filter efficiency of the material/layout for the intake system? Does this require changing the wiring for the waste gate actuator? [Do] you remove the plastic housing[?]
We increase our filter surface area and overall size to enable higher airflow volume and power gains without compromising filtration quality. This is also the reason we use a box design that takes advantage of the available space to increase power potential by fitting our larger filter.
Our system installation requires no cutting, soldering, or splicing of wires. We do remove and replace the factory hard plastic harness housings. Check out steps 14/15 and 24/25 in our installation instructions (click here).
PrecordFK7
Thom
2024 Integra Type S
So I had a failure of my Infinity design inlet pipe earlier this week with the epoxy coming undone from the flange to pipe and decided to pick up the AWE inlet pipe as a replacement. Figured the separate flange and pipe would help me not having the same issue as the Infinity design. I'm on a time crunch, as I was changing fluids Monday for a track day this upcoming Saturday. Luckily @axion_industries responded to me late Monday night I had my issues and got me the AWE inlet today.
First off the inlet is packaged in a large box incredibly well and safe. Now let's get into the install, first thing I was trying to figure out the order of operations, the included QR code for instructions takes you to the instructions for the AWE Intake, so I googled and found the inlet instructions on their site instead. I went to place the flange with gasket on the turbo and when I went to put the coupler on, I couldn't. Now I have a 27won Kuro+ turbo so maybe the alignment is different, but the metal vacuum line bracket was in the way/line of the coupler. I didn't see any mention on the instructions but there was obviously interference on my car. So I removed the vacuum tube from the car and cut the bracket off and reinstalled it. Okay that worked, so install the coupler, but the way the ring clamp sits, you gotta torque the flange first to the oe 18 lb/ft and then slip the ring clamp on after as you won't be able to get a socket on the bolts to torque the flange. Okay, just a learning curve.
Transfer the OEM rubber locator grommet/isolator over to the AWE inlet pipe but it doesn't stay in place, it's very loose and fell out as soon as I flipped the inlet pipe, so be careful. I slipped the inlet pipe into the coupler with the ring clamp loose and decided I'll tighten it later. I'm using an Infinity Design intake, so I decide to use the included coupler meant for OEM intakes. The alignment isn't perfect between the AWE inlet and Infinity Design intake, but it's very close enough, it's tough when you mix 2 different brands together so I understand and accept it. I go to check the CCV port on the coupler and there's an obvious difference between the 2 provided couplers. The coupler meant for the AWE Intake is sized properly at about 9mm/ 3/8" but the OEM intake coupler's CCV port is a good 12mm+ / 1/2". I did send a message to AWE as there's got to be an error on the included coupler or the wrong one packed in my box. I run a J's Racing T-Rev for my CCV line so I just need to get a 1/2" to 3/8" adapter barb to finalize my setup, but someone running the OEM hard line CCV Tube would be in a situation where they need the proper sized coupler or just hope they're running the AWE Intake.
I'm not trying to bash AWE here, I know this is a brand new product and there's always going to be growing pains with new releases. It just seemed that I ran into a few more obstacles than I expected. Hopefully the coupler for OEM intakes gets fixed and non-OEM turbos with the OE metal vacuum line may need to cut that bracket or bypass the metal tube altogether and just run a vacuum line from the turbo/boost reference up to the bypass solenoid. Either way it looks pretty cool installed and the separate flange-coupler-inlet pipe setup should help absorb shock and not encounter what I did with my Infinity Design inlet pipe.
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 20261116_204003
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S Screenshot_20261119_184253_Chrom
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 20261119_184324
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 20261119_190547
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 20261119_190514
11th Gen Honda Civic [Now Available] AWE Carbon Intake System for FL5 Civic Type R & DE5 Integra Type S 20261119_195236
Christian/AWE
Christian/AWE
Horsham PA
FK8 Type R
It just seemed that I ran into a few more obstacles than I expected. [...]Either way it looks pretty cool installed and the separate flange-coupler-inlet pipe setup should help absorb shock and not encounter what I did [...]
We read through your post. We are happy that you are satisfied with the end result, but, we would like to put you in contact with our Support Team. I am sending you a DM with more information.
