🔴💊 Engine Oil Red Pill Thread: Only Post If You Have UOA - Official Honda Civic Type R K20C1 Engine Oil Analysis
eap35
JPM
DFW,TX
2022 ND2 RF GT
I have been following this thread closely, Currently live in CT, seems like my best bet is to stick 0-20 oil. Currently about 500 miles on the odometer, so first oil change is due, What oil/filter you recommend most for the FL5, based on actual science backed feedback?
Ktrw
Zach
United States
2025 Integra Type S
I don't think anyone has done significant particle count testing between oil filters for our engines, or hardly for any car that I've seen that would help us determine that quantitatively.
I think the answer is that most of the oil filter options you could pick, including the oem Honda filter, are good enough and it's not really worth worrying about. We haven't reached that level of optimization yet and I'm not sure we will unless someone wants to pay for all that testing.
Obviously the best efficiency filter you can get for the relevant particle size (~20 micron, roughly bearing clearance) is optimal, but there are some factors like flow rate, capacity, and longevity that are a bit up in the air regarding what leads to the best option.
I've been running Purolator filters because from the somewhat limited quantative online tests performed with oil filters, it seemed to do a good job in all categories and the build quality is quite good. I'm going to try a Purolator One next time instead of a Boss version because it seems the lower mileage rating relates to a higher filtering efficiency for a shorter OCI and I run fairly short intervals.
eap35
JPM
DFW,TX
2022 ND2 RF GT
mind mentioning if filter AND oil change is what's recommended around the 500 miles mark ? What oil do you use and how are your numbers ? other than that, would you agree 0w20 oil is probably my best bet for CT ( West Hartford ) year round since it gets a bit colder?
Ktrw
Zach
United States
2025 Integra Type S
Yeah, I think it's a great idea to change your oil around 500-1000 miles to get a bulk of the break-in material out. 0W-20 is fine for these engines, especially with the stock configuration. I run 5W-30 as well and found both to be sufficient, but I prefer to run the slightly thicker oil for hydrodynamic wedge reasons. I got some great wear results with PUP 5W-30 (4ish ppm wear metals per 1,000 miles), so I will stick with that until I can try Honda Formula R, since that is extremely interesting to me. You may want to consider 5W-20 as well if the temperature range works for your local climate, because it should be more shear stable than 0W-20 while not being substantially thicker.
I think you could choose from a variety of filters and be fine. Tons of people and shops swear by the Honda OEM filter, and I don't think there's really anything wrong with it other than the build quality internally leaves some to be desired, imo. I forgot initially, but I edited my previous comment to include that I run Purolator filters (PBL14610/PL14610).
I would not change factory oil at 500, wait at least to 1,000 (I waited to 3,000)
best commonly/cheaply available: Pennzoil Platinum Plus (I use 5w-30)
best probably Amsoil Signature
Fram ultra synthetic used to be best filter by far (smallest particles, best flow), but company went under, factories closed (includes Amsoil, K&N and other private labels)
current best filter for smallest particles and best flow is Purolator One (not Boss, which is designed for high mileage)
but most important is to keep oil change interval to 5,000 miles
for a filter look for under 20 microns at 90+ efficiency, good flow, low psi drop, high bypass.
eap35
JPM
DFW,TX
2022 ND2 RF GT
Can you dive into why you’d prefer oil change at 1000 over 500?
I will be doing lot of short trips (driving the car for 5mn at a time sometimes 10mn ); was told that I probably should stick to at most 2500-3000 miles oil changes!
Anyone can comment on this as well as how you “warm up” your fl5 and most importantly cool it down?
I love this thread as it focuses on data/science
johnloov
johnloov
John
Agreed. What the data proves is the first 10,000 miles you are flushing out wear metals. No matter which API sq/sp engine oil you use, 0w-20 or 5w-30. Change it more frequently. First 1000-3000 miles then ( there is a lot of moly added in for break in from factory ) - Change it every 2-3k or 2-4 track days. All engine oils degrade after 2000 miles according to top experts, engine builders, and oil analysis labs. Getting rid of contaminants is #1.
eap35
JPM
DFW,TX
2022 ND2 RF GT
Just dmed. We worry about contamination , now what are best practices about warming up/cooling down the k20c1? What’s the minimum oil/engine temp that shows on the logR before driving hard ?
johnloov
johnloov
John
I always wait 10-15 min before woT and right after a track session, I always do a cool down lap, my heater is always on at max heat, recirculate, fan off ( that keeps stock car from overheating - makes a 10-15F difference, I drive straight to a gas station that’s 10 min away allowing entire car brakes and engine temps get water temps down to 190F and then I shut it down and fill it up. Also if you’re just driving in a spirited manner, lay off the boost at least 5 min before coming home so turbo has time to cool.
That’s my regiment so far. I see a lot of people come hot off track and shut their cars down and lift their hoods up - I cringe 😬 for their turbo and engine.
This is roughly the heat water temp difference between running no heater on max on stock FL5 on track and 0w/20 pennzoil ultra platinum
Here is exact same position on track with heater on max, no fan vs. interior temp on cold no fan. The heat exchanger helps keep temps down by about 15 degrees.
11th Gen Honda Civic 🔴💊 Engine Oil Red Pill Thread: Only Post If You Have UOA - Official Honda Civic Type R K20C1 Engine Oil Analysis IMG_3289
11th Gen Honda Civic 🔴💊 Engine Oil Red Pill Thread: Only Post If You Have UOA - Official Honda Civic Type R K20C1 Engine Oil Analysis IMG_3286
try to keep it under 3k rpms for the first 10 mins, no full boost/redline until oil temps are at least 180 deg.
joshinthecity
Josh
Sydney Australia
2025 CTR. Championship White.
I go one step further.
Warm up stage 1: Gentle driving and no real boost until 80c water temp
Warm up stage 2: Moderate driving until the oil temp shows higher than the water temp (an additional 5 mins or so) Then it's hammer time.
johnloov
johnloov
John
I have switched to Pennzoil Ultra Platinum 5W-20 to test if it truly is more sheer stable than the 0W-20 version.
Lake Speed just released this video - it's very interesting - they found that sheer stability was the single most important driving factor in protecting you're engine over viscosity - of course with frequent oil changes is still #1
I'll have the PUP 0W-20 results and this time I did an equivalent of 6 track days on it ( I might have pushed it too far - let's see what the lab results say )
johnloov
johnloov
John
This video is also excellent to dispel confusion on oil pressures
