Break in period (make me feel good)
LaFlamaBlanca
Arizona
FL5 Type R
Hey guys, I was told that these motors are already broken in from the factory but it seems people have different definitions of what that means. Ihave 150-200 miles on the fl5. I had planned on staying pretty chill until the 500-600 mile range the manual suggests until yesterday happened where i was out with the boys (Supra and 911): After the car was warm i did a couple pulls up to 7k rpm from 1st through 3rd. Today I wake up and feel like an idiot. Any thoughts?
Tickle
Chris Long is that you?
What is done is done. Many people don't wait for 600 miles.
What’s done is done. No sense it letting it bother you. It’s just a few pulls anyway and these engines are known for their durability. It’s not like you went crazy with it for hours at the track or something.
mmdct
Northeast
FL5 CTR Crystal Black Pearl
when i picked up mine, there was 22 miles on the odo. someone likely had a great time burning those miles and it wasn't me.
i finished the break-in, gently, for the next 600, dropped the oil at 650, and she runs fine.
enjoy your FL5. HONDA MAKES GREAT MOTORS... this is my eighth time owning the brand and they've all treated me well!
chopsuey34
West Michigan
My go to source on new car break in periods:
https://www.bmw.com/en/automotive-life/break-in-a-new-car.html#pwjt-4
Many drivers wonder whether breaking in a new car is still necessary or if this practice has been superseded with the advances in technology. The answer? Yes and no...
Doing an engine break-in used to be a standard procedure with new cars. And it’s still the case that you should avoid running the engine at high RPM for the first 1,300 miles. Experts recommend a maximum 3,500 rpm and 90 mph in diesel models and 4,500 rpm and 100 mph in gas models. This will give the engine and transmission sufficient time to adjust to each other. Once you’ve reached the 1,300-mile mark, you can gradually increase your speed and your engine’s RPM. In particular, avoid to put too much strain on a cold engine. However, that’s true not just when breaking in a new car but for the whole life cycle of your car. Likewise, never turn off an engine that has been running hard. Allow it to cool down by driving a few miles at a gentle pace.
During the new car break-in period, take note of the following tips:
  • For the first 200 miles, new tires will not yet provide full grip. This is because a release lubricant used in the manufacturing process has to be worn away from the tire surface. Adjust your driving accordingly to prevent accidents.
  • Similarly, the brakes won’t become fully effective for the first 300 miles as the brake pads and discs will need to adjust to one other. You should therefore drive cautiously.
  • The shock absorbers and springs will also need some time to become fully effective. That’s why you should not push your new car to its limits during the first 1,000 miles or so.
While many engine break-in tips also apply to modern engines, one compulsory rule for new cars has disappeared, as it’s no longer necessary to change the engine oil after the first 1,000 miles. You should, however, also keep these break-in practices in mind when replacing individual components later on.
Cornercarver
Rio Verde AZ
1,300 miles?? And that folks is why I drive a Honda instead of a BMW.
2023 CTR #3177
First shift from the dealer was at redline.
IMO it's fine to run it to redline a few times - just avoid sustained loads, lugging, or extended time at one RPM or high RPM which is pretty much what the manual says.
As I've said before, if you've ever bought a car with non zero miles... those miles were hard. I know how I test drive cars. When they dyno a new engine... they run it to redline.
Don't bring this up on YT though unless you want a million replies from worry warts who won't exceed 3k until they have thousands of miles (if ever).
AWR1997
Andrew
Columbus, OH
2023 FL5 Civic Type R R-00154 (deceased)
My car had 26 miles when I hopped into it for the first time. It sort of scares me to think that the first 26 miles was some transport person or individual at the dealership hooning the car.
Cornercarver
Rio Verde AZ
And yet the cars seem to survive those early hard pulls at the dealer.
Well ~15 of those miles are from final test at the factory, I believe? That’s how it was when I bought my ā€˜09 Si. It had 14 miles on it (from the factory test) and not a single mile more. This is back when dealers understood that buyers for Si’s are limited and that the same small crowd of buyers didn’t want to buy the cars with ANY extra miles on them. Dealers would not even let people test drive them unless they were serious and sitting at the desk working a deal with the salesperson.
I need to check my paperwork to see how many miles were on my CTR at time of purchase. I want to say it was like 11 miles or something like that.
daazn
97 Miata
There's no way they drove ~15 miles at the factory. I've seen CTRs with less delivery miles. Personally mine was at 18 and I worry about it sometimes lol
