Downpipe differences
Nikw91
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
Well what's your budget and plans for modding? Any restrictions (like emissions related). I'd say you just go with what you can comfortably afford and if you really care about power, go catless. If it were me, I'd go TSP because I like PRL stuff.
No budget. Just cheap and don’t like wasting money lol
Tougefl5
You should probably just keep it stock. Like TSP said the oem exhaust system is pretty good as is.
I personally don't see a need to mess with it in less your doing a turbo upgrade and turbo back exhaust system.
Canflex and tune is your best bang for buck ?
I have the TSP downpipe on order because my state has emissions testing. Even if the emissions fault code is blocked on the tune, the state test will bust me and I will be hanged from the neck until dead.
Tougefl5
EPA is probably going to be dismantled soon. So don't trip lol
Nikw91
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
Did you mean turbo cat back exhaust?
Nikw91
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
After more research. The 27WON maintains factory heat shield and has the cat is only 200 cell.
In theory, would the 27won 200 cell downpipe flow a lot more efficiently then the 300 and 400 cell downpipes?
27WON is the only company to post actual dyno/hp numbers. All other downpipe companies just say “more” power and faster spooling… which is kinda suspect.
11th Gen Honda Civic Downpipe differences IMG_3190
Yorkman1
DM
2024 Type-R #170001
Ok this is going to piss some people off but,
MAP advertises a GESI cat. They come with a cheap 200 cell cat and you WILL get a CEL.
I lost my shit on them and was told to f myself basically. You can pay them hundreds more and they will custom make you a GESI catted downpipe.
just by a TSP if you want a catted DP
if you want a straight pipe it will be louder and more power but you will get a CEL, unless you tune it out.
My .02. From a MAP DP owner
11th Gen Honda Civic Downpipe differences IMG_7509
Nikw91
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
It’s kinda common knowledge that all downpipes will throw a code other than TSP.
No tune then go tsp…
Tuned, can go any downpipe.
Yorkman1
DM
2024 Type-R #170001
If you get an OTS tune from the normal vendors they come locked so what that means is you can’t disable your CEL from the DP
Nikw91
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
My bad, that’s weird. Every other car I’ve had with off the shelf tunes came with the sensor disabled so i wouldn’t throw a cel.
Whose tune are you using?
How is the sound/performance of the MAP downpipe otherwise?
Nikw91
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
