FL5 Intercooler Reference Thread
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
Seems like so many options atm. Hard to finalize which to get. Any advice for car thats dual duty dd/5-10 track days a year, car will be stock turbo always just tune, intake, exhaust.
Ideally goal is best intake airtemps
least pressure drop
Least lag.
Weight or looks doesnt matter.
5-10 track days a year is a decent amount. Depending on your budget, I would only go HKS ($1,040), PWR ($1,750), WOT ($2,000) or J’s Racing ($2,555) since your stock turbo and tracking.
The tube and fins do take a beating with rocks and debris during daily driving.
I had the PRL bar and plate but it added noticeable turbo lag and overheating at the track.
siwelnosaj
Jason
Reno, NV
Type R
That's also one of the benefits with the Microtube design, no fins to get damaged.
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
I threw that comment in there just for you and you jumped on it quick šŸ˜‚šŸ¤£
petrik
denver
M2C / ND3 gone
Thanks for feedback guys, watched both your vids. Love the details you guys pursue - im same mindset. How are those 3 intercoolers different in turbo lag on stock turbo? People I saw measure core volume but thats not always accurate since a large part of that is vented space. Any data or even anecdotal answers?
siwelnosaj
Jason
Reno, NV
Type R
I looked at the logs to try and estimate pressure loss. I compared airflow at matched RPM, manifold pressure, throttle position, and intake-air temperature. Pressure drop was estimated using Hondata’s airflow-based intercooler model, where pressure loss is approximated to increase with the square of mass airflow (Ī”P āˆ ṁ²). At roughly 300–320 g/s, both intercoolers calculated to approximately 2.5–2.7 psi of modeled pressure loss, with the difference between them effectively negligible.
The Microtube design maintains the same pressure loss, slightly better IATs, while offering significantly more airflow to the radiator, providing lower coolant and oil temps.
HuyR
Aaron
2025 Honda Civic Type R
Question I have PWR bar and plate intercooler wonder if HKS piping would fit
Not sure about HKS but I know 1 FL5 running a PWR bar and plate with HPS charge pipes if you're open to alternate options
HuyR
Aaron
I assuming they are fit the same if HPS fit don't you think?
It will 100% fit. The HKS piping kit replaces the stock components while also replacing the OEM cold side plastic elbow with a cast aluminum part. It supports any aftermarket intercooler that bolts to the original OEM intercooler elbow connections.
FWIW, I have been running the HKS piping kit connected to a J's Racing intercooler without issue. OEM intercooler bolts right up the same.
Link for further information to consider.
HPS charge pipes work as a no brainer. The offering does not replace the OEM intercooler inlet or outlet elbows. No real need to replace the inlet elbow since it is cast aluminum unlike the outlet elbow.
HuyR
Aaron
Thanks I appreciate so much I'm feel šŸ’Æ confident ordering HKS piping now
HuyR
Aaron
I thought the cold side factory intercooler is plastic elbow connected to intercooler end tank and HPS seem like doesn't provide cast aluminum elbows like HKS I might be wrong but I don't see any cast aluminum elbows to replace that oe plastic
Correct...If you read the link that I shared a few posts up, it provides PICs and details for the various intercooler pipe kit upgrade options.
timestamped
DC
ā€˜24 boost blue FL5, ā€˜15 tuxedo black FoST3
Has anyone shaved the lower inside lip of the intercooler opening?
11th Gen Honda Civic FL5 Intercooler Reference Thread IMG_2559
11th Gen Honda Civic FL5 Intercooler Reference Thread IMG_2560
