OEM Honda MTF. I use it in all of my Honda cars... street and race cars.What grade oil would you recommend?
I suspect the latter has been my issue.I beat the ever living shit out of my FL5 and it doesn't grind any gear. Let is warm up before romping on it and its fine. If you are grinding gears you aren't shifting right.
I notice the same thingI've noticed that the 2nd gear shift at lower speeds is a bit crunchy at times.
Do you guys think this is user error on my part or an issue I should take to the dealership?
What type of perfect shifting should be done? Ive driven multiple stick shift cars including the 10th gen Si and FK8 and damn the FL5 is horrible. I have done everything and 2,3,&4, just dont stop grinding every time i get into gear.I beat the ever living shit out of my FL5 and it doesn't grind any gear. Let is warm up before romping on it and its fine. If you are grinding gears you aren't shifting right.
Me too. "Crunchy" is the perfect way to describe it. Not a grinding for me, more like the notch to get in second is not smooth as all of the others. I get that feeling whether im casually driving or redlining it. It's not every shift to 2nd either, some feel really smooth. Every other gear, except reverse, is like butter every time.I notice the same thing
